Fireplace April 2026
Open Suse 13.1 - PC wacht aus Stromsparmodus auf
G
-GL4x-
Das Problem kennt man ja zu genüge für Windows. Dort weiß ich, wie ich vorgehen muss um zu verhindern, das der PC ungewollt aus dem Energie-Spar Modus aufwacht.
Unter Suse-Linux leider nicht.
Kann mit jemand weiter helfen?
Ich bräuchte die Befehle für die Ausgabe, was den PC geweckt hat und wie ich es deaktivieren kann.
Gruß und Danke!
Desktop: Gnome
Hier mal ein Auszug aus der Ausgabe dmesg:
Code:
    [ 2372.492247] PM: Entering mem sleep
    [ 2372.492287] Suspending console(s) (use no_console_suspend to debug)
    [ 2372.492370] wlp0s20u10u4: deauthenticating from 44:32:c8:a1:36:e7 by local choice (reason=3)
    [ 2372.542946] cfg80211: Calling CRDA to update world regulatory domain
    [ 2372.543087] sd 1:0:0:0: [sda] Synchronizing SCSI cache
    [ 2372.543177] sd 1:0:0:0: [sda] Stopping disk
    [ 2372.543290] parport_pc 00:09: disabled
    [ 2372.543432] serial 00:08: disabled
    [ 2372.543939] mei_me 0000:00:16.0: suspend
    [ 2372.964641] PM: suspend of devices complete after 471.898 msecs
    [ 2372.964744] PM: late suspend of devices complete after 0.102 msecs
    [ 2372.964898] r8169 0000:03:00.0: System wakeup enabled by ACPI
    [ 2372.975707] ehci-pci 0000:00:1d.0: System wakeup enabled by ACPI
    [ 2372.986709] ehci-pci 0000:00:1a.0: System wakeup enabled by ACPI
    [ 2373.008651] xhci_hcd 0000:00:14.0: System wakeup enabled by ACPI
    [ 2373.028647] xhci_hcd 0000:00:14.0: power state changed by ACPI to D3cold
    [ 2373.028684] PM: noirq suspend of devices complete after 63.887 msecs
    [ 2373.028876] ACPI: Preparing to enter system sleep state S3
    [ 2373.029166] PM: Saving platform NVS memory
    [ 2373.029469] Disabling non-boot CPUs ...
    [ 2373.030641] smpboot: CPU 1 is now offline
    [ 2373.032071] smpboot: CPU 2 is now offline
    [ 2373.033441] smpboot: CPU 3 is now offline
    [ 2373.034512] ACPI: Low-level resume complete
    [ 2373.034542] PM: Restoring platform NVS memory
    [ 2373.034859] microcode: CPU0 sig=0x306c3, pf=0x2, revision=0x16
    [ 2373.034917] Enabling non-boot CPUs ...
    [ 2373.034971] smpboot: Booting Node 0 Processor 1 APIC 0x2
    [ 2373.046626] CPU1 microcode updated early to revision 0x16, date = 2013-08-07
    [ 2373.049581] microcode: CPU1 sig=0x306c3, pf=0x2, revision=0x16
    [ 2373.049705] CPU1 is up
    [ 2373.049748] smpboot: Booting Node 0 Processor 2 APIC 0x4
    [ 2373.060688] CPU2 microcode updated early to revision 0x16, date = 2013-08-07
    [ 2373.063658] microcode: CPU2 sig=0x306c3, pf=0x2, revision=0x16
    [ 2373.063776] CPU2 is up
    [ 2373.063819] smpboot: Booting Node 0 Processor 3 APIC 0x6
    [ 2373.074762] CPU3 microcode updated early to revision 0x16, date = 2013-08-07
    [ 2373.077740] microcode: CPU3 sig=0x306c3, pf=0x2, revision=0x16
    [ 2373.077859] CPU3 is up
    [ 2373.080107] ACPI: Waking up from system sleep state S3
    [ 2373.085875] xhci_hcd 0000:00:14.0: power state changed by ACPI to D0
    [ 2373.096903] xhci_hcd 0000:00:14.0: System wakeup disabled by ACPI
    [ 2373.118927] ehci-pci 0000:00:1a.0: System wakeup disabled by ACPI
    [ 2373.140943] ehci-pci 0000:00:1d.0: System wakeup disabled by ACPI
    [ 2373.174108] PM: noirq resume of devices complete after 93.486 msecs
    [ 2373.174209] PM: early resume of devices complete after 0.066 msecs
    [ 2373.174230] xhci_hcd 0000:00:14.0: setting latency timer to 64
    [ 2373.174251] mei_me 0000:00:16.0: irq 44 for MSI/MSI-X
    [ 2373.174302] ehci-pci 0000:00:1a.0: setting latency timer to 64
