Features :
Pre-Rooted (No need to root first)
Pre-Deodexed (No need to deodex first)
Zipalign
New AROMA Installer
New UI and animation
New Statusbar (Tablet UI, Phablet, Normal)
New Elasys Multi Labs and About Elasys
Bottom Statusbar (CM Feature)
Navigation Bar (CM Feature)
New Boot animation
Custom platlogo
Beats Manager
StatusBar Slider Brightness
9 Lockscreen styles
OG Battery Mod
24 Toggles
Swipe to remove notifications
Etc...
Bug :
Cannot terminate calls from status bar expanded.
White on white text or black on black text color on some apps.
Mod Edit..Links Removed
INSTALLATION GUIDE :
Download Elasys_ROM_V4.zip
Copy Elasys_ROM_V4.zip to internal memory (SDCARD)
Turn off your phone
Go to recovery mode -> CWM
Go to Instal Zip From SDCARD
Choose Elasys_ROM_V4.zip
AROMA installer windows will be appear.
Follow the instructions
After finish, go to Advanced -> Reboot Recovery
Open CWM again
Wipe data
Wipe cache (optional)
Go to Advanced
Wipe Battery Stats (optional)
Reboot
Enjoy
Notes :
Quote:
If u're using stockrom, u can install it directly without rooting or deodexing.
Don't forget to BACKUP NANDROID thru CWM.
Backup contact number, if necessary.
First time, the statusbar will on the bottom but u should drag from top to open statusbar expanded. To be able to pull down the statusbar from, open settings-> elasys multi labs -> UI Settings -> Notifications Panel -> Tablet Tweaks -> unchecklist Bottom status bar and then checklist again.
