BF3 Patch für BF3 da!
Status
.Dome
Okt. 2009
Hey!
Soeben ist wohl der neue Battlefield 3 Patch erschienen. Jedenfalls lade ich via Origin ein 484,6 mb großes Update. Battlelog hat mich außerdem dazu aufgefordert den neusten Patch zu installieren.
Grüße!
Visuals, Stability and Performance Fixes
General performance and loading time improvements
"Black Screen" fix for an issue occurring on some PC configurations
Stereo and rendering support for Nvidia and AMD graphics cards
Fixed several crashes that occurred when joining multiplayer and co-op sessions
Fixed a problem with high speed mouse movement (aka "negative mouse acceleration")
You should no longer be able to damage a friendly vehicle when sitting in an open position
Grenades now drop to ground if you get killed while attempting to throw it (dangerous in Hardcore mode!)
You should no longer spawn too close to enemies in TDM, SQDM, or Conquest
A large number of damage and range tweaks on a number of weapons to fine-tune overall balance in the game
Added round duration and ticket summary at End of Round screen
Fixed a problem regarding key bindings while playing
Significant changes to the Join Squad interface, detailed at the bottom of this post
Balance and Gameplay Adjustments (PC)
Added back some missing Growlers on Kharg Island Conquest Large
Added back EOR sound for SQDM and TDM
Grenades now drop to ground if you get killed while attempting to throw it(note the affect this will have on Hardcore mode!)
Spawn protection now should work in Conquest. You should no longer spawn on points too close to enemies
You should no longer spawn too close to enemies in TDM and SQDM
Combat areas on Kharg Rush tweaked in order to disallow defenders to access the carrier ship after 1st base is taken and being able to enter the AA gun
Fixed a problem with revived players not suffering suppression
Fixed a problem with the camera when being revived in COOP
Added joystick deadzone setting
Fixed sound for when climbing ladders
Fixed an issue with some weapon sounds in first person
Fixed a swim sound loop error
Increased the damage of Helicopter Miniguns, AA guns, and Jet Cannons against infantry
Increased the damage of Helicopter Miniguns against jeeps.
Reduced the physics impact of AA guns and Jet Cannons, players under attack from these weapons should no longer lose control.
Increased the damage of the 44 Magnum slightly.
Increased the range and minimum damage of the .357 Round from the MP412 Rex.
Increased the range of all .45cal and 9mm weapons.
Slightly increased the range of the P90 and MP7 and PDW-R.
Slightly increased the range of the 5.56mm PDW-R and decreased the minimum damage at long range.
Slightly increased the minimum range of the Mk11, SVD, and M39 EMR 7.62mm rifles.
Decreased the maximum damage and maximum range of the G3 and SCAR-H 7.62mm weapons.
Reduced the damage from FIM-92 and SA-18 IGLA missiles against aircraft.
Increased the damage and range of the 40mm BUCK rounds.
Reduced the damage .50cal weapons do against Helicopters.
Updated T90 canister shell tweaks to match Abrams canister shells
PS war jemand schneller :-)
Glaube den hatte ich schon immer. Zumindest war der ähnlich groß
HM bei mir sind es 772 MB:rolleyes:
Der Patch ist seit 10Uhr frei verfügbar ;)
kann zu keinem server mehr verbinden seit das spiel gepatched wurde. es steht ewig lange "joining server" aber nix passiert. Das Problem tritt nur auf, wenn Origin mittels firewall geblockt wird, ohne blocken funktionierts ganz normal. Hat noch jemand das Problem?
wozu noch blocken? laut c't ist doch keine Spionagegefahr von Origin zu befürchten..
Aber das hat ja nichts mit dem firewall block zu tun, wenn die server erst gepatched werden müssen, dann könnte ich theoretisch auch nicht ohne firewall block joinen, aber das geht in meinem fall(beim gleichem server)
deswegen änderte ich den text ;)
trotzdem hab ich keine freude mit origin.. hättest du mal einen link parat zu deinem vorletzten post?
nicht noch einer :lol:
habs schon selbst gefunden, ist ja erst von heute dieser bericht! ;)
Status
