ich denke mein SATA platte am onboard controller schöpft nicht ihre voll leistung da ich
kann mir jmd folgende sisift sandra meldung erjklaeren ?! :
Warning W231 - The IOQD (Host Bus In-Order Queue Depth) is set too low, most likely 1, i.e. no queue. This indicates the depth of the host bus pipelining; thus 1 indicates that no pipelining is to be done on the bus. This reduces the performance of the host bus which is crucial to performance. P6 (Pentium Pro, II, III, Celeron) has an IOQD depth of 8 while the P4 has an IOQD of 12. Most chipsets have an IOQD of 4 or more.
Fix: Check that BIOS settings were not reset or set to Fail-Safe defaults. Reset them to Optimised or Normal settings.
-> was ist IOQD , was / wo stelle ich fuer mein system ein ?!
dann das :
Warning W3105 - Current block size not optimal, i.e. not highest supported. This affects transfer performance.
Fix: Check BIOS settings and set block size to maximum. Some advanced controllers allow you to set such settings also.
-> ich verstehe das im bios irgendwas hoeher gestellt werden muss doch ich weiss ich nicht was "block size" sein soll! weiss jmd was gemeint ist !?
das ist auch noch zu irgendeiner transferrate ! ich hab kein plan welche gemeint ist bzw wo man das einstellen kann , hab ueberall gesucht , nichts gefunden ! :
Warning W3104 - Current transfer mode not optimal, i.e. not highest supported. This affects drive performance. If the controller is also capable of the highest supported transfer mode, there is no reason not to use it.
Fix: First check controller supported transfer modes. Then check the mode the driver for the controller/BIOS is set to use and modify; some default to a lower mode for compatibility. You may need to install newer drivers if the current drivers do not natively support the controller (especially for RAID). You may need to update the controller BIOS or drive firmware, if the mode does not stick. If data corruption occurs verify the cable and consider switching (if any) drives on the same channel onto other channels.
If the built-in controller does not support the mode, consider using the on-board/RAID controller or even disable the built-in controller and install a new controller.
wo GENAU kann ich die ganzen transferraten / oder einfach alles was mit SATA platte und deren geschwindigkeiten VERAENDERN ... ?! kann im bios IDEmaster3:SP0812 (das ist meine SATA platte) nur den "ACCESS MODE" auf large stellen , mehr is da nicht zu machen!
dann noch die fragen :
1.wie lege ich die auslagerungsdatei am optimalsten ? wie gross ? @c: win / d:spiele
2.und nochwas : ist eine SATA Platte eine SCSI platte ?!
hab hier was in der windows-hilfe gefunden @problembehandlung ! :
Ist die SCSI-Kette terminiert?
Jedes SCSI-Gerät verfügt über zwei Anschlüsse: einer wird mit dem Computer (oder dem vorangehenden Gerät in der Kette) verbunden, und mit dem anderen wird die Verbindung zum nachfolgenden Gerät in der Kette hergestellt.
Beim letzten Gerät in der Kette muss an den zweiten Anschluss ein SCSI-Terminator angeschlossen werden. Selbst wenn nur ein SCSI-Gerät vorhanden ist, stellt dieses das letzte Gerät der Kette dar und muss mit einem Terminator versehen werden.
Wenn das letzte Gerät der SCSI-Kette nicht terminiert ist, stecken Sie einen Terminator auf den freien Anschluss.
dann das :
