So :-) ich glaub das System ist doch schon bissel älter
Processors
Number of processors 1
Number of threads 1
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 3.580 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 1 (max 1)
Number of threads 1 (max 1)
Name AMD Sempron 3400+
Codename Manila
Specification AMD Sempron(tm) Processor 3400+
Package Socket AM2 (940)
CPUID F.F.2
Extended CPUID F.5F
Brand ID 6
Core Stepping DH-F2
Technology 90 nm
Core Speed 1799.6 MHz
Multiplier x Bus Speed 9.0 x 200.0 MHz
HT Link speed 799.8 MHz
Stock frequency 1800 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
L1 Data cache 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 256 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
Max FID 9.0x
Max VID 1.300 V
# of P-States 2
P-State FID 0x2 - VID 0x12 (5.00x - 1.100 V)
P-State FID 0xA - VID 0x0C (9.00x - 1.250 V)
K8 Thermal sensor yes
K8 Revision ID 5.2
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Chipset
Northbridge VIA K8M890CE rev. 00
Southbridge VIA VT8237A rev. 00
Graphic Interface AGP
AGP Revision 3.0
AGP Transfer Rate 8x
AGP SBA supported, enabled
Memory Type DDR2
Memory Size 1024 MBytes
Channels Single
Memory Frequency 359.9 MHz (CPU/5)
CAS# latency (CL) 6.0
RAS# to CAS# delay (tRCD) 6
RAS# Precharge (tRP) 6
Cycle Time (tRAS) 18
Bank Cycle Time (tRC) 25
Command Rate (CR) 2T
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) Samsung (CE000000000000000000)
Size 1024 MBytes
Max bandwidth PC2-6400 (400 MHz)
Part number M3 78T2953EZ3-CF7
Serial number 793206C1
Manufacturing date Week 46/Year 07
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 4.0-4-4-12-16 @ 266 MHz
JEDEC #2 5.0-5-5-15-20 @ 333 MHz
JEDEC #3 6.0-6-6-18-24 @ 400 MHz
Monitoring
Mainboard Model K8M890-8237A (0x000002B3 - 0x5C42A620)
Hardware Monitors
Hardware monitor ITE IT87
Voltage 0 1.26 Volts [0x4F] (CPU VCORE)
Voltage 1 1.22 Volts [0x4C] (VIN1)
Voltage 2 3.31 Volts [0xCF] (+3.3V)
Voltage 3 5.00 Volts [0xBA] (+5V)
Voltage 4 12.10 Volts [0xBD] (+12V)
Voltage 5 -3.46 Volts [0x36] (-12V)
Voltage 6 -7.36 Volts [0x73] (-5V)
Voltage 7 4.84 Volts [0xB4] (+5V VCCH)
Voltage 8 3.44 Volts [0xD7] (VBAT)
Temperature 0 33°C (91°F) [0x21] (TMPIN0)
Temperature 1 41°C (105°F) [0x29] (TMPIN1)
Temperature 2 25°C (76°F) [0x19] (TMPIN2)
Fan 0 1032 RPM [0x28E] (FANIN0)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
Hardware monitor ACPI
Temperature 0 34°C (93°F) [0xC00] (THRM)
Storage
Drive 0
Device Path \\?\ide#diskexcelstor_technology_j880s______________pf2oa60a#5&b0d8036&0&0.0.0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Fixed
Name ExcelStor Technology J880S
Revision PF2OA60A
Serial PFDB30K2CTNRXB
Capacity 76.7 GB
SMART Support Yes
Graphics
Number of adapters 1
Graphic APIs
Display Adapters
Display adapter 0
Name VIA Chrome9 HC IGP
Board Manufacturer 0x105B (0x0CF4)
Memory size 128 MB
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x1106 (0x105B)
Model ID 0x3230 (0x0CF4)
Performance Level 0
Win32_VideoController AdapterRAM = 0x8000000 (134217728)
Win32_VideoController DriverVersion = 6.14.10.0057-15.13.10.14
Win32_VideoController DriverDate = 06/22/2006
