HD 2900 Pro für 133€ !
- Ersteller AMD = POWER
rumpel01
Fleet Admiral
- März 2006
Hey, nix los hier?
Habe mal eben Crysis DX10 gebencht, mit dem E4300 @3,25Ghz sowie dem HD2900pro Crossfire @780/1052:
1280x1024:
sowie 1280x1024, 4xAA und 16xAF:
1280x1024:
Code:
07.02.2008 18:14:08 - Vista 64
Beginning Run #1 on Map-island, Demo-benchmark_gpu
DX10 1280x1024, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Demo Loops=3, Time Of Day= 9
Global Game Quality: High
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 62.37s, Average FPS: 32.06
Min FPS: 3.91 at frame 139, Max FPS: 52.64 at frame 871
Average Tri/Sec: -29367262, Tri/Frame: -915883
Recorded/Played Tris ratio: -1.00
!TimeDemo Run 1 Finished.
Play Time: 48.66s, Average FPS: 41.10
Min FPS: 3.91 at frame 139, Max FPS: 54.57 at frame 68
Average Tri/Sec: -37593536, Tri/Frame: -914703
!TimeDemo Run 2 Finished.
Play Time: 47.69s, Average FPS: 41.94
Average Tri/Sec: -38327076, Tri/Frame: -913865
TimeDemo Play Ended, (3 Runs Performed)
Completed All Tests
<><><><><><><><><><><><><>>--SUMMARY--<<><><><><><><><><><><><><>
Run #1- DX10 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 4152
Code:
07.02.2008 18:18:48 - Vista 64
DX10 1280x1024, AA=4x, Vsync=Disabled, 32 bit test, FullScreen
Play Time: 96.30s, Average FPS: 20.77
Min FPS: 9.33 at frame 148, Max FPS: 26.82 at frame 948
Average Tri/Sec: -18411158, Tri/Frame: -886540
Recorded/Played Tris ratio: -1.03
Play Time: 84.68s, Average FPS: 23.62
Min FPS: 8.86 at frame 1930, Max FPS: 36.94 at frame 73
Average Tri/Sec: -20903852, Tri/Frame: -885114
Recorded/Played Tris ratio: -1.04
Play Time: 82.01s, Average FPS: 24.39
Average Tri/Sec: -21564708, Tri/Frame: -884271
Completed All Tests
Run #1- DX10 1280x1024 AA=4x, 32 bit test, Quality: High ~~ Overall Average FPS: 2400,5
venom
- Okt. 2001
rumpel01
Fleet Admiral
- März 2006
Schöne Fotos!
@Keilinho: Bei XP und DX9 ist bei mir seit dem Boardwechsel speziell bei Crysis irgendwie der Wurm drin. Die Frameraten sind nicht höher als im DX10-Test, und um zwei 2 FPS niedriger als mit dem alten P35-Board (statt 44,5FPS immer ca. 42-43FPS). Alle anderen Spiele funzen aber so wie sie sollen. Evtl. muss ich mal das verbuggte Crysis wieder runterwerfen und neu aufspielen. Aufgrund der Erfahrungen anderer, die alle unisono einen Einbruch von 20-25% beim Wechsel von DX9 auf DX10 bestätigen, müssten die FPS bei 1280x1024 ohne AA/AF unter DX9 bei ca. 50 FPS liegen.
@Das Brot:
Hauptsache, hier wird wieder ein wenig über die Karte diskutiert ...
@Das Brot:
DasBrot
- Sep. 2007
Jetzt nochmal was von mir:
Crysis auf 1280*1024
E2160 @ 2,8 GHz
2900 Pro @ 778/900 (1,15V)
Hier alles auf High
Hier mit angepasster Config
Der RAM ist ein wenig störrisch, muss mal gucken wie hoch der denn jetzt will. 945 war nach ner Stunde instabil...mal sehen.
E2160 @ 2,8 GHz
Hier alles auf High
Code:
Play Time: 66.04s, Average FPS: 30.29
Min FPS: 16.42 at frame 139, Max FPS: 40.64 at frame 991
Average Tri/Sec: 30635828, Tri/Frame: 1011527
Recorded/Played Tris ratio: 0.91
Play Time: 59.39s, Average FPS: 33.68
Average Tri/Sec: 34397032, Tri/Frame: 1021387
Recorded/Played Tris ratio: 0.90
Play Time: 59.31s, Average FPS: 33.72
Min FPS: 16.42 at frame 139, Max FPS: 40.79 at frame 993
Average Tri/Sec: 34493952, Tri/Frame: 1022972
!TimeDemo Run 3 Finished.
