Samba automatische Passwort synchronisation
counterroot
Feb. 2005
hiho!
Ich will dass Samba beim Anlegen eines Benutzers unter Suse, automatisch das gleiche passwort für den Samba account nimmt...
meine smb.conf:
Code:
# smb.conf is the main Samba configuration file. You find a full commented
# version at /usr/share/doc/packages/samba/examples/smb.conf.SuSE
# Date: 2003-09-23
[global]
   workgroup = WORKGROUP
   os level = 2
   time server = Yes
   unix extensions = Yes
   encrypt passwords = yes
   map to guest = Bad User
   printing = CUPS
   printcap name = CUPS
   socket options = SO_KEEPALIVE IPTOS_LOWDELAY TCP_NODELAY
   wins support = No
   veto files = /*.eml/*.nws/riched20.dll/*.{*}/
   security = user
   server string = Samba LinuxServer
   add user script =
   domain master = false
   domain logons = no
   local master = no
   preferred master = auto
   unix password sync = true
;;   ldap server = 127.0.0.1
[homes]
   comment = Home Directories
   valid users = %S
   browseable = no
   read only = No
   create mask = 0640
   directory mask = 0750
   guest ok = no
   printable = no
[printers]
   comment = All Printers
   path = /var/tmp
   printable = yes
   create mask = 0600
   browseable = no
   guest ok = no
[print$]
   comment = Printer Drivers
   path = /var/lib/samba/drivers
   write list = @ntadmin root
   force group = ntadmin
   create mask = 0664
   directory mask = 0775
   browseable = yes
   guest ok = no
   printable = no
[exchange]
   comment = Files for exchange
   path = /exchange/
   browseable = yes
   guest ok = yes
   readonly = No
   create mask = 0640
   printable = no
"unix password sync = true" sollte normalerweise diese funktion übernehmen
was mach ich falsch?
pmb µatze
