# File generated by xorgconfig.
# Refer to the xorg.conf(5) man page for details about the format of
# this file.
# Module section -- this section is used to specify
# which dynamically loadable modules to load.
Section "Module"
# This loads the DBE extension module.
# This loads the miscellaneous extensions module, and disables
# initialisation of the XFree86-DGA extension within that module.
# This loads the font modules
# Load "dri"
Load "dbe" # Double buffer extension
SubSection "extmod"
Option "omit xfree86-dga" # don't initialise the DGA extension
EndSubSection
Load "type1"
# Load "speedo"
Load "freetype"
# Load "xtt"
Load "vbe"
Load "extmod"
# Load "fbdevhw"
Load "record"
# This loads the GLX module
Load "glx"
# This loads the DRI module
EndSection
# Files section. This allows default font and rgb paths to be set
Section "Files"
# The location of the RGB database. Note, this is the name of the
# file minus the extension (like ".txt" or ".db"). There is normally
# no need to change the default.
# RgbPath "/usr/share/X11/rgb"
# Multiple FontPath entries are allowed (which are concatenated together),
# as well as specifying multiple comma-separated entries in one FontPath
# command (or a combination of both methods)
FontPath "/usr/share/fonts/100dpi/"
FontPath "/usr/share/fonts/75dpi/"
FontPath "/usr/share/fonts/aquafont/"
FontPath "/usr/share/fonts/aquapfont/"
FontPath "/usr/share/fonts/arkpandora/"
FontPath "/usr/share/fonts/arphicfonts/"
FontPath "/usr/share/fonts/artwiz-aleczapka-en/"
FontPath "/usr/share/fonts/baekmum-fonts/"
FontPath "/usr/share/fonts/corefonts/"
FontPath "/usr/share/fonts/cyrillic/"
FontPath "/usr/share/fonts/default/"
FontPath "/usr/share/fonts/dejavu/"
FontPath "/usr/share/fonts/encodings/"
FontPath "/usr/share/fonts/fireflysung/"
FontPath "/usr/share/fonts/freefonts/"
FontPath "/usr/share/fonts/hkscs-ming/"
FontPath "/usr/share/fonts/intlfonts/"
FontPath "/usr/share/fonts/ja-ipafonts/"
FontPath "/usr/share/fonts/jisx0213/"
FontPath "/usr/share/fonts/kochi-substitute/"
FontPath "/usr/share/fonts/liberation-fonts-ttf/"
FontPath "/usr/share/fonts/mathematica-fonts/"
FontPath "/usr/share/fonts/mikachan-font/"
FontPath "/usr/share/fonts/misc/"
FontPath "/usr/share/fonts/terminus/"
FontPath "/usr/share/fonts/texcm-ttf/"
FontPath "/usr/share/fonts/ttf-bitstream-vera/"
FontPath "/usr/share/fonts/ttf-gentium/"
FontPath "/usr/share/fonts/TTF/"
# FontPath "/usr/share/fonts/OTF"
FontPath "/usr/share/fonts/Type1/"
FontPath "/usr/lib/X11/fonts/unifont/"
FontPath "/usr/lib/X11/fonts/urwvn-fonts/"
# FontPath "/usr/lib/X11/fonts/local/"
# FontPath "/usr/lib/X11/fonts/misc/"
# FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
# FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
# FontPath "/usr/lib/X11/fonts/Speedo/"
FontPath "/usr/lib/X11/fonts/TrueType/"
FontPath "/usr/lib/X11/fonts/freefont/"
# The module search path. The default path is shown here.
# ModulePath "/usr/lib/modules"
EndSection
# Server flags section.
Section "ServerFlags"