Play Time: 59.27s, Average FPS: 33.75
Average Tri/Sec: 34466876, Tri/Frame: 1021373
TimeDemo Play Ended, (4 Runs Performed)
Code:
Play Time: 87.49s, Average FPS: 22.86
Min FPS: 19.01 at frame 140, Max FPS: 40.29 at frame 1004
Average Tri/Sec: 18822158, Tri/Frame: 823408
Recorded/Played Tris ratio: 1.11
Play Time: 61.52s, Average FPS: 32.51
Min FPS: 19.01 at frame 140, Max FPS: 43.48 at frame 134
Average Tri/Sec: 26860382, Tri/Frame: 826199
Play Time: 61.29s, Average FPS: 32.63
Min FPS: 19.01 at frame 140, Max FPS: 45.05 at frame 109
Average Tri/Sec: 26925946, Tri/Frame: 825085
Play Time: 61.24s, Average FPS: 32.66
Average Tri/Sec: 26946448, Tri/Frame: 825150
Keilinho
- Okt. 2005
Habe meine mal durch die Timedemo gehetzt da die so schon die Temps hochjagd, Karte hat 1,1V und lief auf 750-1100,, Auflösung 1440x900 alles High mit meinem 4500er unter Standard(3,1) 31 FPS Avg. mit 4xAA/8xAF dann 22 FPS Avg, und ich bin sehr zufrieden mit den Temperaturen speziell bei den Spannungsreglern, deutlich niedriger als bei meiner früheren 1950XT.
venom
- Okt. 2001
wäre ja schade um den thread wenn dieser vergammeln würde
welchen treiber benutzt :?
klar, die CF benutzen, die nutzen türlich den neuesten
aber eure persönliche meinung zum treiber, evtl benutzt ihr ja auch inoffiziele sprich Omega treiber.
ich persönlich benutze z.Z. den 8.2 weil ich vorher den Farbbug hatte
DasBrot
- Sep. 2007
Ich benutze die Omega Treiber, basierend auf dem 7.12 Catalyst.
Verwende die schon seit über 1 1/2 Jahren und bin immer hoch zufrieden damit. Prinzipiell kann man natürlich auch immer die neuesten von ATI benutzen, aber dann muss ich immer alles neu einstellen, was die Tweaks angeht. Die Omega sind halt ein rundum-sorglos Paket.
Und ein kleines Fazit zu meinem neuen System:
E2160 @ 3GHz (8*375) (1,55 V, gut das ich nen dicken Kühler hab!
MSI Neo2 FR
2 GB DDR2 RAM GEIL BlackDragon @ 900
WindowsXP SP2
HD 2900 PRO @200,300 0,9 V / 780,945 1,15 V
Bin damit hochzufrieden, läuft alles so seit gut 2 Wochen. Für das Geld ( ca. 450 €) kann man sich nicht beklagen. Alles läuft flüssig auf 1280*1024 mit hohen Einstellungen. Kann das nur jedem wärmstens empfehlen.
MSI Neo2 FR
WindowsXP SP2
NVIDIAfan
- März 2007
DasBrot schrieb:E2160 @ 3GHz (8*375) (1,55 V, gut das ich nen dicken Kühler hab!)
Whoo... du gibst dem ganz ordentlich Volt. Ich laufe mit 2,8 GHz bei 1.3375V
KabaFit Erdbeer
Captain
- Juli 2007
hab mal ne frage :
mit welchem Programm lest ihr die Spawa-temps euerer pro aus ?
hat sich erledigt, everst hat sie mir eben nicht angeziegt und ich dachte, ich hätte mich vertan
habe aber noch eine Frage :
Seit ich den HR03 R600 besitze, sind die Temperaturen meiner Spawas ins sehr ungesunde gestiegen :
nach 1 min. Fellwürfel sind es 110°C.
Was soll ich tun ?
Soll ich den HR03 zurücksenden ?
Was soll ich tun ?
rumpel01
Fleet Admiral
- März 2006
Hast Du denn auf den Spawas einen separaten Kühlkörper? Ist da beim Thermalright keiner mitgeliefert? Da gehört einer drauf. Ohne weitere Kühlkörper auf den Dingern kann man sich die Karte grillen!
Ansonsten würde ich mir den Arctic 2900 besorgen ...
KabaFit Erdbeer
Captain
- Juli 2007
ja, der ist drauf.
die Spawas wurden vorher mit IsO-Propanol gereinigt und ich habe den Klebstreifen auf dem PWN-Kühler abgezogen. Dann das Pad drauf gesetzt und die Befestigungspins runtergedrückt, bis es *Klick* gemacht hat.
KabaFit Erdbeer
Captain
- Juli 2007
Der ist auf der Oberseite montiert und bläst auch auf die Spawas
