MarcWilmots
- Jan. 2002
Neue Treiber sind fertig.
Die Version zum Catalyst 6.4 wurde übersprungen.
http://www.omegadrivers.net/
v3.8.252
[*] Based on the Catalyst 6.5 Official drivers.
[*] Some resolutions where not showing for some reason, so I re-made the code for them, now every available resolution for your monitor should show up (as long as you have the proper Monitor INF installed).
[+] Added support for x1k Mobility series and some yet unreleased desktop cards.
[*] Updated the integrated Control Panel to v6.14.10.5183
Known Issues:
1) Some of the settings for both D3D & OGL will not be synchronized between ATT and the normal ATI CP, you must only use one of them to make changes, the best option is to use ATT since the ATI CP does not support changes to AI and in order to use the advanced D3D/OGL features. Changes made in ATT will work on games and such but the changes will not be reflected in the normal ATI CP since ATI stores the registry values that the CP reads separate from the actual values in the registry.
Important Info:
Since these drivers include a non-standard version of ATT, I would recommend that if you have any previous version of ATT installed, please uninstall it before installing these drivers, not doing so may cause unknown problems.
v3.8.252
Known Issues:
Important Info:
