OC e6600 boxed @ 2700mhz
soni-c
Juni 2007
SO meine Damen und Herren...
Habe mein sys dank der hilfe von "8800GTX" einwenig übertaktet hier jetzt mein ergebnis:
Hier noch mal die Prime95 Ergebnisse:
[Thu Jun 28 18:41:52 2007]
Self-test 1024K passed!
[Thu Jun 28 19:01:49 2007]
Self-test 8K passed!
[Thu Jun 28 19:18:36 2007]
Self-test 10K passed!
[Thu Jun 28 19:34:26 2007]
Self-test 896K passed!
[Thu Jun 28 19:41:23 2007]
Compare your results to other computers at http://www.mersenne.org/bench.htm
Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
CPU speed: 2700.01 MHz, 2 cores
CPU features: RDTSC, CMOV, Prefetch, MMX, SSE, SSE2
L1 cache size: 32 KB
L2 cache size: 4096 KB
L1 cache line size: 64 bytes
L2 cache line size: 64 bytes
TLBS: 256
Prime95 32-bit version 25.3, RdtscTiming=1
Best time for 768K FFT length: 16.229 ms.
Best time for 896K FFT length: 19.428 ms.
Best time for 1024K FFT length: 22.473 ms.
Best time for 1280K FFT length: 27.928 ms.
Best time for 1536K FFT length: 33.899 ms.
Best time for 1792K FFT length: 40.390 ms.
Best time for 2048K FFT length: 45.108 ms.
Best time for 2560K FFT length: 59.479 ms.
Best time for 3072K FFT length: 72.544 ms.
Best time for 3584K FFT length: 86.365 ms.
Best time for 4096K FFT length: 97.031 ms.
Best time for 5120K FFT length: 123.824 ms.
Best time for 6144K FFT length: 149.234 ms.
TLBS: 256
Best time for 768K FFT length: 16.235 ms.
Best time for 896K FFT length: 19.542 ms.
Best time for 1024K FFT length: 22.290 ms.
Best time for 1280K FFT length: 27.880 ms.
Best time for 1536K FFT length: 33.976 ms.
Best time for 1792K FFT length: 40.488 ms.
Best time for 2048K FFT length: 45.225 ms.
1.Was haltet ihr davon? ist das für ein Boxed kühler zu viel des guten?
2.Sollte noch was anderes umgestellt werden was nicht so ganz hinhaut?
3.Wie ist die Temp. (temp. ist bei volllast entstanden mit prime95)
Ein dank noch für den hilfsbereiten 8800GTX
Danke im Voraus soni-c
Hi soni-c,
ich würde mal behaupten dass alles in Ordung ist. Von den Temepraturen her gehts noch, aber wenn du noch Geld übrig hast um einen anderen Lüfter zu kaufen dann kannst du sogar noch auf 3 Ghz, also 9 x333 Mhz. Empfehlen würde ich dir den Zalman 9700 LED bzw. NT. Habe den LED und muss sagen bin sau zufrieden, auch optisch finde ich ihn Hammer . Habe den selben Prozzi wie du, und er ist auf 3 Ghz hochgetaktet. Im idle ist der Prozzi laut Everest auf ca. 36 °C und in der Last auf ca. 49 °C.
Nochmal zum Zalmankühler: Der LED kostet ungefähr 42 €uronen, der NT ca. 50 €. Auch in tests ist er einer der besten.
MfG Alexander B.
habe jetzt den SPD Multiplayer auf 2,66 eingestellt:
So muss der ja standard sein oder??? war ja davor auch 400mhz und ich darf ja nicht über 800 gehen oder würdet ihr lieber die SPD auf 2.5 lassen?
mfg soni-c
Stell mal deinen Ramteiler auf 1:1, dann die Latenzen auf 4-4-4-8 1T und du bekommst eine erheblich bessere Performance. Den 6600 kannst du auch problemlos noch viel höher takten. Erst ab 3,6 GHz gibt es bei mir Probleme mit der Kühlung durch den Coolermaster HyperTX. 3,2 GHz dürften mit einem günstigen Freezer 7 kein Problem darstellen und unter Last sollten sich dann die Temperaturen um die 50 Grad bewegen.
