Linux Mint 22.1 Xfce Desktop und Fensterschliesne und minmieren Propleme
4nudels
Apr. 2020
Wäre Ide hier Infos
in thuinar schon wie kan desktop usw neu starten nottebook neustarten bringt nix wer idee ?
und Fenster zeigen ma niemavergrössern und schliesen an beides gleichzeitig gekomen danke
auch hier gepostet https://forum.linuxguides.de/index....eigt-nichts-mehr-an/&postID=166658#post166658
Code:
    nudels@nudels:~$ inxi -Fz System: Kernel: 6.8.0-60-generic arch: x86_64 bits: 64 Desktop: Xfce v: 4.18.1 Distro: Linux Mint 22.1 Xia Machine: Type: Laptop System: Dell product: Latitude 7390 v: N/A serial: Mobo: Dell model: 09386V v: A00 serial: UEFI: Dell v: 1.43.0 date: 03/06/2025 Battery: ID-1: BAT0 charge: 60.0 Wh (100.0%) condition: 60.0/60.0 Wh (100.0%) CPU: Info: quad core model: Intel Core i5-8350U bits: 64 type: MT MCP cache: L2: 1024 KiB Speed (MHz): avg: 3592 min/max: 400/3600 cores: 1: 3600 2: 3600 3: 3600 4: 3600 5: 3602 6: 3600 7: 3534 8: 3601 Graphics: Device-1: Intel UHD Graphics 620 driver: i915 v: kernel Device-2: CNFGH19P165410063790 Integrated_Webcam_HD driver: uvcvideo type: USB Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X: loaded: modesetting unloaded: fbdev,vesa dri: iris gpu: i915 resolution: 1: 2560x1440 2: N/A API: EGL v: 1.5 drivers: iris,swrast platforms: gbm,x11,surfaceless,device API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.8-1ubuntu1~24.04.1 renderer: Mesa Intel UHD Graphics 620 (KBL GT2) API: Vulkan v: 1.3.275 drivers: N/A surfaces: xcb,xlib Audio: Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel API: ALSA v: k6.8.0-60-generic status: kernel-api Server-1: PipeWire v: 1.0.5 status: active Network: Device-1: Intel Ethernet I219-LM driver: e1000e IF: enp0s31f6 state: down mac: Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi IF: wlp2s0 state: up mac: IF-ID-1: virbr0 state: down mac: IF-ID-2: wwan0 state: down mac: Bluetooth: Device-1: N/A driver: btusb type: USB Report: hciconfig ID: hci0 state: up address: bt-v: 4.2 Drives: Local Storage: total: 1.02 TiB used: 237.41 GiB (22.6%) ID-1: /dev/mmcblk0 model: MSSD0 size: 117.04 GiB type: Removable ID-2: /dev/nvme0n1 vendor: Western Digital model: WD BLACK SN770 1TB size: 931.51 GiB Partition: ID-1: / size: 883.83 GiB used: 237.38 GiB (26.9%) fs: ext4 dev: /dev/nvme0n1p2 ID-2: /boot/efi size: 511 MiB used: 25.3 MiB (5.0%) fs: vfat dev: /dev/nvme0n1p1 Swap: ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p3 ID-2: swap-2 type: zram size: 30.48 GiB used: 7.34 GiB (24.1%) dev: /dev/zram0 Sensors: System Temperatures: cpu: 85.0 C mobo: 66.0 C Fan Speeds (rpm): cpu: 6321 Info: Memory: total: 32 GiB note: est. available: 30.48 GiB used: 27.97 GiB (91.8%) Processes: 468 Uptime: 23h 37m Shell: Bash inxi: 3.3.34 nudels@nudels:~$
Erklärung des Beitrags durch Claude.Ai.
Der Benutzer fragt, wie er den Desktop neu starten kann. Er hat bereits versucht, das Notebook (Laptop) neu zu starten, aber das hat nichts gebracht - die Probleme bestehen weiter.
Das eigentliche Problem:
  • Fenster lassen sich nicht mehr vergrößern oder verkleinern
  • Ein Neustart des Laptops hat das Problem nicht gelöst
  • Er sucht nach einer Möglichkeit, nur den Desktop/die Desktop-Umgebung neu zu starten, ohne den ganzen Computer neu starten zu müssen
Die Frage: Wie kann man unter Linux Mint 22.1 mit Xfce den Desktop neu starten, wenn ein kompletter Neustart des Computers das Problem nicht behoben hat?
Lösungsvorschläge durch Claude-AI.
