Power_state_driver_failure
da_dennis
Jan. 2014
Hallo Leute.
Habe seit ein paar Tagen immer wieder einen Bluescreen wo mir der POWER_STATE_DRIVER_FAILURE mitgeteilt wird. Zudem braucht mein Laptop seit genau dieser Zeit immer sehr lange zum hochfahren. Mein Betriebssytsem ist Win 8.
Hier der Dump:
Microsoft (R) Windows Debugger Version 6.2.9200.20512 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Bitmap Dump File: Full address space is available
Symbol search path is: SRV*C:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 8 Kernel Version 9200 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 9200.16581.amd64fre.win8_gdr.130410-1505
Machine Name:
Kernel base = 0xfffff801`7c070000 PsLoadedModuleList = 0xfffff801`7c33ca20
Debug session time: Thu Jan 9 17:03:45.037 2014 (UTC + 1:00)
System Uptime: 0 days 19:11:18.900
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 9F, {3, fffffa8006bcf060, fffff8017da997f0, fffffa8007c57670}
Probably caused by : pci.sys
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_POWER_STATE_FAILURE (9f)
A driver has failed to complete a power IRP within a specific time (usually 10 minutes).
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: fffffa8006bcf060, Physical Device Object of the stack
Arg3: fffff8017da997f0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa8007c57670, The blocked IRP
Debugging Details:
DRVPOWERSTATE_SUBCODE: 3
IMAGE_NAME: pci.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 5010ab1f
MODULE_NAME: pci
FAULTING_MODULE: fffff88000efc000 pci
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
BUGCHECK_STR: 0x9F
PROCESS_NAME: System
CURRENT_IRQL: 2
TAG_NOT_DEFINED_c000000f: FFFFF8017DA9FFB0
STACK_TEXT:
fffff801`7da997b8 fffff801`7c2063a2 : 00000000`0000009f 00000000`00000003 fffffa80`06bcf060 fffff801`7da997f0 : nt!KeBugCheckEx
fffff801`7da997c0 fffff801`7c2063d5 : fffffa80`0de8af00 fffffa80`0b1e97b0 fffff801`7da99939 fffff801`7c194084 : nt!PopIrpWatchdogBugcheck+0xe2
fffff801`7da99820 fffff801`7c0f31ea : fffffa80`0b1e97b0 fffff801`7da99939 00000000`00000001 fffff880`03002180 : nt!PopIrpWatchdog+0x32
fffff801`7da99870 fffff801`7c0f1655 : 00000000`00000000 fffff801`7c0f2cff 00000000`00140001 fffff801`7c36c640 : nt!KiProcessExpiredTimerList+0x22a
fffff801`7da999a0 fffff801`7c0f3668 : fffff801`7c368180 fffff801`7c36af80 00000000`00000004 00000000`0028358e : nt!KiExpireTimerTable+0xa9
fffff801`7da99a40 fffff801`7c0f2a06 : fffffa80`00000000 00001f80`00360080 00000000`00000000 00000000`00000002 : nt!KiTimerExpiration+0xc8
fffff801`7da99af0 fffff801`7c0f39ba : fffff801`7c368180 fffff801`7c368180 00000000`001a3db0 fffff801`7c3c2880 : nt!KiRetireDpcList+0x1f6
fffff801`7da99c60 00000000`00000000 : fffff801`7da9a000 fffff801`7da94000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
FAILURE_BUCKET_ID: 0x9F_3_iaStorA_IMAGE_pci.sys
Schon mal Danke für eure Hilfe!:)
Im BIOS ist was verstellt ?
SATA-Mode von IDE auf AHCI oder umgekehrt verstellt ?
Also bewusst verstellt habe ich nichts. Muss allerdings auch zugeben, dass Computer nicht meine große Stärke sind. Was genau muss ich jetzt tun? Oder braucht ihr noch irgendwelche Informationen?
installiere mal den Treiber, wenn das nix bringt, dann lad die neuen dmp Dateien hoch.
