18 WoS [mem] unable to get an empty memory block...
Neuling95
Jan. 2013
Hallo wollte gerad bisschen die alten zeiten genießen in 18 Wheels of Steel , dann werde ich nach zirka 30 Minuten fahrt rausgeworfen ....
******** : log created on : Saturday June 08 2013 @ 09:01:39
09:01:39 : [sys] running on x86 / Unknown (version 6.1) / Service Pack 1
09:01:39 : [sys] DirectX version : 4.09.00.0904
09:01:39 : [cpu] GenuineIntel [ Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz] at ~3403MHz.
09:01:39 : [cpu] Features utilized: fpu cmov mmx sse sse2.
09:01:39 : [mm] physical memory detected (4194303K/4194303K)
09:01:39 : [mm] virtual memory detected (2097024K/2032572K)
09:01:39 : [mm] Trying to allocate memory pool (153600K)
09:01:39 : [zipfs] Unsupported compression method used: 8 for record #10489 - vehicle/truck/truck_storage.sii, from file 'base.scs'.
09:01:39 : [zipfs] base.scs successfully mounted [crc_0x7ff6a077]
09:01:39 : [zipfs] patch.scs successfully mounted [crc_0xce8d3250]
09:01:39 : [game] 18 WoS Haulin init ver.1.06 (rev. 19698)
09:01:39 : Home directory: 'C:/Users/Peters/Documents/18 WoS Haulin'
09:01:39 : exec /home/config.cfg
09:01:39 : [cor] executing /home/config.cfg
09:01:39 : uset g_minicon "0"
09:01:39 : uset g_console "1"
09:01:39 : uset g_trackir "1"
09:01:39 : uset g_developer "1"
09:01:39 : uset g_steering_func_param "0.16"
09:01:39 : uset g_joy_axis_brake_dz "0.0"
09:01:39 : uset g_joy_axis_brake "5"
09:01:39 : uset g_joy_ff_gain "0.14"
09:01:39 : uset g_joy_axis_throttle_dz "0.0"
09:01:39 : uset g_joy_axis_throttle "2"
09:01:39 : uset g_joy_axis_ff "1"
09:01:39 : uset g_joy_axis_combine "0"
09:01:39 : uset g_joy_axis_steer_sens "0"
09:01:39 : uset g_joy_axis_steer_dz "0.0"
09:01:39 : uset g_joy_axis_steer "0"
09:01:39 : uset g_fatigue "0"
09:01:39 : uset g_police "0"
09:01:39 : uset g_subtitles "0"
09:01:39 : uset g_clock_24 "1"
09:01:39 : uset g_quality "2"
09:01:39 : uset g_reflection "1"
09:01:39 : uset g_mph "0"
09:01:39 : uset g_show_map "1"
09:01:39 : uset g_points "0.0"
09:01:39 : uset g_atrans "1"
09:01:39 : uset g_flyspeed "10.0"
09:01:39 : uset g_lang "en"
09:01:39 : uset g_colbox "0"
09:01:39 : uset g_texture_usage_stats "0"
09:01:39 : uset g_fps "0"
09:01:39 : uset r_gamma "1.12"
09:01:39 : uset r_path "5"
09:01:39 : uset r_fullscreen "0"
09:01:39 : uset r_mode "640x480x32x0"
09:01:39 : uset r_device "gl"
09:01:39 : uset r_driver "gl"
09:01:39 : uset ds8_mix_channels "2"
09:01:39 : uset ds8_mix_depth "16"
09:01:39 : uset ds8_mix_rate "44100"
09:01:39 : uset ds8_reverse_stereo "0"
09:01:39 : uset s_acceleration "1"
09:01:39 : uset s_mix_channels "2"
09:01:39 : uset s_mix_depth "16"
09:01:39 : uset s_mix_rate "44100"
09:01:39 : uset s_sfx_enabled "1"
09:01:39 : uset s_music_enabled "1"
09:01:39 : uset s_sfx_volume "1.0"
09:01:39 : uset s_music_volume "1.0"
09:01:39 : uset s_reverse_stereo "0"
09:01:39 : uset s_device "ds8"
09:01:39 : uset r_quirks "0"
09:01:39 : uset r_anisotropy_factor "0.5"
09:01:39 : uset r_texture_detail "0"
