This product can be used with any video cards that have heatsink mounting
holes.
Note 1) If you are using an nVIDIA GeForce FX5800, an ATI Radeon 9800 Pro, a Matrox Parhelia, or a more advanced model, an Optional Fan (ZM-OP1, sold separately) must be installed.
Note 2) This product is not installable on an nVidia GeForce 6800 GT, 6800 Ultra because they do not have 3mm holes around the GPU.
Note 3) Zalman does not recommend VGA card overclocking. Zalman is not responsible for any damage from VGA card overclocking.
Note 4) Since this product weighs 350 g, always firmly fasten the VGA card onto the case with a screw. Special care should be taken while the computer is being moved. Zalman is not responsible for any damage arising while moving the computer.
Note 5) To enhance the performance of this product, the use of a fan on the rear panel of the system’s case is recommended.
Note 6) After installing this product on a VGA card (Video Graphics Card), the PCI slot adjacent to the AGP slot will be unusable.
Die hier geht auf die 6600 GT AGP ohne Probleme rauf - man muss nur noch den HSI Chip mit einem Passivelemt kühlen, falls beim alten Lüfter keiner schon drauf war
