CoMo
Commodore
- Dez. 2015
ich bekomme beim
Das
Wie komme ich da raus?
@andy_m4 ich brauche dich 😇
ich bekomme beim
pkg upgrade folgenden Fehler:
Code:
[root@<XXX> ~]# pkg upgrade
Updating FreeBSD-ports repository catalogue...
FreeBSD-ports repository is up to date.
Updating FreeBSD-ports-kmods repository catalogue...
FreeBSD-ports-kmods repository is up to date.
Updating FreeBSD repository catalogue...
FreeBSD repository is up to date.
All repositories are up to date.
Checking for upgrades (30 candidates): 100%
Processing candidates (30 candidates): 100%
Checking integrity... done (2 conflicting)
- sqlite3-icu-3.50.4_2,1 [FreeBSD-ports] conflicts with sqlite3-3.53.1,1 [installed] on /usr/local/bin/sqldiff
- sqlite3-icu-3.53.1,1 [FreeBSD] conflicts with sqlite3-3.53.1,1 [installed] on /usr/local/bin/sqldiff
Checking integrity... done (0 conflicting)
Your packages are up to date.
Das
sqlite3-icu hat sich kurz vorher beim pkg upgrade installiert.
Code:
Fetching data: 100% 11 MiB 2.8 MB/s 00:04
Processing entries: 100%
FreeBSD repository update completed. 36964 packages processed.
The following 2 package(s) will be affected (of 0 checked):
New packages to be INSTALLED:
sqlite3-icu: 3.50.4_2,1 [FreeBSD-ports]
Installed packages to be UPGRADED:
bash: 5.3.12 -> 5.3.15 [FreeBSD]
Number of packages to be installed: 1
Number of packages to be upgraded: 1
The process will require 6 MiB more space.
2 MiB to be downloaded.
Proceed with this action? [y/N]: y
[1/1] Fetching bash-5.3.15: 100% 1912 KiB 2.0 MB/s 00:01
Checking integrity... done (1 conflicting)
Conflicts with the existing packages have been found.
One more solver iteration is needed to resolve them.
sqlite3-icu: 3.53.1,1 [FreeBSD]
1 MiB to be downloaded.
Code:
freebsd-version -ukr
15.0-RELEASE-p10
15.0-RELEASE-p10
15.0-RELEASE-p10
Code:
[root@<XXX> ~]# pkg stats
Local package database:
Installed packages: 86
Disk space occupied: 902 MiB
Remote package database(s):
Number of repositories: 3
Packages available: 74277
Unique packages: 74277
Total size of packages: 321 GiB
Code:
cat /etc/pkg/FreeBSD.conf
# To disable a repository, instead of modifying or removing this file,
# create a /usr/local/etc/pkg/repos/FreeBSD.conf file, e.g.:
# mkdir -p /usr/local/etc/pkg/repos
# echo "FreeBSD-ports: { enabled: no }" > /usr/local/etc/pkg/repos/FreeBSD.conf
# echo "FreeBSD-ports-kmods: { enabled: no }" >> /usr/local/etc/pkg/repos/FreeBSD.conf
# Note that the FreeBSD-base repository is disabled by default.
FreeBSD-ports: {
url: "pkg+https://pkg.FreeBSD.org/${ABI}/quarterly",
mirror_type: "srv",
signature_type: "fingerprints",
fingerprints: "/usr/share/keys/pkg",
enabled: yes
url: "pkg+https://pkg.FreeBSD.org/${ABI}/kmods_quarterly_${VERSION_MINOR}",
mirror_type: "srv",
enabled: yes
FreeBSD-base: {
url: "pkg+https://pkg.FreeBSD.org/${ABI}/base_release_${VERSION_MINOR}",
mirror_type: "srv",
fingerprints: "/usr/share/keys/pkgbase-${VERSION_MAJOR}",
enabled: no
Code:
cat /usr/local/etc/pkg/repos/*.conf 2>/dev/null
FreeBSD: {
url: "pkg+http://pkg.FreeBSD.org/${ABI}/latest",
mirror_type: "srv",
enabled: yes