# Uncomment this to cause a core dump at the spot where a signal is
# received. This may leave the console in an unusable state, but may
# provide a better stack trace in the core dump to aid in debugging
# Option "NoTrapSignals"
# Uncomment this to disable the <Ctrl><Alt><Fn> VT switch sequence
# (where n is 1 through 12). This allows clients to receive these key
# events.
# Option "DontVTSwitch"
# Uncomment this to disable the <Ctrl><Alt><BS> server abort sequence
# This allows clients to receive this key event.
# Option "DontZap"
# Uncomment this to disable the <Ctrl><Alt><KP_+>/<KP_-> mode switching
# sequences. This allows clients to receive these key events.
# Option "Dont Zoom"
# Uncomment this to disable tuning with the xvidtune client. With
# it the client can still run and fetch card and monitor attributes,
# but it will not be allowed to change them. If it tries it will
# receive a protocol error.
# Option "DisableVidModeExtension"
# Uncomment this to enable the use of a non-local xvidtune client.
# Option "AllowNonLocalXvidtune"
# Uncomment this to disable dynamically modifying the input device
# (mouse and keyboard) settings.
# Option "DisableModInDev"
# Uncomment this to enable the use of a non-local client to
# change the keyboard or mouse settings (currently only xset).
# Option "AllowNonLocalModInDev"
Option "Xinerama" "0"
EndSection
# Input devices
# Core keyboard's InputDevice section
Section "InputDevice"
Identifier "Keyboard1"
Driver "kbd"
Option "AutoRepeat" "500 30"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "de"
# Option "XkbOptions" "compose:lwin"
# Option "XkbVariant" "de-latin1"
EndSection
# Core Pointer's InputDevice section
# Identifier and driver
Identifier "Mouse1"
Driver "mouse"
Option "Protocol" "Auto" # Auto detect
Option "Device" "/dev/psaux"
# Mouse-speed setting for PS/2 mouse.
# Option "Resolution" "256"
# Baudrate and SampleRate are only for some Logitech mice. In
# almost every case these lines should be omitted.
# Option "BaudRate" "9600"
# Option "SampleRate" "150"
# Mouse wheel mapping. Default is to map vertical wheel to buttons 4 & 5,
# horizontal wheel to buttons 6 & 7. Change if your mouse has more than
# 3 buttons and you need to map the wheel to different button ids to avoid
# conflicts.
Option "ZAxisMapping" "4 5 6 7"
# Emulate3Buttons is an option for 2-button mice
# Emulate3Timeout is the timeout in milliseconds (default is 50ms)
Option "Emulate3Buttons"
# Option "Emulate3Timeout" "50"
# ChordMiddle is an option for some 3-button Logitech mice
# Option "ChordMiddle"
EndSection
Identifier "Synaptics Touchpad"
Driver "synaptics"
Option "SendCoreEvents" "true"
Option "Protocol" "auto-dev"
# Option "HorizEdgeScroll" "0"
# Option "LeftEdge" "130"
# Option "RightEdge" "840"
# Option "TopEdge" "130"
# Option "BottomEdge" "640"
# Option "FingerLow" "7"
# Option "FingerHigh" "8"
# Option "MaxTapTime" "180"
# Option "MaxTapMove" "110"
# Option "EmulateMidButtonTime" "75"
# Option "VertScrollDelta" "20"
# Option "HorizScrollDelta" "20"
# Option "MinSpeed" "0.60"
# Option "MaxSpeed" "1.10"
# Option "AccelFactor" "0.030"
# Option "EdgeMotionMinSpeed" "200"
# Option "EdgeMotionMaxSpeed" "200"
# Option "UpDownScrolling" "1"
# Option "CircularScrolling" "1"
# Option "CircScrollDelta" "0.1"
# Option "CircScrollTrigger" "2"
Option "LeftEdge" "1700"
Option "RightEdge" "5300"
Option "TopEdge" "1700"
Option "BottomEdge" "4200"
Option "FingerLow" "25"
Option "FingerHigh" "30"
Option "MaxTapMove" "220"
Option "VertScrollDelta" "100"
Option "HorizScrollDelta" "100"
Option "EmulateMidButtonTime" "0"
Option "SHMConfig" "true"
Option "MinSpeed" "0.09"
Option "MaxSpeed" "0.18"
Option "AccelFactor" "0.0015"
EndSection
# Other input device sections
# this is optional and is required only if you
# are using extended input devices. This is for example only. Refer
# to the xorg.conf man page for a description of the options.
# Section "InputDevice"
# Identifier "Mouse2"
# Driver "mouse"
# Option "Protocol" "MouseMan"
# Option "Device" "/dev/mouse2"
# EndSection
# Monitor section
# Any number of monitor sections may be present
Section "Monitor"
Identifier "xps m1330 flatpanel led"