09:01:39 : uset i_force_gain "1.0"
09:01:39 : uset i_feedback "1"
09:01:39 : uset i_joystick2 "-1"
09:01:39 : uset i_joystick1 "0"
09:01:39 : uset i_deadzone "0.0"
09:01:39 : uset i_device "di8"
09:01:39 : uset m_invert "0"
09:01:39 : uset m_sensitivity "0.33"
09:01:39 : uset m_filter "0"
09:01:39 : uset g_view_dist "1.0"
09:01:39 : [gl] driver: GeForce GTX 670/PCIe/SSE2
09:01:39 : [gl] vendor: NVIDIA Corporation
09:01:39 : [gl] version: 4.3.0
09:01:39 : [gl] GL extensions: GL_AMD_multi_draw_indirect GL_AMD_seamless_cubemap_per_texture GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_clear_buffer_object GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_compute_shader GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_indirect GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counters GL_ARB_shader_bit_encoding GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_image_load_store GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_debug GL_KTX_buffer_region GL_NV_bindless_texture GL_NV_blend_square GL_NV_compute_program5 GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_draw_texture GL_NV_ES1_1_compatibility GL_NV_explicit_multisample GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_gpu_program4_1 GL_NV_gpu_program5 GL_NV_gpu_program5_mem_extended GL_NV_gpu_program_fp64 GL_NV_gpu_shader5 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_atomic_counters GL_NV_shader_atomic_float GL_NV_shader_buffer_load GL_NV_shader_storage_buffer_object GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_attrib_integer_64bit GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
09:01:39 : [gl] GL_max_texture_size: 16384
09:01:39 : [gl] taking advantage of 'GL_ARB_fragment_program'
09:01:39 : [gl] taking advantage of 'GL_ARB_texture_mirrored_repeat'
09:01:39 : [gl] taking advantage of 'GL_ARB_multitexture'
09:01:39 : [gl] sampler count 4
09:01:39 : [gl] taking advantage of 'GL_ARB_texture_border_clamp'
09:01:39 : [gl] taking advantage of 'GL_ARB_texture_compression'
09:01:39 : [gl] taking advantage of 'GL_EXT_texture_compression_s3tc'
09:01:39 : [gl] taking advantage of 'GL_ARB_texture_cube_map'
09:01:39 : [gl] taking advantage of 'GL_ARB_texture_env_crossbar'
09:01:39 : [gl] taking advantage of 'GL_ARB_texture_env_combine'
09:01:39 : [gl] taking advantage of 'GL_ARB_texture_rectangle'
09:01:39 : [gl] taking advantage of 'GL_ARB_transpose_matrix'
09:01:39 : [gl] taking advantage of 'GL_ARB_vertex_buffer_object'
09:01:39 : [gl] taking advantage of 'GL_ARB_vertex_program'
09:01:39 : [gl] taking advantage of 'GL_ARB_shader_objects'
09:01:39 : [gl] taking advantage of 'GL_ARB_vertex_shader'
09:01:39 : [gl] taking advantage of 'GL_ARB_fragment_shader'
09:01:39 : [gl] taking advantage of 'GL_ATI_draw_buffers'
09:01:39 : [gl] taking advantage of 'GL_EXT_blend_color'
09:01:39 : [gl] taking advantage of 'GL_EXT_compiled_vertex_array'
09:01:39 : [gl] taking advantage of 'GL_EXT_draw_range_elements'
09:01:39 : [gl] taking advantage of 'GL_EXT_rescale_normal'
