kalleberlin
- Feb. 2005
hi liebe leute
ich will in meinem windows xp rechner eine samba freigabe öffen. nur klappt das nich weil xp immer ein passwort für den user gast haben will...den user gast hab ich aber gar nicht angelegt und ändern kann ich den benutzer der sich "einloggen" will auch nicht da es grau unterlegt ist...ich denke aber mal das es an meiner konfigurationliegt. hier mal mein smb.conf
hoffentlich könnt ihr mir helfen :-D
gruß kalle
; /etc/smb.conf
; Copyright (c) 1999 SuSE GmbH Nuernberg, Germany.
[global]
workgroup = berger
guest account = nobody
keep alive = 30
os level = 2
kernel oplocks = false
security = user
; Uncomment the following, if you want to use an existing
; NT-Server to authenticate users, but don't forget that
; you also have to create them locally!!!
; security = server
; password server = 192.168.1.10
; encrypt passwords = yes
printing = bsd
printcap name = /etc/printcap
load printers = yes
socket options = TCP_NODELAY
map to guest = Bad User
; Uncomment this, if you want to integrate your server
; into an existing net e.g. with NT-WS to prevent nettraffic
; local master = no
; Please uncomment the following entry and replace the
; ip number and netmask with the correct numbers for
; your ethernet interface.
; interfaces = 192.168.1.1/255.255.255.0
; If you want Samba to act as a wins server, please set
; 'wins support = yes'
wins support = no
; If you want Samba to use an existing wins server,
; please uncomment the following line and replace
; the dummy with the wins server's ip number.
; wins server = 192.168.1.1
; Do you wan't samba to act as a logon-server for
; your windows 95/98 clients, so uncomment the
; following:
; logon script =%U.bat
; domain logons = yes
; domain master = yes
; [netlogon]
; path = /netlogon
[homes]
comment = Heimatverzeichnis
browseable = no
read only = no
create mode = 0750
[webserver]
comment = Webserver
browseable = yes
writeable = yes
public = yes
path = /etc/httpd/htdocs
guest ok = yes
; The following share gives all users access to the Server's CD drive,
; assuming it is mounted under /cd. To enable this share, please remove
; the semicolons before the lines
; [cdrom]
; comment = Linux CD-ROM
; path = /cdrom
; read only = yes
; locking = no
[printers]
comment = All Printers
browseable = no
printable = yes
public = no
read only = yes
create mode = 0700
directory = /tmp
gruß kalle