@ bitcatcher
command rate auf 1t ? das war wohl ein scherz oder ?
@sonic
ich würde erstmal mit cl5-5-5-15 CR 2t gehen !
wenn das läuft dann langsam runtergehen bis auf cl4-4-4-12 mit 2,1v spannung
aber command rate wird wohl kaum auf 1t laufen.
es kommt aber darauf an wie hoch der takt ist !
die speichertimings sind beim c2d nicht so wichtig da er kein speicherkontroller hat wie die AMD´s
du kannst eher versuchen mit einem einem anderen speicherteiler den speicher zu übertakten.
vielleicht läuft er mit ddr2-900 @ cl5-5-5-15 CR 2t
mußt du eben probieren. aber 2,1 V Vdimm sollte ohne probleme gehen
gruss
Nö, wieso? Siehe meine Signatur. Alle Systeme primestable, schon seit langer Zeit - und das mit MDT-RAM. Beim 1:1 Teiler wird das RAM unter den Spezifikationen betrieben, dadurch sind ehrheblich niedrigere Latzenen und eine CR von 1T möglich.
Auf keinen Fall den MDT-RAM höher als 1,8 bis maximal 1,9 V betreiben! Bei 2,1 V dürfte das System schon nicht mehr booten - Absolute Vorsicht, sonst zerhackst du dir deinen RAM!
Edit: Speicherteiler 1:1 und 1T bei 2,7 - 3 GHz läuft auf jeden Fall rund mit den MDT @1,8V.
@ bit
im letzten cpu-z svreen hat er die speihcer auf 800 laufen ! das ist nicht mehr unter spez.
aber es bringt wesentlich mehr mit schelchten timings und mehr takt zu fahren.
gruss
Nein, bringt es nicht. Kann ich dir mit Benches belegen. 900 MHz macht der MDT-RAM zudem nicht mit.
Ja, er fährt auch mit 10:8 und nicht mit 1:1.
Jetzt habt ihr mich verwirrt was soll ich jetzt machen und wie mach ich den Teiler auf 1:1 die Timmings kann ich ändern im BIOS
aber wie heißt der Befehl für Teiler im BIOS?
das mit den 3,6ghz. kommt evt. später da ich ja zur zeit nur ein boxed kühler habe..
mfg soni-c
Alexander B. schrieb:
Hi soni-c,
MfG Alexander B.
genau so hab ich es auch , mit den selben komponenten . mein temps sind auch fast identisch :)
Und du denkst du kennst dich aus? Wirklich?!
Wie willst bei nem 965 die Command Rate 1T einstellen? (Wär mir neu)
Der Coolermaster HyperTX schaft 3,6ghz wahrscheinlich noch bei nem vcore von 1,5v. Alles klar :freak:.
Wie xrobberx schon sagte höher Speichertaktraten bringen auf jedenfall mehr wie die besten Timings.
@exiter
mein reden !
cr auf 1t ist mir neu bei dem board und den speichern !
obwohl einige boards wie z.b. meins könne das ! aber meine speicher laufen nicht auf CR 1t ! ich habe es noch unter 900 probiert ! vielleicht laufen si bei 800mhz auf 1t !
aber ich habe sie immer über 1000 laúfen!
und meine kumpels fahren alle 2t ´weil 1t nicht läuft.
und der cpukühler den er hat kann nimmer 3,6ghz ab ! ich schätz die cpu hat so mindestens 65 grad unter last ! oder mehr !
und dann 1,5v vore !! cool ! dat raucht ........lol
gruss
@ topic
geh mit den speichern erstmal auf 5-5-5-15 2t .