09:01:39 : [gl] taking advantage of 'GL_EXT_secondary_color'
09:01:39 : [gl] taking advantage of 'GL_EXT_separate_specular_color'
09:01:39 : [gl] taking advantage of 'GL_EXT_texture3D'
09:01:39 : [gl] taking advantage of 'GL_EXT_texture_edge_clamp'
09:01:39 : [gl] taking advantage of 'GL_EXT_texture_env_add'
09:01:39 : [gl] max anisotropy factor : 16
09:01:39 : [gl] taking advantage of 'GL_EXT_texture_filter_anisotropic'
09:01:39 : [gl] taking advantage of 'GL_NV_register_combiners'
09:01:39 : [gl] taking advantage of 'GL_NV_register_combiners2'
09:01:39 : [gl] taking advantage of 'GL_NV_texture_env_combine4'
09:01:39 : [gl] taking advantage of 'GL_NV_texture_shader'
09:01:39 : [gl] taking advantage of 'GL_NV_texture_shader2'
09:01:39 : [gl] taking advantage of 'GL_NV_texture_shader3'
09:01:39 : [gl] taking advantage of 'GL_NV_fragment_program'
09:01:39 : [gl] taking advantage of 'GL_NV_fragment_program_option'
09:01:39 : [gl] taking advantage of 'GL_NV_fragment_program2'
09:01:39 : [gl] taking advantage of 'GL_NV_vertex_program'
09:01:39 : [gl] taking advantage of 'GL_NV_vertex_program2'
09:01:39 : [gl] taking advantage of 'GL_NV_vertex_program2_option'
09:01:39 : [gl] taking advantage of 'GL_NV_vertex_program3'
09:01:39 : [gl] taking advantage of 'GL_SGIS_generate_mipmap'
09:01:39 : [gl] taking advantage of 'WGL_ARB_extensions_string'
09:01:39 : [gl] WGL_extensions: WGL_ARB_buffer_region WGL_ARB_create_context WGL_ARB_create_context_profile WGL_ARB_create_context_robustness WGL_ARB_extensions_string WGL_ARB_make_current_read WGL_ARB_multisample WGL_ARB_pbuffer WGL_ARB_pixel_format WGL_ARB_pixel_format_float WGL_ARB_render_texture WGL_ATI_pixel_format_float WGL_EXT_create_context_es_profile WGL_EXT_create_context_es2_profile WGL_EXT_extensions_string WGL_EXT_framebuffer_sRGB WGL_EXT_pixel_format_packed_float WGL_EXT_swap_control WGL_EXT_swap_control_tear WGL_NVX_DX_interop WGL_NV_DX_interop WGL_NV_DX_interop2 WGL_NV_float_buffer WGL_NV_multisample_coverage WGL_NV_render_depth_texture WGL_NV_render_texture_rectangle
09:01:39 : [gl] taking advantage of 'WGL_ARB_pixel_format'
09:01:39 : [gl] taking advantage of 'WGL_ARB_pbuffer'
09:01:39 : [gl] taking advantage of 'WGL_ARB_render_texture'
09:01:39 : [gl] taking advantage of 'WGL_NV_render_texture_rectangle'
09:01:39 : [gl-quirk] Enabling workaround for alpha-testing overoptimization.
09:01:39 : [gl] SetPixelFormat: OK
09:01:39 : [gl] wglCreateContext: OK
09:01:39 : [gl] OpenGL framebuffer context init OK
09:01:39 : [snd] select device (ds8)
09:01:39 : [ds8] Available device : Primärer Soundtreiber ().
09:01:39 : [ds8] Available device : Lautsprecher (VIA High Definition Audio) ({0.0.0.00000000}.{864c00f1-cf6f-4ef3-a40f-368f17f24d9c}).
09:01:39 : [ds8] Available device : SPDIF Interface (TX1) (VIA High Definition Audio) ({0.0.0.00000000}.{42131b38-779d-4720-b6d9-4bc461233264}).
09:01:39 : [ds8] Available device : SPDIF Interface (TX0) (VIA High Definition Audio) ({0.0.0.00000000}.{c88019e1-af1e-45f9-86ce-787f7254f886}).
09:01:39 : [ds8] Initialization OK.
