also mit dem Code läuft gar nix.
Bzw. es leuchten LEDs aber das Mikro reagiert nicht.
Hab jetz folgenden genommen:
//Develop by creative KHOPDI
//NOTE:-ADJUST/SET BY POTENTIOMETER OF SOUND SENSOR IF LESS NUMBER OF PATTERN OBSERVE
#include <FastLED.h>
int r=152;
int g=0;
int b=10;
#define LED_PIN 7 //CONNECT DATA PIN OF PIXEL WITH 5 NUMBER PIN OF ARDUINO
#define NUM_LEDS 17 //CHANGE THE VALUE IF YOU WANT TO USE DIFFRENT NUMBER OF LED IN YOUR STRIP,HERE IN MY STRIP NUMBER OF LED IS 60 SO I SET IT 60.
CRGB leds[NUM_LEDS];
CRGB led[NUM_LEDS];
int s=0;
void setup() {
FastLED.addLeds<WS2812, LED_PIN, GRB>(leds, NUM_LEDS);
for (int i = NUM_LEDS/2; i >= 0; i--)
leds = CRGB ( r,g,b);
leds[NUM_LEDS-i] = CRGB (r,g,b );
delay(40);
FastLED.show();
Serial.begin(9600);
pinMode(A0,INPUT);
void loop()
s=analogRead(A0);
s=s*2;
// Serial.println(s);
// delay(50);
if((s>=450)&&(s<=550))
leds[(NUM_LEDS/2)-1]=CRGB (0, 0, 255);
leds[NUM_LEDS/2]=CRGB (0, 0, 255);
else if((s>=400)&&(s<=450))
leds[(NUM_LEDS/2)-1]=CRGB (153, 153, 0);
leds[NUM_LEDS/2]=CRGB (153, 153, 0);
else if((s>=350)&&(s<=400))
leds[(NUM_LEDS/2)-1]=CRGB (255, 50, 255);
leds[NUM_LEDS/2]=CRGB (255, 50, 255);
else if((s>=300)&&(s<=350))
leds[(NUM_LEDS/2)-1]=CRGB (10, 25, 217);
leds[NUM_LEDS/2]=CRGB (10, 25, 217);
else if((s>=276)&&(s<=300))
leds[(NUM_LEDS/2)-1]=CRGB (50, 50, 150);
leds[NUM_LEDS/2]=CRGB (50, 50, 150);
else if((s>=250)&&(s<=275))
leds[(NUM_LEDS/2)-1]=CRGB (230, 0, 10);
leds[NUM_LEDS/2]=CRGB (230, 0, 10);
else if((s>=235)&&(s<=250))
leds[(NUM_LEDS/2)-1]=CRGB (0, 160, 0);
leds[NUM_LEDS/2]=CRGB (0, 160, 0);
else if((s>=200)&&(s<=230))
leds[(NUM_LEDS/2)-1]=CRGB (1, 0, 1);
leds[NUM_LEDS/2]=CRGB (1, 0, 1);
else
leds[(NUM_LEDS/2)-1] = CRGB ( r,s-100,b);
leds[NUM_LEDS/2] = CRGB ( r,s-100,b);
for (int i = 0; i <= ((NUM_LEDS/2)-2); i++)
leds = leds[i+1];
leds[NUM_LEDS-1-i] = leds[(NUM_LEDS)-i-2];
FastLED.show();
delay(25);
dort hab ich zwar zu viel RGB Kirmes - aber das Mikro reagiert auch
Ich check noch nicht wirklich was ich alles ändern muss um einfach eine Farbe zu haben die dann stufenweise heller wird durch vorgegebene Lautstärke
Es soll halt auch kein Licht "wandern" - sondern eigentlich statisch sich ändern in der Helligkeit.
