HMailServer
HackyPaddy
Aug. 2004
ich wollte heute einen Mailserver mit dem HMailServer aufsetzen.
Bis jetzt klappt auch der Versand aller E-Mails 100%ig. Nur wenn jemand an eine Adresse auf unserem Server schreibt, kommt folgende Logmeldung:
Code:
"TCPIP"	1440	"2005-10-07 06:32:59.515"	"SMTPD - Connection from 212.227.126.171 accepted."
"SMTPD"	2264	"2005-10-07 06:32:59.515"	"212.227.126.171"	"SENT: 220 SMTP-XXX ESMTP"
"SMTPD"	2264	"2005-10-07 06:32:59.515"	"212.227.126.171"	"RECEIVED: EHLO moutng.kundenserver.de"
"SMTPD"	2264	"2005-10-07 06:32:59.515"	"212.227.126.171"	"SENT: 250-hmailserver[nl]250-SIZE[nl]250 AUTH LOGIN"
"SMTPD"	2264	"2005-10-07 06:32:59.531"	"212.227.126.171"	"RECEIVED: MAIL FROM:<XXX@XXX.de>"
"TCPIP"	2264	"2005-10-07 06:32:59.546"	"DNS - INAddr lookup: 171.126.227.212.sbl-xbl.spamhaus.org"
"TCPIP"	2264	"2005-10-07 06:32:59.562"	"DNSResolver - INAddr Lookup result for 171.126.227.212.sbl-xbl.spamhaus.org: 0 responses"
"TCPIP"	2264	"2005-10-07 06:32:59.562"	"DNS - INAddr lookup: 171.126.227.212.relays.ordb.org"
"TCPIP"	2264	"2005-10-07 06:32:59.796"	"DNSResolver - INAddr Lookup result for 171.126.227.212.relays.ordb.org: 0 responses"
"TCPIP"	2264	"2005-10-07 06:32:59.796"	"DNS - INAddr lookup: 171.126.227.212.bl.spamcop.net"
"TCPIP"	2264	"2005-10-07 06:32:59.812"	"DNSResolver - INAddr Lookup result for 171.126.227.212.bl.spamcop.net: 0 responses"
"SMTPD"	2264	"2005-10-07 06:32:59.875"	"212.227.126.171"	"SENT: 250 XXX@XXX... Sender OK"
"SMTPD"	2264	"2005-10-07 06:32:59.890"	"212.227.126.171"	"RECEIVED: RCPT TO:<XXX@XXX>"
[B]"SMTPD"	2264	"2005-10-07 06:32:59.890"	"212.227.126.171"	"SENT: 530 SMTP authentication is required."[/B]
"SMTPD"	2264	"2005-10-07 06:32:59.890"	"212.227.126.171"	"RECEIVED: QUIT"
"SMTPD"	2264	"2005-10-07 06:32:59.890"	"212.227.126.171"	"SENT: 221 goodbye"
"TCPIP"	2264	"2005-10-07 06:32:59.890"	"SMTPD - Connection to client 212.227.126.171 closed."
Es scheint so, als wenn jeder Mailserver von aussen, der unserem Mailserver eine E-Mail übermittelt, sich authendifizieren muss. Das kann doch nicht sein, sowas kontraproduktives hab ich wirklich noch nie gesehen.
Der Mailserver soll so eingerichtet sein, dass wenn eine E-Mail über unseren SMTP-Server ins Netz geschickt wird, er dann AUTH verlangt. Aber das soll er nicht bei einer ankommenden Mail machen ? :freak:
Kennt sich vielleicht einer mit dem HMailServer aus und hatte das Problem schonmal gehabt?
Würde mich freuen, wenn Antworten eintreffen :-)
SMTP ist ein Protokoll zum Emailversenden. Eine Authentifizierung ist da dann auch wirklich sinnvoll, damit nicht jeder unter irgendwelchen Addressen Emails über deinen Server verschicken kann!
Der Empfang von Emails bzw. das Abholen von Emails müsste doch IMO über ein anderes Protokoll laufen?! Würde aber auch eher meinen, dass dein Mail-Server aktiv die Mails per POP3 oder IMAP abholen sollte...
-> Hab noch keinen MailServer aufgesetzt, aber theoretisch müsste das so sein?!
