overclocking=
pptp_extraoptions=
hopseq=0
oet2_id=1
eth1_bridged=1
wl0_wme_txp_vo=7 3 4 2 0
pptp_reorder=1
wl0_radius_override=1
ath4_radius_port=1812
dhcp_domain=wan
port4vlans=0
fon_userlist=
sputnik_done=0
vlans=0
samba_mount=0
wl_wep_last=
ath0.2_ssid=
wl_wme_ap_vo=3 7 1 3264 1504 off
wan_gateway_buf=0.0.0.0
ath5_8021xtype=peap
wan_dial=0
warn_connlimit=500
oet6_shaper=0
resetbutton_enable=1
block_cookie=0
wan_vdsl=0
wan_iface=
chilli_dns1=0.0.0.0
rc_firewall=
wl_frameburst=off
ezc_enable=1
ath0_chanshift=0
wd_maclist=
NC_enable=0
wl0_nmode_protection=auto
ath0.3_ipaddr=0.0.0.0
is_modified=1
eth5_bridged=1
ath3_lazywds=0
upnp_wan_proto=
smtp_redirect_destination=0.0.0.0
svqos_port3prio=10
dhcp_num=50
filter_web_url1=
wan_ipaddr=0.0.0.0
oet3_bridged=1
filter_web_url2=
reconnect_hours=0
filter_web_url3=
et0macaddr_safe=00:27:19
A:AD
0
af_country=
oet2_ip=1.2.3.4
wl0_rts=2347
ath1_channelbw=20
filter_web_url4=
ath0_pollingmode=0
tcp_congestion_control=vegas
af_ssid_name=AnchorFree WiFi
wd_sslport=443
ospfd_copt=0
zebra_conf=
filter_web_url5=
fon_enable=0
port2vlans=0
ath1_wpa_gtk_rekey=3600
wl_ifname=
filter_web_url6=
wan_wins=0.0.0.0
oet9_comp=0
ipv6_enable=0
ntp_mode=auto
ath5_radius_port=1812
wl_wep=disabled
http_enable=1
filter_web_url7=
wl0_radauth=0
l2tp_pass=1
filter_web_url8=
oet8_en=0
eth9_bridged=1
sputnik_mode=standard
svqos_ips=
ddns_dyndnstype=
ath1_channel=0
pppoe_username=
filter_web_url9=
os_version=4.150.10.5
oet7_bridged=1
l2tp_use_dhcp=0
ath3_wpa_psk=
wl_gmode_protection=auto
ath5_closed=0
eth4_ipaddr=0.0.0.0
sshd_rsa_host_key=
mac_clone_enable=0
wl0_sta_retry_time=5
ppp_get_srv=
ath0_regdomain=GERMANY
oet1_id=1
wl_frag=2346
ath4_mode=ap
l2tp_req_chap=yes
wan_mtu=1500
wl_wep_gen=
eth1_netmask=0.0.0.0
ath4_wpa_gtk_rekey=3600
filter_macmode=deny
oet1_mssfix=0
wd_httpdname=WiFiDog
svqos_port1prio=10
ppp_compression=0
console_loglevel=7
NC_LoginTimeout=86400
port0vlans=1
sshd_wanport=22
dnsmasq_options=
time_zone=+01
oet7_comp=0
reconnect_minutes=0
ath5_akm=disabled
wan_get_domain=
af_state=
ttraff_enable=1
oet7_mssfix=0
l2tp_req_auth=yes
ath0.3_bridged=1
wan_ifname=
eth5_netmask=0.0.0.0
wl_wme_sta_be=15 1023 3 0 0 off
sshd_authorized_keys=
radvd_enable=0
ath5_xr=0
upnp_max_age=180
squid_proxy_server_port=3128
oet3_netmask=255.255.255.0
oet1_ip=1.2.3.4
hotss_customuam=
wl_radioids=
gozila_action=0
af_ssid=0
wl0_dfs_postism=60
ath2_mode=ap
wan_hostname=
wl_corerev=
af_address=
sv_restore_defaults=0
zebra_enable=1
info_passwd=0
DD_BOARD=TP-Link TL-WR941ND v2/v3
svqos_port3bw=FULL
oet10_comp=0
oet7_en=0
wl_wme_sta_bk=15 1023 7 0 0 off
manual_boot_nv=0
ath3_radius_key=
wl0_bcn=100
ath4_channelbw=20
ath0_wds5_enable=0
pptpd_auth=
ath0_relayd_gw_ipaddr=0.0.0.0
radio0_on_time=111111111111111111111111
macupd_interval=10
block_multicast=1
wl_afterburner=off
wl0_hwaddr=00:27:19
A:AD
0
ppp_static=0
filter_tod1=
dtag_vlan8=0
oet5_comp=0
eth9_netmask=0.0.0.0
log_rejected=0
dyn_default=0
filter_tod2=
oet7_netmask=255.255.255.0
filter_tod3=
oet1_shaper=0
filter_tod4=
ezc_version=2
oet9_rem=192.168.90.1
dnsmasq_no_dns_rebind=1
ddns_passwd_buf=
wk_mode=gateway
wl0_gmode_protection=auto
filter_tod5=
rc_shutdown=
ath0_8021xtype=peap
ath2_radius_ipaddr=
filter_tod6=
ath0_preamble=0
NC_GatewayMode=Open
ath3_akm=disabled
filter_tod7=
wl0_radmacpassword=0
wl_rts=2347
ath0_mode=wet
ath0_bridged=1
filter_tod8=
oet7_shaper=0
filter_tod9=
vlan0hwname=et0
wl_ap_isolate=0
lan_wins=
wd_path=/wifidog
dhcp_dnsmasq=0
NC_IdleTimeout=0
ip_conntrack_udp_timeouts=120
dhcpd_options=
wl_mac_list=
lan_hwnames=
dhcpd_usejffs=0
static_leases=
wl_wme_no_ack=off
wds_watchdog_enable=0
pppoe_demand=0
wd_auth=0
local_dns=0
ath1_auth_mode=disabled
ath4_xr=0
oet3_comp=0
ath5_radius_ipaddr=
ath0.3_netmask=0.0.0.0
filter_dport_grp10=
ath0_nat=1
wl0_wme_ap_be=15 63 3 0 0 off
ddns_username_buf=
ath0_maxrate=0
ath0_outdoor=0
wd_enable=0
wl0_nmcsidx=-1
wl0_lazy_wds=
ath0_closed=0
refresh_time=3
oet6_en=0
pptp_encrypt=0
oet10_en=0
NC_ForcedRedirect=0
ddns_wan_ip=1
oet7_rem=192.168.90.1
wl0_wme_ap_bk=15 1023 7 0 0 off
schedule_hour_time=1
dr_setting=0
upnp_enable=0
ath0_regulatory=1
wl_wme_txp_be=7 3 4 2 0
hs_redirect=
http_redirect_destination=0.0.0.0
eth5_ipaddr=0.0.0.0
ath1_akm=disabled
dhcpc_vendorclass=
wol_hostname=
pptpd_lip=
ath0_ssid=SIEMENS-6EFFE3
filter_rule10=
eth2_bridged=1
forwardspec_entries=0
rflow_if=br0
wl_dfs_preism=60
ath0_lazywds=0
oet1_comp=0
ppp_mlppp=0
wl_wme_txp_bk=7 3 4 2 0
NC_AllowedWebHosts=
def_whwaddr=00:00:00:00:00:00
ath2_radio=1
ath0_ap_isolate=0
oet2_mssfix=0
dhcpc_requestip=
status_auth=1
autofw_port0=
boardnum=0x0
warn_enabled=0
language=english
ath3_8021xtype=peap
ath0_netmask=0.0.0.0
def_hwaddr=00:00:00:00:00:00
oet8_mssfix=0
wl_bcn=100
ath0_scanlist=default
hotss_operatorid=
macupd_enable=0
wl_wep_buf=
wl_reg_mode=off
ath3_xr=0
oet10_mssfix=0
eth6_bridged=1
wd_username=
mmc_enable0=0
oet4_bridged=1
rflow_ip=0.0.0.0
limit_telnet=0
ath0_wpa_psk=
upnp_config=1
filter_dport_grp1=
oet5_rem=192.168.90.1
oet1_fragment=0
pptpd_client_mru=1450
rc_custom=
filter_dport_grp2=
size: 17750 bytes (47786 left)
root@DD-WRT:~#
Ergänzung (26. Januar 2011 )
Kan damit jemand was anfangen?
Weiß jemand ne Lösung? :O
