C
conspectumortis
Selbst ist der Mann (man kanns ja mal versuchen):
Warning: Serious problems might occur if you modify the registry incorrectly by using Registry Editor or by using another method. These problems might require that you reinstall your operating system. Microsoft cannot guarantee that these problems can be solved. Modify the registry at your own risk. To resolve this problem, add the EnIdleEndpointSupport entry to the USB registry key. To do this, follow these steps:
1. Click Start, click Run, type regedit, and then click OK.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\USB
Note: If the USB subkey does not exist, create it. To do this, follow these steps:
a. Select the Services key. On the Edit menu, point to New, and then click Key.
b. Type USB in the New Key #1 box to name the new key "USB."
3. Right-click USB, point to New, and then click DWORD Value.
4. In the New Value #1 box that appears, type EnIdleEndpointSupport, and then press ENTER.
5. Right-click EnIdleEndpointSupport, and then click Modify.
6. In the Value data box, type 1, leave the Hexadecimal option selected, and then click OK.
7. Quit Registry Editor.
Resultat (usb 2.0 aktiv):
Aber da das Asus A6JA eine integrierte Kamera hat und diese über usb 2.0 die ganze Zeit connected ist ...
"Adding an external USB 2.0 device to either ASUS notebook does result in an additional drop in battery life, but the initial damage is done by the integrated camera that you can't unplug. To truly isolate this problem, we'll need two notebooks that don't have any integrated USB 2.0 devices, which is why we turned to the Lenovo Thinkpad T43 and T60."
Quelle: anandtech.com
P.S: Es geht mur um USB 2.0 nicht um USB 1.0/1.1 Geräte. (aber natürlich auch um den Ruhestand)
Ausserdem sieht man das es auch bei Sonoma Plattform was bringt und nicht nur an der Napa Plattform:
So far, it is looking like this is not a Core Duo problem and indeed a problem that affects all Intel systems at least.
Wollts hier nur mal extra posten ,weil es sonst untergeht.
Ihr könnt es mal testen,have fun.
€dit: Thread kann dich gemacht werden,war wohl zu lahm und hab den anderen Thread übersehen sorry ^^