# HorizSync is in kHz unless units are specified.
# HorizSync may be a comma separated list of discrete values, or a
# comma separated list of ranges of values.
# NOTE: THE VALUES HERE ARE EXAMPLES ONLY. REFER TO YOUR MONITOR'S
# USER MANUAL FOR THE CORRECT NUMBERS.
HorizSync 31.5-49.68
# HorizSync 30-64 # multisync
# HorizSync 31.5, 35.2 # multiple fixed sync frequencies
# HorizSync 15-25, 30-50 # multiple ranges of sync frequencies
# VertRefresh is in Hz unless units are specified.
# VertRefresh may be a comma separated list of discrete values, or a
VertRefresh 50-83.46
EndSection
# Graphics device section
# Any number of graphics device sections may be present
# Standard VGA Device:
Section "Device"
Identifier "Standard VGA"
VendorName "Unknown"
BoardName "Unknown"
# The chipset line is optional in most cases. It can be used to override
# the driver's chipset detection, and should not normally be specified.
# Chipset "generic"
# The Driver line must be present. When using run-time loadable driver
# modules, this line instructs the server to load the specified driver
# module. Even when not using loadable driver modules, this line
# indicates which driver should interpret the information in this section.
Driver "vga"
# The BusID line is used to specify which of possibly multiple devices
# this section is intended for. When this line isn't present, a device
# section can only match up with the primary video device. For PCI
# devices a line like the following could be used. This line should not
# normally be included unless there is more than one video device
# intalled.
# BusID "PCI:0:10:0"
# VideoRam 256
# Clocks 25.2 28.3
EndSection
# Device configured by xorgconfig:
Section "Device"
Identifier "geforce 8400m gs"
Driver "nvidia"
Option "TripleBuffer" "true"
Option "RenderAccel" "true"
Option "AllowGLXWithComposite" "true"
Option "OnDemandVBlankInterrupts" "True"
Option "NvAGP" "0"
Option "DamageEvents" "True"
Option "BackingStore" "True"
Option "InitialPixmapPlacement" "2"
# If you use render events, be sure to boot with the idle=poll option
#Option "UseEvents" "True"
#VideoRam 262144
# Insert Clocks lines here if appropriate
Option "DPMS" "TRUE"
Option "NoLogo" "1"
#Enable Underclocking
Option "Coolbits" "1"
EndSection
# Screen sections
# Any number of screen sections may be present. Each describes
# the configuration of a single screen. A single specific screen section
# may be specified from the X server command line with the "-screen"
# option.
Section "Screen"
Identifier "Screen 1"
Device "geforce 8400m gs"
Monitor "xps m1330 flatpanel led"
DefaultDepth 24
Option "TwinView" "0"
Option "AddARGBGLXVisuals" "true"
# Workaround for ugly Qt bugs with recent nvidia drivers and compiz
Option "UseCompositeWrapper" "true"
Subsection "Display"
Depth 8
Modes "1280x800"
ViewPort 0 0
EndSubsection
Depth 16
Modes "1280x800"
ViewPort 0 0
EndSubsection
Depth 24
Modes "1280x800"
ViewPort 0 0
EndSubsection
EndSection
# ServerLayout sections.
# Any number of ServerLayout sections may be present. Each describes
# the way multiple screens are organised. A specific ServerLayout
# section may be specified from the X server command line with the
# "-layout" option. In the absence of this, the first section is used.
# When now ServerLayout section is present, the first Screen section
# is used alone.
Section "ServerLayout"
# The Identifier line must be present
Identifier "Simple Layout"
# Each Screen line specifies a Screen section name, and optionally
# the relative position of other screens. The four names after
# primary screen name are the screens to the top, bottom, left and right
# of the primary screen. In this example, screen 2 is located to the
# right of screen 1.
Screen "Screen 1"
# Each InputDevice line specifies an InputDevice section name and
# optionally some options to specify the way the device is to be
# used. Those options include "CorePointer", "CoreKeyboard" and
# "SendCoreEvents".
InputDevice "Mouse1" "CorePointer"
InputDevice "Keyboard1" "CoreKeyboard"
InputDevice "Synaptics Touchpad"
EndSection
Section "Extensions"
Option "Composite" "Enable"
Option "DAMAGE" "Enable"
Option "RENDER" "Enable"
EndSection
Section "DRI"
Mode 0666
EndSection
