Overclocking Probleme bei E8500
Doch probier mal:
BIOS@0308-Einstellungen des Maximus Rampage
CPU Feature
Ai Overclock Tuner [Manual]
OC from CPU Level Up [Auto]
CPU Ratio Control [Manual]
Ratio CMOS Setting: [9]
FSB Frequency [445]
FSB Strap to North Bridge [400MHz]
PCIE Frequency [100]
RAM
DRAM Settings [Manual]
DRAM Frequency [1.186MHz]
DRAM Command Rate [2T]
DRAM Timing Control [Manual]
DRAM CMD Skew on Channel A [Auto]
DRAM CMD Skew on Channel B [Auto]
CAS# Latency [5]
RAS# to CAS Delay [5]
RAS# Precharge [5]
RAS# Active Time [15]
RAS# to Ras# Delay [Auto]
Row Refresh Cycle Time [Auto]
Write Recovery Time [Auto]
Read to Precharge Time [Auto]
Read to Write Delay (S/D) [Auto]
Write to Read Delay (S) [Auto]
Write to Read Delay (D) [Auto]
Read to Read Delay (S) [Auto]
Read to Read Delay (D) [Auto]
Write to Write Delay(S) [Auto]
Write to Write Delay (D) [Auto]
DRAM Static Read Control [Disabled]
Ai Clock Twister [stronger]
Transaction Booster [Manual]
Common Performance-Level [6]
Pull-In CHA PH1 [deaktiviert]
Pull-In CHA PH2 [deaktiviert]
Pull-In CHA PH3 [deaktiviert]
Pull-In CHB PH1 [deaktiviert]
Pull-In CHB PH2 [deaktiviert]
Pull-In CHB PH3 [deaktiviert]
Voltage Settings
CPU Voltage [1,318V]
CPU PLL Voltage [1,52V]
North Bridge Voltage [1,47V]
DRAM Voltage [2.18V=2,27V real]
FSB Termination Voltage* [1,40V] (*FSB-Abschlussspannung)
South Bridge Voltage [1,05V]
Loadline Calibration [Disabled, unbedingt beim OC deaktivieren]
CPU GTL Reference [0,62x]
North Bridge GTL Reference [0.67x]
DDR2 Channel A REF Voltage [Auto]
DDR2 Channel B REF Voltage [Auto]
DDR2 Controller REF Voltage [DDR2_REF]
SB 1.5V Voltage [Auto]
Performance-Level 6.
Superπ 1M= 11.688s
Superπ 32m= 11.453s
Memtest86+: L1 Cache: 64K 70.265 MB/s, L 2 Cache: 6.155 26.007 MB/s, Mem.:4.095MB= 6.357MB/s
CPU/MCH Reference:
Bei einigen Boards heißen diese Optionen auch CPU (oder MCH) GTLRef und sie stehen für die GTL (Gun Transceiver Logic) Spannungen.
Die GTL Spannungen sind nichts anderes als Referenzwerte die von der CPU (oder MCH oder RAM) genutzt werden um herauszufinden, ob die Spannung am FSB (für Daten oder Adressen) eine logische 1 oder eine 0 darstellt. Diese Spannungen werden von Mainboard generiert.
Die CPU GTL wird normalerweise mit Hilfe von Spannungsteilern aus der VTT "gewonnen" . Der normaler Wert ist VTT * 0.67 (wird von Intel so vorgegeben). Da aber jede CPU etwas anders auf VTT und GTL reagiert, ist es sinnvoll die GTL verändern zu können. Hierbei muss man allerdings mit sehr viel Bedacht heran gehen... Wie auch bei allen anderen Spannungen kann dadurch die Hardware beschädigt werden! Man sollte auf jedenfall nur ganz minimale Veränderungen vornehmen und dann sofort auf Stabilität testen!
Für jede Die auf der CPU (also maximal 2) gibt es eine GTL Einstellung.
Gerade wenn man mit einer QuadCore übertaktet (da hier ja die beiden Dies per FSB kommunizieren), kann diese Einstellung eine entscheidende Hilfe sein. Wie schon bei der VTT und Clock Drive Spannung können hier im hohen FSB Bereich die Signalqualitäten verbessert werden und so noch ein paar Prozent mehr herausgekitzelt werden! Es sei hier nochmal an das Beispiel der "Stillen Post" erinnert Zwinkern
Da für jede DIE die GTL seperat eingestellt werden kann, kann man so auch Qualitätsunterschiede zwischen den DIEs eventl ausgleichen...
Die MCH GTL arbeitet genauso wie die CPU GTL.
Die Channel X Reference bzw GTL arbeitet ebenso wie die CPU GTL, allerdings berechnet sich hier die GTL aus der halben VDimm. Bei dieser GTL handelt es sich um eine GTL für den RAM.
Quelle: Mephis kleiner BIOS-Guide für 965P, P35/45 und X38/48
@shiek,
ich danke Dir für Deine Ausführungen, da die Frage an mich gerichtet war. Ich habe nichts mehr zu ergänzen.
Mich würde jedoch interessieren, ob der Ersteller des Threads nun ein weinig weiter gekommen ist?
Wow, vielen vielen Dank, in diesem Forum kann man echt was lernen! Top und Daumen hoch an euch :daumen:
