Alternate 4
Error: Setup_wm.exe - Entry Point Not Found!
hibent
Nov. 2007
While trying to install the Windows Media Player 11, I am encountering following error message:
"The procedure entry point_except_handler4_common could not be located in the dynamic link library msvcrt.dll"
Where as I could see that this file had been copied and pased on the Windows Media Player.
One time I could able to run the setup program and it has been installed but I could not able to open it.
When I click to open the program I am having the same error message as mentioned above.
Can anyone help to resolve the issue!
Use the player-installer for your operating system, I guess you try to install a version not designed for it.
I have been blocked now. I could not able to uninstall or remove this Media Player 11 through Control Panel Add and Remove Program. I can see there the Program is installed.
Might be some Registery Changes are required! I guess...
Hope for the best solution... anyhow thanks for consideration
