hatte auch diese sound probleme....ein freund von mir sagte in der readme würde drinn stehen wie das problem zu lösen sei. nachgesehen und siehe da! sound geht nachdem ich nach anweisung alles bereinigt hatte.
gruss Nox
X. Audio Troubleshooting
• For a more detailed listing of all known audio issues with Freelancer, please visit <
http://support.microsoft.com/default.aspx?scid=fh;EN-US;gmssound>. DirectX - If you experience audio problems using DirectX, connect to the DirectX Web site for the latest troubleshooting information, as explained in DirectX Troubleshooting. If this occurs, ensure that you have the latest drivers from your sound card manufacturer or check Windows Update (<
http://windowsupdate.microsoft.com/>) for the latest drivers.
• Sound Skipping or Stuttering - Often this problem can be fixed by installing the latest sound drivers for your sound card and/or adjusting the hardware acceleration settings in the control panel. Setting hardware acceleration to a lower setting usually resolves these issues (and a few others), but sacrifices some performance.
• Missing Game Sounds
If you experience missing game sounds throughout Freelancer then a different audio codec is probably being used rather that the one provided by Freelancer.
• Please follow these steps if some sounds and speech are still missing after installation:
• Uninstall any 3rd party codec pack or the Nimo Codec pack from your system.
• Uninstall Freelancer.
• Go to the following directory, C:\WINDOWS\system32 and delete the file “l3codecp.acm”. If there happens to be another file named “l3codeca.acm”, delete this too.
• If your system is Windows 98 or ME, open the system.ini file located in your system folder; C:\WINDOWS\SYSTEM. Delete ONLY the line that starts with “msacm.l3acm=”. In the case of the Nimo codec pack, this will read “msacm.l3acm=l3codecp.acm”
• If your system is Windows 2000 or XP, open the system registry editor (regedit) from the RUN command window.
• Locate and delete the following key: \HKLM\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Drivers32\msacm.l3acm
• Load the Freelancer installation CD and locate the REDIST folder. Within the REDIST folder, double click on the file named “WMFADist.exe” and follow on-screen instructions.
• Install Freelancer.
