CS 1.6 Ekliger Sound CS 1.6
Katillah
Apr. 2008
hallo ihr fragg0rs
habe voll den ekligen sound im Game, nur bei CS 1.6 alle anderen games laufen 100%ig.
Musik etc auch supi...
hier mal meine cfg: (falls es daran liegen sollte)
_cl_autowepswitch "0"
_snd_mixahead "0.1"
ati_npatch "1.0"
ati_subdiv "2.0"
bgmvolume "0.000000"
bottomcolor "6"
brightness "8"
cl_allowdownload "1"
cl_allowupload "1"
cl_backspeed "400"
cl_cmdbackup "6"
cl_cmdrate "40"
cl_corpsestay "0.000000"
cl_crosshair_color "50 250 50"
cl_crosshair_size "large"
cl_crosshair_translucent "1"
cl_dlmax "756"
cl_download_ingame "1"
cl_dynamiccrosshair "0"
cl_forwardspeed "400"
cl_himodels "1"
cl_idealpitchscale "0.8"
cl_lc "1"
cl_logocolor "#Valve_Orange"
cl_logofile "lambda"
cl_lw "1"
cl_minmodels "0"
cl_radartype "1"
cl_righthand "1"
cl_shadows "0"
cl_timeout "600"
cl_updaterate "101"
cl_vsmoothing "0.05"
cl_weather "0"
con_color "255 180 30"
console "0.0"
crosshair "1"
fastsprites "0"
fps_max "300"
fps_modem "0.0"
gamma "3"
gl_dither "0"
gl_flipmatrix "0"
gl_fog "1"
gl_monolights "0"
gl_overbright "1"
gl_polyoffset "0.1"
hisound "1"
hpk_maxsize "0.1"
hud_capturemouse "1"
hud_centerid "0"
hud_draw "1"
hud_fastswitch "1"
hud_saytext_internal "1"
hud_takesshots "0"
joystick "0"
lookspring "0"
lookstrafe "0"
m_filter "0"
m_forward "1"
m_pitch "0.022"
m_side "0.8"
m_yaw "0.022"
model "arctic"
MP3FadeTime "2"
MP3Volume "1"
mp_decals "30.000000"
name "Hekmek"
net_graph "3"
net_graphpos "3"
net_scale "5"
r_bmodelhighfrac "5"
r_detailtextures "0"
s_a3d "0"
s_automax_distance "40"
s_automin_distance "2"
s_bloat "2.0"
s_distance "160"
s_doppler "0.0"
s_eax "0"
s_leafnum "0"
s_max_distance "1000"
s_min_distance "2"
s_numpolys "200"
s_polykeep "1000000000"
s_polysize "10000000"
s_refdelay "4"
s_refgain "0.4"
s_rolloff "1"
s_verbwet "0.25"
sensitivity "3"
skin ""
spec_autodirector_internal "1"
spec_drawcone_internal "1"
spec_drawnames_internal "1"
spec_drawstatus_internal "1"
spec_mode_internal "2"
spec_pip "0"
suitvolume "0.15"
sv_aim "1"
sv_voiceenable "1"
team ""
topcolor "30"
viewsize "120"
voice_enable "1"
voice_forcemicrecord "1"
voice_modenable "1"
voice_scale "0.85"
volume "2"
setinfo "ghosts" "0"
setinfo "_vgui_menus" "0"
setinfo "_ah" "0"
+mlook
+jlook
exec userconfig.cfg
wenn sich einer auskennt bitte um korrektur :)
mfg
Beschreib doch erstmal genau was los ist; unter "eklig" kann ich mir ne Menge vorstellen ;)
ja so ein beschissenes "rauschen", hört sich qualitativ beschissen an!
weiss nicht wie ichs dir sonst beschreiben kann phlipp :)
Lösch doch einfach mal alle Soundeinstellungen (oder der Einfachheit halber nimm die Config ganz raus) und sieh, ob es dann besser ist.
Da die Config ohnehin neu aus den Defaultwerten erstellt wird, wenn keine gefunden wird, dürfte das einige hundert Mal schneller gehen als neu installieren ;)
Gamescom