Sofortige Lösungen:
1. Xfce Desktop neu starten (ohne Neustart des Computers):
Code:
bash# Xfce-Panel neu starten
xfce4-panel -r
# Oder kompletten Xfce-Desktop neu starten
pkill xfce4-session && startxfce4
2. Fenstermanager neu starten:
Code:
bash# Xfwm4 (Xfce Window Manager) neu starten
xfwm4 --replace &
3. Über das Terminal ausführen:
Code:
bash# Alt + F2 drücken, dann eingeben:
xfwm4 --replace
Häufige Ursachen und weitere Lösungen:
4. Compositor-Probleme:
  • Einstellungen → Fensterverwaltung → Erweitert
  • "Fensterzusammenstellung aktivieren" aus- und wieder einschalten
5. Themes/Designs zurücksetzen:
  • Einstellungen → Erscheinungsbild → Standard-Theme auswählen
6. Xfce-Einstellungen zurücksetzen:
Code:
bash# Xfce-Konfiguration sichern und zurücksetzen
mv ~/.config/xfce4 ~/.config/xfce4-backup
7. Grafiktreiber prüfen:
Code:
ash# Grafikkarte und Treiber anzeigen
inxi -G
Ich habe auch ADHS, aber das ist keine Aussrede dafür, sich nicht etwas zu bemühen. (Bestimmte Dinge lassen sich trainieren --> mal Neurofeedback-Training testen, das hilft sehr, übernimmt die Krankenkasse.)
Es gibt Werkzeuge für einen Browser, die Ihnen dabei helfen können Rechtschreibfehler zu erkennen.
Ebenso kann eine KI wie Claude.Ai helfen, Beiträge verständlich zu verfassen oder vorher Lösungsansätze zu testen.
Zuletzt bearbeitet: (Text vereinfacht, Absätze hinzugefügt, damit Themenersteller es leichter beim Lesen hat.)
Reaktionen: rollmoped, Sir Gollum und Traube
punkt 4 fesbterzusammenstelung finde nicht
Code:
nudels@nudels:~$ inxi -G
Graphics:
    type: USB
    1: 2560x1440 2: N/A
Desktop zeigt noch immer nichts an, trotzdem Danke.
Alle Schritte um gesetzt Fenster kann wieder schlisen und minimieren aber Desktopoberfläche zeigt noch immer nichts an probier nochmals Neustart Notebook.
Und Thunar funktioniert auch noch nicht noch Wer Idee ?
Kannst du einen Screenshot oder ein Foto erstellen und anhängen?
Wenn Spocks Beitrag nicht geholfen hat würde ich einer KI folgenden Text mitgeben:
Ich nutzte Linux Mint mit XFCE Desktop. Dieser verhält sich nicht wie erwartet. Ein Neustart bringt nichts. Wie kann ich XFCE reparieren oder neu installieren. Ist eine Backup ratsam?
Reaktionen: rollmoped und Sir Gollum
oky danke mache wen von arbeit heim kome die fotos
Reaktionen: Spock55000
Hier würde ich erstmal genre wissen, ob auf dem Rechner überhaupt mal das XFCE funktionierte oder das Problem auf einmal aufgetreten ist?
Ist auff einmal aufgetrette
kein update? keine neue software? nichts?
Dann kann eigentlich an der Hardware etwas kaputt gegangen sein
wüsste ned wie
Starte mal ein Terminal und gib dort 'thunar' ein. Die Ausgabe hier posten.
hier bildschirmfoto vom desktop
in live iso funktioniert alles
Code:
nudels@nudels:~$ 'thunar'
(thunar:37719): thunarx-python-WARNING **: 20:31:58.154: g_module_open libpython failed: /usr/lib/x86_64-linux-gnu/lib.so.1.0: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden
ImportError: could not import gobject (error was: ImportError('/usr/lib/python3/dist-packages/gi/_gi.cpython-312-x86_64-linux-gnu.so: undefined symbol: PyExc_NotImplementedError'))
(thunar:37719): thunarx-python-WARNING **: 20:31:58.235: pygobject initialization failed
(thunar:37719): thunarx-python-WARNING **: 20:31:58.235: thunarx_python_init_python failed
Traceback (most recent call last):
  File "/usr/share/thunarx-python/extensions/RabbitVCS.py", line 29, in <module>
    from rabbitvcs.util.contextmenuitems import *
  File "/usr/lib/python3/dist-packages/rabbitvcs/util/contextmenuitems.py", line 27, in <module>
    import gi
  File "/usr/lib/python3/dist-packages/gi/__init__.py", line 40, in <module>
    from . import _gi
ImportError: /usr/lib/python3/dist-packages/gi/_gi.cpython-312-x86_64-linux-gnu.so: undefined symbol: PyExc_NotImplementedError
welche frage habe über sehen
thunar->thunarx-python->rabbitvcs
Du musst die Erweiterungen (thunarx-python, rabbitvcs) entweder updaten oder deinstallieren.
oky danke habe gemacht dan noch thuanr neustarten oder wie ?
Thunar geht wieder was kann och machen wegen Desktop ?
Oky montags vormittags mache es
Code:
nudels@nudels:~$ killall xfdesktop
xfdesktop: Kein Prozess gefunden
nudels@nudels:~$
nudels@nudels:~$ setsid xfdesktop
nudels@nudels:~$
Hast du eigentlich das was Spock55000 vorgeschlagen hatte alles ausprobiert? Du hast nur auf zwei reagiert. Dort steht z.b. wie der XFCE Panel gestartet wird.
