[XHTML] Validierungsproblem
MarcDK
Banned
Mai 2001
Code:
 <?xml version="1.0" encoding="iso-8859-1" ?>
 <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
 <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
 <head>
 <link rel="stylesheet" href="style.css" type="text/css" />
 <meta http-equiv="content-type" content="text/html; charset=iso-8859-1" />
 <title>pixer gallery</title>
 </head>
 <body>
 <h1><a href="index.php"></a></h1>
 <div id="gallery">
 <a href="?path=">Gallery</a>
/<a href="?path=rock">rock</a>
 /<br /><a href="index.php?path=rock&amp;img=img_0007.JPG">&lt; &lt; (previous)</a>&nbsp;&nbsp;img_0008 (9/121)&nbsp;&nbsp;<a href="index.php?path=rock&amp;img=img_0009.JPG">(next) &gt; &gt;</a><br /><a href="index.php?path=rock&amp;img=img_0009.JPG"><img src="rock/img_0008.JPG" alt="img_0008.JPG - large - click to jump to the next picture!" /><br /><a href="index.php?path=rock&amp;img=img_0007.JPG">&lt; &lt; (previous)</a>&nbsp;&nbsp;img_0008 (9/121)&nbsp;&nbsp;<a href="index.php?path=rock&amp;img=img_0009.JPG">(next) &gt; &gt;</a><br /></a><form method="post" action="">Kommentare:<br /><input type="hidden" name="path" value="rock" /><input type="hidden" name="img" value="img_0008.JPG" /><input type="hidden" name="text" value="" /><input type="text" size="60" name="addcomment" /><input type="submit" value="add" /></form><table><tr><td></td></tr></table></div><div id="bottom">copyright © 2003 <a href="http://www.toensing.com">www.toensing.com</a></div>
 </body></html>
Hi! Er meckert beim validieren und zwar so:
Line 15, column 401: document type does not allow element "a" here; missing one of "object", "span", "bdo", "applet", "iframe", "tt", "i", "b", "u", "s", "strike", "big", "small", "font", "em", "strong", "dfn", "code", "q", "samp", "kbd", "var", "cite", "abbr", "acronym", "sub", "sup", "label", "ins", "del" start-tag
...x.php?path=rock&amp;img=img_0007.JPG">&lt; &lt; (previous)</a>&nbsp;&nbsp;img
Also das ist ja im prinzip im <a>-Tag die "href"-value die er anmeckert weil da so viele Variablen übergeben werden und das mag XHTML wohl nicht.
Wie kann man das umgehen?
Re: XHTML & php Variablenübergabe-Problem
MarcDK schrieb:
{code}
Öhm... wie wäre es wenn du deinen Code mal vernünftig strukturierst?
Dann sähe das so aus:
HTML:
So, jetzt schaus dir nochmal selber an, der Fehler ist extrem billig.
Oder seit wann benutzt man <a href="page1">text <a href="page2">mehr text</a></a>
ok, dankeschön! Ich hatte wohl vergessen, die <a>-Tags zu zumachen =)
Du hast btw den Sinn des ALT-Attributs nicht verstanden...
Der ALTernativ wird ANSTELLE des Bildes angezeigt.
Was du suchst ist TITLE=
Sag mal, ich glaube du spinnst. Bin ich jetzt dein privater Validatorservice oder was?
Ne, sie validieren ja.
Es hätte ja sein können, dass Dir Sachen auffallen, die Du vielleicht anders machen würdest.
Valideren kann ich ja selber. =)
The Prophet schrieb:
Danke für die Hilfe. =)
Ja, wenn es fertig ist. Es macht sogar die Watermarks drauf! =)
Gut dann meld ich schonmal interesse an :) Irgendwann brauch sowas auch mal!
Ok, sorry, ich bin es bloss gewohnt, dass die Leute immer andere ihre Arbeit machen lassen wollen...
Und wenn dann zum 87. Mal am Tag jemand in dem Programmierforum wo ich FB bin eine Anfrage nach kostenlosem Webspace postet, obwohl es da dick und fett einen Sammelthread gibt, auf den sogar sowohl in den Regeln als auch in der FAQ verwiesen ist, trägt das auch nicht sonderlich zum heben der Stimmung bei...
In dem Sinne nochmal:
Tut mir leid.
Btw: Wenn er validiert ist doch alles ok? Dein <a><a></a></a> von vorhin sollte schon einen Validierungsfehler erzeugen...
Das hatte ich ja auf dein Anraten gefixt. =)
