Thomson TWG850-4u Ersatz?
Flip89
Dez. 2010
Hey Leute,
wie im Betreff schon geschrieben suche ich einen Ersatz für mein Thomson TWG850-4u. Da ich eine Internetverbindung von 35 mbit/s habe, über das Wlan (kabel verlegen geht leider auf Dauer nicht wirklich) aber meistens nur ca 20 mbit/s schaffe. Ich hab auch immer wieder Lag bei 1080p Streams.
Weiters benutze ich einen Wlan-Stick mit dem Wlan Standard 802.11n.
Im Event Log scheint immer folgendes auf
Sat Mar 09 14:41:48 2013 Notice (6) TLV-11 - unrecognized OID
Sat Mar 09 14:41:47 2013 Critical (3) DHCP WARNING - Non-critical field invalid in response.
Thu Mar 07 07:33:41 2013 Critical (3) Started Unicast Maintenance Ranging - No Response received - ...
Thu Mar 07 07:05:12 2013 Critical (3) DHCP WARNING - Non-critical field invalid in response.
Fri Jan 25 00:15:10 2013 Critical (3) REG RSP not received
Fri Jan 25 00:15:05 2013 Critical (3) DHCP WARNING - Non-critical field invalid in response.
Fri Jan 25 00:14:56 2013 Critical (3) No Ranging Response received - T3 time-out
Fri Jan 25 00:12:27 2013 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC f...
Fri Jan 25 00:00:59 2013 Critical (3) Received Response to Broadcast Maintenance Request, But no Un...
Thu Jan 24 22:04:52 2013 Critical (3) DHCP WARNING - Non-critical field invalid in response.
Tue Jan 15 14:08:11 2013 Critical (3) Started Unicast Maintenance Ranging - No Response received - ...
Tue Jan 15 11:05:25 2013 Critical (3) DHCP WARNING - Non-critical field invalid in response.
Time Not Established Critical (3) Received Response to Broadcast Maintenance Request, But no Un...
Time Not Established Critical (3) Started Unicast Maintenance Ranging - No Response received - ...
Time Not Established Critical (3) No Ranging Response received - T3 time-out
Sat Oct 20 23:06:18 2012 Critical (3) DHCP WARNING - Non-critical field invalid in response.
Wed Sep 12 17:06:46 2012 Critical (3) DHCP WARNING - Non-critical field invalid in response.
Wed Jul 11 01:29:06 2012 Critical (3) Received Response to Broadcast Maintenance Request, But no Un...
Tue Jul 10 20:52:35 2012 Critical (3) Started Unicast Maintenance Ranging - No Response received - ...
Tue Jul 10 18:29:15 2012 Critical (3) DHCP WARNING - Non-critical field invalid in response.
Sun Jun 10 17:07:16 2012 Critical (3) Started Unicast Maintenance Ranging - No Response received - ...
Sun Jun 10 16:22:05 2012 Critical (3) DHCP WARNING - Non-critical field invalid in response.
Mon Jun 04 19:37:42 2012 Critical (3) Started Unicast Maintenance Ranging - No Response received - ...
Mon Jun 04 18:17:08 2012 Critical (3) DHCP WARNING - Non-critical field invalid in response.
Fri Jan 25 00:12:35 2013 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/Q...
Tue May 15 20:16:14 2012 Critical (3) Started Unicast Maintenance Ranging - No Response received - ...
Mon May 14 14:46:17 2012 Critical (3) DHCP WARNING - Non-critical field invalid in response.
Sun May 06 16:55:14 2012 Critical (3) Started Unicast Maintenance Ranging - No Response received - ...
Sun May 06 10:12:47 2012 Critical (3) DHCP WARNING - Non-critical field invalid in response.
Sun Apr 29 11:20:20 2012 Critical (3) DHCP WARNING - Non-critical field invalid in response.