Screenshot (10).jpg Screenshot (11).jpg Screenshot (12).jpg Screenshot (13).jpg
So schauts aus. Ich weiß nicht wie ich diese .sys installieren soll, da kommt jedes mal diese Meldung.
Installiere den Treiber über die Setup.exe. Du hast den Floppy Treiber geladen, den man beim Setup von Windows angeben kann.
Zunächst hat alles geklappt doch seit heute habe ich wieder das gleiche Problem:
Built by: 9200.16628.amd64fre.win8_gdr.130531-1504
Machine Name:
Kernel base = 0xfffff800`3f48a000 PsLoadedModuleList = 0xfffff800`3f756a20
Debug session time: Tue Jan 14 23:55:38.606 2014 (UTC + 1:00)
System Uptime: 0 days 1:45:18.464
BugCheck 9F, {3, fffffa800775c060, fffff8003e6ac7f0, fffffa80077313c0}
*** ERROR: Module load completed but symbols could not be loaded for iaStorA.sys
Probably caused by : iaStorA.sys
0: kd> !analyze -v
Arguments:
Arg2: fffffa800775c060, Physical Device Object of the stack
Arg3: fffff8003e6ac7f0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa80077313c0, The blocked IRP
Debugging Details:
DRIVER_OBJECT: fffffa8007681e60
IMAGE_NAME: iaStorA.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 526ed3ee
MODULE_NAME: iaStorA
FAULTING_MODULE: fffff880016ad000 iaStorA
BUGCHECK_STR: 0x9F
CURRENT_IRQL: 2
TAG_NOT_DEFINED_c000000f: FFFFF8003E6B2FB0
STACK_TEXT:
fffff800`3e6ac7b8 fffff800`3f620722 : 00000000`0000009f 00000000`00000003 fffffa80`0775c060 fffff800`3e6ac7f0 : nt!KeBugCheckEx
fffff800`3e6ac7c0 fffff800`3f620755 : fffffa80`079e7ba0 fffffa80`069c2510 00000000`00000007 fffff800`3f5ae0a0 : nt!PopIrpWatchdogBugcheck+0xe2
fffff800`3e6ac820 fffff800`3f50d1ea : fffffa80`079e7bd8 fffff800`3e6ac939 00000000`00000001 fffff880`02e00f45 : nt!PopIrpWatchdog+0x32
fffff800`3e6ac870 fffff800`3f50b655 : 00000000`00000000 fffff800`3f50ccff 00000000`00140001 fffff800`3f786540 : nt!KiProcessExpiredTimerList+0x22a
fffff800`3e6ac9a0 fffff800`3f50d668 : fffff800`3f782180 fffff800`3f784f80 00000000`0000000b 00000000`0003ad86 : nt!KiExpireTimerTable+0xa9
fffff800`3e6aca40 fffff800`3f50ca06 : fffffa80`00000000 00001f80`00780080 00000000`00000000 00000000`00000002 : nt!KiTimerExpiration+0xc8
fffff800`3e6acaf0 fffff800`3f50d9ba : fffff800`3f782180 fffff800`3f782180 00000000`001a3db0 fffff800`3f7dc880 : nt!KiRetireDpcList+0x1f6
fffff800`3e6acc60 00000000`00000000 : fffff800`3e6ad000 fffff800`3e6a7000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND: kb
FAILURE_BUCKET_ID: 0x9F_3_POWER_DOWN_IMAGE_iaStorA.sys
0: kd> !analyze -v
Arguments:
Debugging Details:
BUGCHECK_STR: 0x9F
CURRENT_IRQL: 2
STACK_TEXT:
STACK_COMMAND: kb
0: kd> !analyze -v
Arguments:
Debugging Details:
BUGCHECK_STR: 0x9F
CURRENT_IRQL: 2
STACK_TEXT:
STACK_COMMAND: kb
0: kd> !analyze -v
Arguments:
Debugging Details:
