*.dem* to *.avi* need help...plz
RandomStyle
Cadet 1st Year
Jan. 2002
Ich möchte ein .avi movie machen von einer cs (counterstrike) demo... (.dem - files)
1. gibt es ein program das .dem to .avi umwandelt
2. oder kann ich mit einer screencam .. dieses video fangen ... und dann bearbeiten ...
3. ich blick da nicht ganz durch plz Help...
:mad:
Ich weiß jetzt wie es geht ...
Und so geht´s ...
Here is a guide on how to make Movies in counterstrike.
Making your File
1. In counterstrike you must be in a game. While in the game go into console and type:
"startmovie <movie Name>" or Bind a key like this: "bind <key> startmovie <name>"...
I bind my keys because that way the console will not be in your movie.
If its working you should feel some lag only on your side.
When you feel you have got all you need for that scene of the movie go into console
(as soon as you hit console the movie stops so it will not be in the movie) type "endmovie"
Getting your File
2. Now that you have your desired scene (you can make more if you want) get out of
Counter-strike to your desktop. Now that your on your desktop go to C:/sierra/halflife
or you halflife folder. Right there you should see your file called <movie name>,
it will be in a really wierd format and really large.
Renaming your File
3. To make it work you must rename your file to - <moviename>.hlm it has to have the .hlm
Turning your large .hlm into .avi
4. Get out the software in the package included called HLM2DivX.exe
On the input choose Half-life Movie
Now click load then go into you halflife folder and choose your movie that you renamed with a .hlm
On Output choose DIVX ;-) and AVI
Click Save then save it to your desired folder. Make sure you put .avi after it.
Choose Div ;-) MPEG-4 Fast-Motion
then hit Convert
At the bottom it should say the frames being converted
link to download...
http://students.washington.edu/jvos...vX/HLM2DivX.zip