Ich weiß leider nicht, ob all die Meldungen aufs Wlan bezogen sind, da ich versuchsweise den Pc 1-2 Tage per Lankabel verbunden hatte (damit lief alles Top),
Da ich jetzt gesehen habe, dass der Thomson nur den Wlan Standard 802.11g unterstütz, dachte ich mir, es könnte evtl. daran liegen. Daher wollte ich mir jz einen neuen Router? zuzulegen. Ich hab schon versucht zu verstehen was der Unterschied zwischen Router, Modem und Gateway ist, bin mir aber nicht sicher was mein Thomson ist, da er bei Google immer wieder unterschiedlich bezeichnet wird.
Da ich mir demnächst evtl. eine 100 mbit/s Leitung zulegen werde, wollte ich direkt zu einem Router? + Wlan Stick mit Standard 802.11ac greifen.
Leider weiß ich jetzt nicht ob ich einen Router, Modem bzw Gateway brauche. Daher kann ich jetzt (noch) keine Vorschläge machen was ich mir kaufen wollte. Ich würde nur ungern noch ein 2. Gerät zusätzlich zum Thomson betreiben.
Daher bitte ich um eure Hilfe. Vielleicht liegt das Problem ja ganz wo anders und ich kann mir den Kauf ersparen. Ich hoffe nur das ist jetzt alles nicht zu verwirrend formuliert, ich bin selbst etwas verwirrt ;)
Danke,
lg Flip
Der Thomson ist ein Docsis 2 Modem, kann wohl auch nur so um die 50MBit/s. Ich denke, bei einem 100MBit Upgrade bekommst du ein anderes.
Ansonsten ist WLAN extrem abhängig von der Entfernung und den "Zwischenwänden". Wenn du nicht alzu weit weg bist, kannst du dir das mal angucken: FRITZ!Box 6360 Cable
Ob es ac fähiges Gerät auf den Markt gibt, weiß ich nicht. Eventuell wäre dann ein TOP WLAN Router doch die bessere Wahl.
Hey Miac, erst mal danke für die Rückmeldung. Jetzt bin ich leider noch verwirrter *gg*
Ich hab also ein Modem, wieso sollte ich dann einen Router kaufen? Und wieso steht im Manual "Gateway"
Mögliche Router mit 802.11ac gibts ja unter https://www.computerbase.de/forum/t...chweitenerhoehung.595362/page-7#post-12663413 einige aufgelistet. Aber fehlt mir dann nicht das Modem?
Da ich Upc Kunde bin, und die mir dieses Uralt Modem/Router zu meinem 35mbit/s Vertrag dazugegeben haben, vertraue ich leider nicht wirklich darauf, dass ich bei einer Umstellung auf 100mbit/s ein vernünftiges Wlan-Modem/Router bekomme.
Distanz vom Thomson zu meinem PC ist sehr gering, viell 1-2 meter. Auch keine Mauer dazwischen. Es steht nur ein 2. Pc dazwischen. Ich habe auch schon versucht meinen PC mit Wlan Stick direkt neben den Thomson zu stellen, trotzdem nur 20mbit/s.
Das Modem muß Du auf jeden Fall haben, wenn das neue Gerät kein Kabelmodem mitbringt.
Dein Anbieter hat dir nun ein Kombigerät Modem/Router mitgeliefert. dieser Thompson hat einen 100MBit Lan Port. Den kannst Du nun an einen weiteren WLAN Router (ohne Modem) hängen, wenn Du unbedingt eine höhere WLAN Geschwindigkeit benötigt. Untereinander könne dann die WLAN Geräte mit höhere Geschwindigkeit kommunizieren und auch die 35 MBit Download aus dem Internet sollten problemlos gehen.
Wenn Du auf 100MBit aufrüstest, wirst Du auf jeden Fall ein neues Modem bekommen, welches Docsis 3.0 fähig ist, denn sonst kannst Du die Datenrate nicht nutzen. Gleichzeitig sollte das neue Modem mindestens einen GBit Port haben.
Ah jetzt versteh ich es, danke :)
Also entweder mein Router (inkl. Modem) + neuen Router (ohne Modem) oder ich such einen neuen Router (inkl. Modem).
Na mal schaun was UPC mir da für ein Wlan Router + Modem bringen wird, habe mal angefragt, werd das hier dann Bekanntgeben.
