10tacle
Admiral
- Juni 2003
Quelle: http://www.theinquirer.net/?article=19313AN NVIDIA OFFICIAL document we've seen has revealed some dark secrets of its currently shipping chipset. Three weeks ago we wrote a story about the Nforce 4 A01 silicon problem with 5X Hyper transport, which you can read here.
While an earlier Nvidia communication implied it will fix this issue in A02 silicon it hasn't managed to do that yet. The problem will be fixed in A03 silicon.
All of the early Nforce 4 motherboards that you will get from now till A03 silicon will be limited to 4X HT. For the record, Nforce 3 250 has 5X HT that is working without any problems. You sort of need that to unleash the full power of Athlon 64 939 CPUs that can use 5X and 1000 MHz HT.
Nvidia discovered that its Hypertransport RX input receiver pads have sensitivity that's higher than acceptable to inbound inter symbol interference. Nvidia continued: "This can cause degradation of signal integrity which prevents achieving 5X speed."
A workaround is very simple. You just limit your board to 4X or should we say 800 MHz and not the 1000 MHz that 5X should give.
Nvidia also has some PCIe problems that will be fixed in A03 silicon, whenever it arrives.
So wie es aussieht werden die ersten Boards mit nForce 4 nur 800MHz HT unterstützen, desweiteren gibt es noch kleine Probleme mit PCIe. Müssen wir alle wohl auf das neue Stepping warten A03.
Och menno, ich zähle doch schon die Tage und jetzt das. Bin mal gespannt woran man erkennt um welche Revision es sich handelt. Hab kein Bock ständig Boards zurück zu schicken weil sie die falsche Revision haben.