09:01:39 : [game] Trying to mount MOD archive: C:/Users/Peters/Documents/18 WoS Haulin/mod/flarepack_by_Samson.scs
09:01:39 : [zipfs] C:/Users/Peters/Documents/18 WoS Haulin/mod/flarepack_by_Samson.scs successfully mounted [crc_0x9bf0264c]
09:01:39 : [game] Trying to mount MOD archive: C:/Users/Peters/Documents/18 WoS Haulin/mod/Miekkie zawieszenie ( Physics mod ).scs
09:01:39 : [fs] file open failed! (C:/Users/Peters/Documents/18 WoS Haulin/mod/Miekkie zawieszenie ( Physics mod ).scs:0)
09:01:39 : UFS: error creating device!
09:01:39 : [game] Trying to mount MOD archive: C:/Users/Peters/Documents/18 WoS Haulin/mod/MP 1.0 Def.scs
09:01:39 : [zipfs] C:/Users/Peters/Documents/18 WoS Haulin/mod/MP 1.0 Def.scs successfully mounted [crc_0x698ac49]
09:01:39 : [game] Trying to mount MOD archive: C:/Users/Peters/Documents/18 WoS Haulin/mod/MP 1.0 Map.scs
09:01:39 : [zipfs] C:/Users/Peters/Documents/18 WoS Haulin/mod/MP 1.0 Map.scs successfully mounted [crc_0x46c4ff8f]
09:01:39 : [game] Trying to mount MOD archive: C:/Users/Peters/Documents/18 WoS Haulin/mod/MP 1.0 Model.scs
09:01:39 : [zipfs] C:/Users/Peters/Documents/18 WoS Haulin/mod/MP 1.0 Model.scs successfully mounted [crc_0xc7f80bcf]
09:01:39 : [game] Trying to mount MOD archive: C:/Users/Peters/Documents/18 WoS Haulin/mod/MP 1.0 Other.scs
09:01:39 : [zipfs] C:/Users/Peters/Documents/18 WoS Haulin/mod/MP 1.0 Other.scs successfully mounted [crc_0x9aeae425]
09:01:39 : [game] Trying to mount MOD archive: C:/Users/Peters/Documents/18 WoS Haulin/mod/MP 1.0 Signs.scs
09:01:39 : [zipfs] C:/Users/Peters/Documents/18 WoS Haulin/mod/MP 1.0 Signs.scs successfully mounted [crc_0x6f45ed17]
09:01:39 : [game] Trying to mount MOD archive: C:/Users/Peters/Documents/18 WoS Haulin/mod/pete379jp_other_clear_glass.scs
09:01:39 : [zipfs] C:/Users/Peters/Documents/18 WoS Haulin/mod/pete379jp_other_clear_glass.scs successfully mounted [crc_0xd2248c0b]
09:01:39 : [game] Trying to mount MOD archive: C:/Users/Peters/Documents/18 WoS Haulin/mod/Renault.Premium_TZ (vehicle).scs
09:01:39 : [zipfs] C:/Users/Peters/Documents/18 WoS Haulin/mod/Renault.Premium_TZ (vehicle).scs successfully mounted [crc_0x2475f80d]
09:01:39 : [game] Trying to mount MOD archive: C:/Users/Peters/Documents/18 WoS Haulin/mod/TEKSTUR MOD 0.6.scs
09:01:39 : [zipfs] C:/Users/Peters/Documents/18 WoS Haulin/mod/TEKSTUR MOD 0.6.scs successfully mounted [crc_0x2150828]
09:01:39 : [game] Trying to mount MOD archive: C:/Users/Peters/Documents/18 WoS Haulin/mod/Trailer_mod_1.1.scs
09:01:39 : [zipfs] C:/Users/Peters/Documents/18 WoS Haulin/mod/Trailer_mod_1.1.scs successfully mounted [crc_0x36010070]
09:01:39 : [game] Trying to mount MOD archive: C:/Users/Peters/Documents/18 WoS Haulin/mod/TZexpress_interiors.scs
09:01:39 : [zipfs] C:/Users/Peters/Documents/18 WoS Haulin/mod/TZexpress_interiors.scs successfully mounted [crc_0x6082bd04]
09:01:39 : [game] Trying to mount MOD archive: C:/Users/Peters/Documents/18 WoS Haulin/mod/TZ_AI_cars.scs
09:01:39 : [zipfs] C:/Users/Peters/Documents/18 WoS Haulin/mod/TZ_AI_cars.scs successfully mounted [crc_0x1fcac996]
09:01:39 : [game] Trying to mount MOD archive: C:/Users/Peters/Documents/18 WoS Haulin/mod/TZ_express_truck.scs
09:01:39 : [zipfs] C:/Users/Peters/Documents/18 WoS Haulin/mod/TZ_express_truck.scs successfully mounted [crc_0xcbc103d7]
09:01:39 : [game] Trying to mount MOD archive: C:/Users/Peters/Documents/18 WoS Haulin/mod/TZ_truck_storage.scs
09:01:39 : [zipfs] C:/Users/Peters/Documents/18 WoS Haulin/mod/TZ_truck_storage.scs successfully mounted [crc_0x31eb306f]
09:01:39 : [inp] Joystick/GamePad device: \bLogitech MOMO Racing USB
09:01:39 : g_ui_recache
09:01:39 : exit
09:01:40 : Starting physics server: \gOpen Dynamics Engine (svn revision 981)
09:01:47 : Loading city data ....
