h67 chipsatz mit 2600k +oc möglich?
francodn
Banned
Nov. 2004
ich kann für 150 euro von einem bekannten einen i7-2600k bekommen.nun ist es so das ich ein msi h67m-e45 board habe welches ja bekanntermaßen übertakten laut diversen reviews nicht unterstützt.
auf der msi webseite für das board ist aber angegeben das zumindest eine übertaktung auf 4.2ghz möglich ist.
http://www.msi.com/product/mb/H67MA-E45--B3-.html#/?div=Overview
im web hab ich mal geschaut und diesen chatlog mit einem intel mitarbeiter gefunden:
info: Please wait for a site operator to respond.
info: You are now chatting with 'Victor'
xx@xxxx.xxx: Hi,
Victor: Hello. Thank you for using the Intel Customer Support chat service. We are glad to be of service. How can I help you today?
xx@xxxx.xxx: According to http://www.intel.com/consumer/game/gaming-power.htm, overclocking 2nd Gen Core processors requires a P67 chipset. According to http://www.intel.com/Assets/PDF/prodbrief/324586.pdf, H67 supports the overclocking features of unlocked 2nd gen Core processors. Which is correct?
xx@xxxx.xxx: I may add that the overview page for the F67 chipset refers to P67.
xx@xxxx.xxx: H67, I mean, not F.
Victor: On the information that I have, both chipset's H and P will support the overclocking on unlocked processors. This will depend on the integration of the chipset and the BIOS.
xx@xxxx.xxx: Very interesting! Nearly all the reviews I have read state that only P67 supports overclocking.
Victor: Currently in our motherboards the P67 chipset motherboard has enabled the overclocking features.
xx@xxxx.xxx: Thankyou. So it is dependent on the motherboard manufacture as to whether an H67 board can overclock or not, I believe.
Victor: Correct.
xx@xxxx.xxx: OK. Now I know what I'll be doing, thankyou.
Victor: You are welcome and thank you for contacting Intel Customer Support.
Victor: Thank you for using chat. We value your suggestions and would appreciate it if you would take a moment to complete our survey. The survey will appear when you click "Close'' to close the chat window. Have a nice day.
also wenn ich den i7 kaufe will ich den auch übertakten,nur die frage ist brauche ich dann ein neues board?
oh jetzt les ich es p67 :rolleyes:
ein bischen ist das ja eine verarschung von msi dies mit einem bild so hervorzuheben und dann zu schreiben das es nur mit mit einem p67 board geht :D
nein die grafikperformance der igpu kannst du auch beim h board boosten und damit werben die auch
Wenn du die Leistung vom i7 brauchst dann kauf dir den Prozessor wenn Rechnung dabei ist und der CPU ohne Probleme läuft.
Dazu ein Z77 Board