    [ 2373.174322] ahci 0000:00:1f.2: setting latency timer to 64
    [ 2373.174358] snd_hda_intel 0000:00:1b.0: irq 46 for MSI/MSI-X
    [ 2373.174360] r8169 0000:03:00.0: System wakeup disabled by ACPI
    [ 2373.174426] ehci-pci 0000:00:1d.0: setting latency timer to 64
    [ 2373.174506] pci 0000:04:00.0: setting latency timer to 64
    [ 2373.175336] serial 00:08: activated
    [ 2373.175686] parport_pc 00:09: activated
    [ 2373.480193] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
    [ 2373.480990] ata3.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
    [ 2373.480992] ata3.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
    [ 2373.480993] ata3.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
    [ 2373.482131] ata3.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
    [ 2373.482132] ata3.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
    [ 2373.482133] ata3.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
    [ 2373.482455] ata3.00: configured for UDMA/100
    [ 2376.391539] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
    [ 2376.499874] ata2.00: configured for UDMA/133
    [ 2376.499915] sd 1:0:0:0: [sda] Starting disk
    [ 2376.660044] PM: resume of devices complete after 3483.021 msecs
    [ 2376.660127] rtl8192cu: Chip version 0x11
    [ 2376.697085] rtl8192cu: MAC address: xxxxx
    [ 2376.697086] rtl8192cu: Board Type 0
    [ 2376.697164] rtl_usb: rx_max_size 15360, rx_urb_num 8, in_ep 1
    [ 2376.697174] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw.bin
    [ 2376.697241] ieee80211 phy4: Selected rate control algorithm 'rtl_rc'
    [ 2376.697391] rtlwifi: wireless switch is on
    [ 2376.697489] PM: Finishing wakeup.
    [ 2376.697490] Restarting tasks ... done.
Es sind die Einträge vom Einleiten des Sleepmodus bis zum kompletten Wakeup. Ich pers. kann hier nicht sehen, was den Wakeup ausgelöst hat. Ich seh hier nicht mal den Eintrag an dem das System wieder aufgeweckt wird :/
Vielleicht sieht hier jemand mehr!
pm-powersave.log, pm-suspend.log gibt es anscheinend auf meinem System nicht.
/var/log/messages forste ich gerade durch und werde es später posten.
Da es in den meisten Fällen die Maus der Übertäter ist, kann jemand sagen wie ich unter Suse die Maus vom Wakeup ausnehmen kann?
bei mir is es erst recht lustig ;) wenn mein pc im suspend modus ist, also sleep/strom sparen oder wie das überall anders heißt, kann ich meinen pc mit dem ein- oder ausschalten meiner schreibtischlampe aufwecken xD hängt an der gleichen steckerleiste ;)
Von elektrischen Impulsen als Wakeup-Grund hab ich auch schon gehört. Mein Netzteil hängt auch an einer Steckerleiste. Ich teste es mal.
Die Sache ist aber die, unter Windows hab ich es geschafft das Ganze zu unterbinden. Da war es die Maus.
Den Überltäter hab ich mittlerweile gefunden. Es wird der Wlan-Stick im USB2.0 Hub (ohne extern. Stromversg.) sein. Wenn ich den Stick rausziehe, dann den Energiesparmodus aktviere, ist Ruhe bis ich den PC wieder auf wecken.
Schonmal ein Fortschritt. Nur wäre es schon, denn Stick nicht dauernd vorher rausziehen zu müssen. Kann man unter Suse nun iwie das weitere Senden und empfangen im Sparmodus unterbinden?
sieht mir nach nem älteren Bios aus :) Die EInstellung hab ich gar nicht mehr.
Es ist aber mittlerweile gelöst. Es war der USB-Hub schuld. Ich hab jetzt alles, was ich permanent am Rechner benötige dort aus gesteckt, und direkt an die Ports angeschlossen. Am Hub hängen jetzt nur noch externe Platten oder Sticks. Seit dem ist Ruhe :) Schon seit mehreren Tagen nichts dergleichen passiert. Ich denke das wars.