09:01:59 : map /home/save/1
09:01:59 : Trying to restore game state from (/home/save/1)...
09:01:59 : Starting physics server: \gOpen Dynamics Engine (svn revision 981)
09:01:59 : Loading resource server data ....
09:01:59 : Loading road data ....
09:01:59 : Wrong center styles for road look #90
09:01:59 : Loading terrain data ....
09:01:59 : Loading railing data ....
09:01:59 : Loading building data ....
09:01:59 : Loading model data ....
09:01:59 : Loading prefab data ....
09:01:59 : Loading sign data ....
09:02:00 : Loading traffic light data ....
09:02:00 : Loading city data ....
09:02:00 : Loading vegetation data ....
09:02:00 : Loading particles data ....
09:02:00 : Loading hinges data ....
09:02:00 : Loading stamp data ....
09:02:00 : Loading movers data ....
09:02:12 : Map successfully loaded ....
09:02:24 : g_mode gl gl 1920x1080x32x0 1
09:02:24 : [gl] Context shutdown
09:02:24 : [gl] CDS init: OK
09:02:24 : [gl] SetPixelFormat: OK
09:02:24 : [gl] wglCreateContext: OK
09:02:24 : [gl] OpenGL framebuffer context init OK
09:02:24 : [inp] Joystick/GamePad device: \bLogitech MOMO Racing USB
09:03:33 : screenshot
09:03:33 : Screenshot written: '/screenshot/wos5_00001.png'.
09:03:35 : screenshot
09:03:35 : Screenshot written: '/screenshot/wos5_00002.png'.
09:06:46 : screenshot
09:06:46 : Screenshot written: '/screenshot/wos5_00003.png'.
09:08:12 : screenshot
09:08:12 : Screenshot written: '/screenshot/wos5_00004.png'.
09:08:26 : screenshot
09:08:26 : Screenshot written: '/screenshot/wos5_00005.png'.
09:12:38 : screenshot
09:12:38 : Screenshot written: '/screenshot/wos5_00006.png'.
09:12:41 : screenshot
09:12:41 : Screenshot written: '/screenshot/wos5_00007.png'.
09:12:42 : Screenshot written: '/screenshot/wos5_00008.png'.
09:13:51 : .\m_manager.cpp(1105): unknown fn: [mem] unable to get an empty memory block...
Ich meine memory block wäre doch Speicher gewesen... Aber ich verstehe das nicht habe 2GB Grafikkartenspeicher und 8GB RAM sollte doch mehr als ausreichend sein ?
Danke
ps: habe den spoiler button nicht gefunden ^^
mach das in nen spoiler so: [spoiler ]....[/spoiler ] (leerzeichen in den eckigen klammern auslassen!!)
wirst du jetzt immer nach 30 minuten rausgeworfen? oder lässt sich es nicht mehr starten?
Probier mal das als Admin auszuführen oder im xb kompatilitätsmodus zu spielen
Black Friday II Asus