wenn läuft dann gucken das du die timings vielleicht bie auf 4-4-4-12 2t bekommst.
vdimm auf 2,1v. ist vertretbar uund unbedenklich.
aber wie gesagt , takt bringt wesentlich mehr als timings !
lieber die rams übertakten als die timings so weit runter zu stellen
gruss
Hallo wo ändere ich die Spannung bei meinem Gigabyte DS3 habe leider keine vdimm einstellung gefunden im bios... mfg soni-c
Lern mal genau zu lesen, dann können wir uns weiter unterhalten.
Ich habe kein Wort davon gesagt das der HyperTX es schafft für eine vernüftige Kühlung bei 3,6 GHz zu sorgen, schon gar nicht habe ich die 1,5 V erwähnt - also mal genau schauen.
Das der 965 kein 1T schafft wusste ich nicht, meine Boards laufen alle mit 1T.
Hier mal zwei Everest 3.80 Memory Benchmark Ergebnisse.
Testsystem: C2D @ 3 GHz (Haupt-PC siehe Signatur)
1. Ergebnis mit RAM-Takt auf 667 MHz, Teiler 1:1, Timings bei 4-4-4-8 1T, Spannung: 1,8 V
2. Ergebnis mit RAM-Takt auf 800 MHz, Teiler 6:5, Timings bei 5-5-5-15 2T, Spannung: 1,8 V
Lediglich der Schreibdurchsatz ist bei dem geringeren Takt von 667 MHz leicht schlechter, alle anderen Ergebnisse sind besser - vor allem der Lesedurchsatz.
Edit: Habe mit erster Konfiguration (auf 667) auch bessere Ergebnisse im 3DMark06 sowie im Aquamark 3.
@xrobberx: Benutzt du MDT-RAM? Nein, denn dann wüsstest du das MDT-RAM mit erheblich niedrigerer Spannung betrieben werden muß (Ab Werk 1,8 V). Alle Versuche meinerseits das MDT-RAM mit mehr als 2,0 V zu betreiben scheiterten. Bei 2,1 V bootete das System nicht mehr und ein BIOS-Reset war erforderlich. Zudem habe ich keinen Vorteil durch höhere Spannungen beim MDT-RAM feststellen können, die Übertaktbarkeit hält sich bei diesem RAM in Grenzen. Auf 4-4-4-12 bekommst du das MDT-RAM auf 800 MHz niemals.
Ist ja schön und gut aber wo stelle ich bei meinem board die Spannung für die RAM ein pls help habe im BIOS nix gefunden... und ich will da nix falsches einstellen mfg soni-c.
@ bitcatcher !
in deiner signatur steht bei deinen beiden systemen bei den speichern pc6400. das entspricht ddr2-800 !
dann solltest du das nächste mla schreiben dass du die dinger mit 667 bertreibst. dann gibts auch keine mißverstandnisse !
denn mit 800 (pc-6400) lese ich bei dir das du mit cr-2 fährst. denn bei dem takt machen die kein cr-1 mehr.
und das mdt keine hohe Vdimm vertragen wußte ich nicht.
gruss
@xrobberx: Ist doch klar, bei einem Teiler von 1:1 (FSB 333) = RAM-Takt: 333 bzw. 667. Der RAM bleibt trotzdem PC-6400er, auch wenn er unter den Spezifikationen betrieben wird. Es war halt kein Platz mehr für die @667 MHz Anmerkung in der Signatur. Habs jetzt extra für dich mal ergänzt ;)
Es ging mir auch nur darum, euch klarzumachen, das schärfere Timinigs bei geringerem Takt eine bessere Performance liefern als hohe Timings bei hohem Takt. Dies konnte ich durch obige Benches recht gut belegen. Auf Wunsch liefere ich auch noch Aquamark 3 und 3DMark Ergebnisse mit beiden Konfigurationen.
