Hi liebes Forum,
hab ab und an vor dem Start von Windows einen Bluescreen und kann mir net erklären woher das kommt. Hoffe ihr habt ne Lösung für das Problem welches nur bei 30 PC Starts vielleicht 1x Auftritt. Anbei mal die Meldungen die mir der Debugger gegeben hat.
Unternommen hab ich bisher nur n RAM Test und da war alles in Ordnung.
BCCode: c4
BCP1: 0000000000000091
BCP2: 0000000000000002
BCP3: FFFFFA80093C1060
BCP4: 0000000000000000
DRIVER_VERIFIER_DETECTED_VIOLATION (c4)
A device driver attempting to corrupt the system has been caught. This is
because the driver was specified in the registry as being suspect (by the
administrator) and the kernel has enabled substantial checking of this driver.
If the driver attempts to corrupt the system, bugchecks 0xC4, 0xC1 and 0xA will
be among the most commonly seen crashes.
Arguments:
Arg1: 0000000000000091, A driver switched stacks using a method that is not supported by
the operating system. The only supported way to extend a kernel
mode stack is by using KeExpandKernelStackAndCallout.
Arg2: 0000000000000002
Arg3: fffffa80093c1060
Arg4: 0000000000000000
Debugging Details:
***** Debugger could not find nt in module list, module list might be corrupt, error 0x80070057.
BUGCHECK_STR: 0xc4_91
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from fffff800034da9ea to fffff800034841c0
STACK_TEXT:
fffff880`0383b548 fffff800`034da9ea : 00000000`000000c4 00000000`00000091 00000000`00000002 fffffa80`093c1060 : 0xfffff800`034841c0
fffff880`0383b550 00000000`000000c4 : 00000000`00000091 00000000`00000002 fffffa80`093c1060 00000000`00000000 : 0xfffff800`034da9ea
fffff880`0383b558 00000000`00000091 : 00000000`00000002 fffffa80`093c1060 00000000`00000000 07032985`07032985 : 0xc4
fffff880`0383b560 00000000`00000002 : fffffa80`093c1060 00000000`00000000 07032985`07032985 07032985`07032985 : 0x91
fffff880`0383b568 fffffa80`093c1060 : 00000000`00000000 07032985`07032985 07032985`07032985 fffff800`034ad843 : 0x2
fffff880`0383b570 00000000`00000000 : 07032985`07032985 07032985`07032985 fffff800`034ad843 07032985`07032985 : 0xfffffa80`093c1060
STACK_COMMAND: kb
SYMBOL_NAME: ANALYSIS_INCONCLUSIVE
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: Unknown_Module
IMAGE_NAME: Unknown_Image
DEBUG_FLR_IMAGE_TIMESTAMP: 0
BUCKET_ID: CORRUPT_MODULELIST
Followup: MachineOwner
Ich habs geschafft.....hab verifier.exe mit allen zu ladenen treibern gestartet und jetzt kommt bei jedem windows start der bluescreen
wenn ich F5 drücke habe ich keine möglichkeit im abgesicherten modus zu starten sondern nur windows 7 und memory irgendwas.....
bitte helft mir in windows zu kommen.....dann leb ich auch mit den bluescreens
BCCode: c4
Arguments:
Debugging Details:
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
