Achim_Anders
Commodore
- Nov. 2005
Ich habe mega nervige Ruckler bei Fifa 14. Das Bild stockt alle paar Sekunden merklich, super nervig.
Versucht habe ich bisher folgendes:
ATI: Get RadeonPro make a profile with the FIFA 14 ,select it,click on Profile > Visual and add these settings: Anti-Aliasing = Application Controlled, Anti-Aliasing Filter = Multisampling, Anti-Aliasing Mode = Multi Sample, Anisotropic Filtering = Application Controlled. From the Advance and Tweak tabs turn OFF Vsync & Tripple Buffering.
Note that these are only standard settings and will not fix your problem 100% because everyone has different specs. You can change and tweak the settings yourself until you reach an optimal configuration for your game and the lag and stuttering will stop. Also don’t forget to use the D3DOverrider!
Hat zwar Verbesserung gebracht, aber dadurch habe ich Mikroruckler... Das Spiel stockt wirklich für bruchteile von Sekunden.
