pttvox.py:25: DeprecationWarning: This function is deprecated. Please use the named parameter
format to
PCM() instead
audio.setformat(alsaaudio.PCM_FORMAT_S16_LE)
/home/480/Programme/Linux/PTT/./ts3_pttvox.py:26: DeprecationWarning: This function is deprecated. Please use the named parameter
periodsize to
PCM() instead
audio.setperiodsize(160)
/home/480/Programme/Linux/PTT/./ts3_pttvox.py:27: DeprecationWarning: This function is deprecated. Please use the named parameter
channels to
PCM() instead
audio.setchannels(1)
/home/480/Programme/Linux/PTT/./ts3_pttvox.py:28: DeprecationWarning: This function is deprecated. Please use the named parameter
rate to
PCM() instead
audio.setrate(8000)
ALSA lib confmisc.c:855
parse_card) cannot find card '0'
ALSA lib conf.c:5178
_snd_config_evaluate) function snd_func_card_inum returned error: No such file or directory
ALSA lib confmisc.c:422
snd_func_concat) error evaluating strings
_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
ALSA lib confmisc.c:1334
snd_func_refer) error evaluating name
_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5701
snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2664
snd_pcm_open_noupdate) Unknown PCM sysdefault
ALSA lib pcm.c:2664
ALSA lib pcm.c:2664
snd_pcm_open_noupdate) Unknown PCM front
ALSA lib pcm.c:2664
snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2664
snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2664
snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2664
snd_pcm_open_noupdate) Unknown PCM surround21
ALSA lib pcm.c:2664
ALSA lib pcm.c:2664
snd_pcm_open_noupdate) Unknown PCM surround40
ALSA lib pcm.c:2664
snd_pcm_open_noupdate) Unknown PCM surround41
ALSA lib pcm.c:2664
snd_pcm_open_noupdate) Unknown PCM surround50
ALSA lib pcm.c:2664
snd_pcm_open_noupdate) Unknown PCM surround51
ALSA lib pcm.c:2664
snd_pcm_open_noupdate) Unknown PCM surround71
ALSA lib pcm.c:2664
snd_pcm_open_noupdate) Unknown PCM iec958
ALSA lib pcm.c:2664
snd_pcm_open_noupdate) Unknown PCM spdif
ALSA lib pcm.c:2664
ALSA lib pcm.c:2664
snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2664
ALSA lib pcm.c:2664
snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2664
ALSA lib pcm.c:2664
snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib pcm.c:2664
ALSA lib confmisc.c:165
snd_config_get_card) Cannot get card index for 0
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
ALSA lib pcm_oss.c:397
_snd_pcm_oss_open) Cannot open device /dev/dsp
ALSA lib confmisc.c:160
snd_config_get_card) Invalid field card
ALSA lib pcm_usb_stream.c:482
_snd_pcm_usb_stream_open) Invalid card 'card'
_snd_config_evaluate) function snd_func_card_id returned error: No such file or directory
ALSA lib pcm.c:2664
snd_pcm_open_noupdate) Unknown PCM dmix
ALSA lib pcm.c:2664
ALSA lib pcm.c:2664
ALSA lib pcm.c:2664
ALSA lib pcm.c:2664
ALSA lib pcm.c:2664
ALSA lib pcm.c:2664
ALSA lib pcm.c:2664
ALSA lib pcm.c:2664
ALSA lib pcm.c:2664
ALSA lib pcm.c:2664
ALSA lib pcm.c:2664
ALSA lib pcm.c:2664
ALSA lib pcm.c:2664
ALSA lib pcm.c:2664
ALSA lib pcm.c:2664
ALSA lib pcm.c:2664
ALSA lib pcm.c:2664
ALSA lib pcm.c:2664
ALSA lib pcm.c:2664
ALSA lib pcm.c:2664
ALSA lib pcm.c:2664
python: src/common/pa_front.c:235: InitializeHostApis: Assertion `hostApi->info.defaultInputDevice < hostApi->info.deviceCount' failed.
ALSA lib pcm.c:2664
snd_pcm_open_noupdate) Unknown PCM cards.pcm.phonelineAbgebrochen (Speicherabzug geschrieben)
