NAS
Doom Doom3 Problem
Status
Niven
Feb. 2004
Hallo an alle!
Wollte mal wieder nach langer Zeit Doom3 installieren aber leider kriege ich immer eine Fehlermeldung!
DOOM 1.3.1.1304 win-x86 Jan 16 2007 15:36:51
2405 MHz AMD CPU with MMX & 3DNow! & SSE & SSE2 & SSE3 & HTT
2048 MB System Memory
256 MB Video Memory
Winsock Initialized
Found interface: {5EAF1BF0-ADDB-4C9A-A2AA-22355C3AE896} Atheros AR5008X Wireless Network Adapter - 192.168.178.25/255.255.255.0
Found interface: {BBA3D844-4423-4829-BCCC-5CE3779598A9} Bluetooth-Gerät (PAN) - 0.0.0.0 NULL netmask - skipped
Found interface: {360ADDBD-1EC2-4B1E-97F2-EC9EE56ED5E8} NVIDIA nForce Networking Controller - 0.0.0.0 NULL netmask - skipped
Sys_InitNetworking: adding loopback interface
doom using MMX & SSE & SSE2 & SSE3 for SIMD processing
enabled Flush-To-Zero mode
enabled Denormals-Are-Zero mode
------ Initializing File System ------
Loaded pk4 D:\Spiele\DOOM 3\base\game00.pk4 with checksum 0x29cdb978
Loaded pk4 D:\Spiele\DOOM 3\base\game01.pk4 with checksum 0x51c6981f
Loaded pk4 D:\Spiele\DOOM 3\base\game02.pk4 with checksum 0xf3ec6f7
Loaded pk4 D:\Spiele\DOOM 3\base\game03.pk4 with checksum 0x5d4230ea
Loaded pk4 D:\Spiele\DOOM 3\base\pak000.pk4 with checksum 0x28d208f1
Loaded pk4 D:\Spiele\DOOM 3\base\pak001.pk4 with checksum 0x40244be0
Loaded pk4 D:\Spiele\DOOM 3\base\pak002.pk4 with checksum 0xc51ecdcd
Loaded pk4 D:\Spiele\DOOM 3\base\pak003.pk4 with checksum 0xcd79d028
Loaded pk4 D:\Spiele\DOOM 3\base\pak004.pk4 with checksum 0x765e4f8b
Loaded pk4 D:\Spiele\DOOM 3\base\pak005.pk4 with checksum 0x8ffc3621
Loaded pk4 D:\Spiele\DOOM 3\base\pak006.pk4 with checksum 0x95b65ab
Loaded pk4 D:\Spiele\DOOM 3\base\pak007.pk4 with checksum 0x666bdb3c
Loaded pk4 D:\Spiele\DOOM 3\base\pak008.pk4 with checksum 0x23ae5993
Current search path:
D:\Spiele\DOOM 3/base
D:\Spiele\DOOM 3\base\pak008.pk4 (3 files)
D:\Spiele\DOOM 3\base\pak007.pk4 (38 files)
D:\Spiele\DOOM 3\base\pak006.pk4 (48 files)
D:\Spiele\DOOM 3\base\pak005.pk4 (63 files)
D:\Spiele\DOOM 3\base\pak004.pk4 (5137 files)
D:\Spiele\DOOM 3\base\pak003.pk4 (4676 files)
D:\Spiele\DOOM 3\base\pak002.pk4 (6120 files)
D:\Spiele\DOOM 3\base\pak001.pk4 (8972 files)
D:\Spiele\DOOM 3\base\pak000.pk4 (2698 files)
D:\Spiele\DOOM 3\base\game03.pk4 (2 files)
D:\Spiele\DOOM 3\base\game02.pk4 (2 files)
D:\Spiele\DOOM 3\base\game01.pk4 (2 files)
D:\Spiele\DOOM 3\base\game00.pk4 (2 files)
game DLL: 0x0 in pak: 0x0
Addon pk4s:
file system initialized.
----- Initializing Decls -----
------- Initializing renderSystem --------
using ARB renderSystem
renderSystem initialized.
5206 strings read from strings/english.lang
Couldn't open journal files
execing editor.cfg
execing default.cfg
couldn't exec DoomConfig.cfg
couldn't exec autoexec.cfg
----- Initializing Sound System ------
sound system initialized.
----- R_InitOpenGL -----
Initializing OpenGL subsystem
...registered window class
...registered fake window class
...initializing QGL
...calling LoadLibrary( 'opengl32' ): succeeded
...calling CDS: ok
...created window @ 0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...PIXELFORMAT 10 selected
...creating GL context: succeeded
...making context current: succeeded
------- Input Initialization -------
Initializing DirectInput...
mouse: DirectInput initialized.
keyboard: DirectInput initialized.
sound: STEREO
X..GL_ARB_multitexture not found
X..GL_ARB_texture_env_combine not found
X..GL_ARB_texture_cube_map not found
X..GL_ARB_texture_env_dot3 not found
X..GL_ARB_texture_env_add not found
X..GL_ARB_texture_non_power_of_two not found
X..GL_ARB_texture_compression not found
X..GL_EXT_texture_filter_anisotropic not found
...using GL_1.4_texture_lod_bias
X..GL_EXT_shared_texture_palette not found
X..GL_EXT_texture3D not found
X..GL_EXT_stencil_wrap not found
X..GL_NV_register_combiners not found
X..GL_EXT_stencil_two_side not found
X..GL_ATI_separate_stencil not found
X..GL_ATI_fragment_shader not found
X..GL_ATI_text_fragment_shader not found
X..GL_ARB_vertex_buffer_object not found
X..GL_ARB_vertex_program not found
X..GL_ARB_fragment_program not found
ERROR: The current video card / driver combination does not support the necessary features.
Error during initialization
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
Patch 1.3.1 habe ich installier da der 1.3 ja scheinbar unter Vista nicht funktioniert.Ich wäre euch Super Dankbar wenn mir einer einen Ratschlag geben könnte woran das Problem liegt!
Niven
Was für eine Grafikkarte hast du?
Welcher Treiber für die Grafikkarte ist installiert?
Der Treiber der bei Windows mitgeliefert wird unterstützt (wenn ich mich nicht irre) nur Direct X, aber kein OpenGL. Da musst du dir evtl mal einen "richtigen" Treiber runterladen.
Zumindest war das bei XP so. Wie es bei Vista aussieht weiss ich nicht. Aber ich schätze das da das Problem liegt.
Jo, hab das gleiche Problem.
Habe auch schon alles ausprobiert, auch die graka auf OpenGL umgestellt und Kompatibilitätsmodus usw.
Hab ne 8800 gtx und
Vista Ultimate x64
Hallo!
Ich habe eine Geforce 8600GS M.also ein Laptop.und da FSC keine neuen Treiber anbietet und die normalen Nvidia Treiber hier von z.b Comuterbase nicht funktionieren kann ich meine Treiber leider nicht Aktualisieren!
Meiner Treiber Version lautet 7.15.11.5615
Sollten noch Fragen offen sein, stelle die bitte im Sammel-Thread.
*closed*
Status
