ich habe mal Memtest86+ v1.60 laufen lassen.
Leider wurden folgende Fehler gefunden, sonst wurde nix gefunden, FSB steht auch auf 203 statt 200, falls es das sein sollte.
Test: 5
Errors: 34
Test 5 [Block move, 64 moves, cached]
This test stresses memory by using block move (movsl) instructions
and is based on Robert Redelmeier's burnBX test. Memory is initialized
with shifting patterns that are inverted every 8 bytes. Then 4MB blocks
of memory are moved around using the movsl instruction. After the moves
are completed the data patterns are checked. Because the data is checked
only after the memory moves are completed it is not possible to know
where the error occurred. The addresses reported are only for where the
bad pattern was found. Since the moves are constrained to a 8MB segment
of memory the failing address will always be lest than 8MB away from the
reported address. Errors from this test are not used to calculate
BadRAM patterns.
Was sagt mir das nun, sind die Riegel fehlerhaft?
ASUS P5LD2 (i945P)
Corsair XMS2 (DDR2-667) 2x512MB
Pentium 630
mfg
Test: 5
Errors: 34
BadRAM patterns.
ASUS P5LD2 (i945P)
Pentium 630
mfg
