... /ldbdump.js:1
var Module=typeof Module!="undefined"?Module:{};var ENVIRONMENT_IS_WEB=typeof window=="object";var ENVIRONMENT_IS_WORKER=typeof WorkerGlobalScope!="undefined";var ENVIRONMENT_IS_NODE=typeof process=="object"&&typeof process.versions=="object"&&typeof process.versions.node=="string"&&process.type!="renderer";if(ENVIRONMENT_IS_NODE){}var moduleOverrides={...Module};var arguments_=[];var thisProgram="./this.program";var quit_=(status,toThrow)=>{throw toThrow};var scriptDirectory="";function locateFile(path){if(Module["locateFile"]){return Module["locateFile"](path,scriptDirectory)}return scriptDirectory+path}var readAsync,readBinary;if(ENVIRONMENT_IS_NODE){var fs=require("fs");var nodePath=require("path");scriptDirectory=__dirname+"/";readBinary=filename=>{filename=isFileURI(filename)?new URL(filename):filename;var ret=fs.readFileSync(filename);return ret};readAsync=async(filename,binary=true)=>{filename=isFileURI(filename)?new URL(filename):filename;var ret=fs.readFileSync(filename,binary?undefined:"utf8");return ret};if(!Module["thisProgram"]&&process.argv.length>1){thisProgram=process.argv[1].replace(/\\/g,"/")}arguments_=process.argv.slice(2);if(typeof module!="undefined"){module["exports"]=Module}quit_=(status,toThrow)=>{process.exitCode=status;throw toThrow}}else if(ENVIRONMENT_IS_WEB||ENVIRONMENT_IS_WORKER){if(ENVIRONMENT_IS_WORKER){scriptDirectory=self.location.href}else if(typeof document!="undefined"&&document.currentScript){scriptDirectory=document.currentScript.src}if(scriptDirectory.startsWith("blob:")){scriptDirectory=""}else{scriptDirectory=scriptDirectory.slice(0,scriptDirectory.replace(/[?#].*/,"").lastIndexOf("/")+1)}{if(ENVIRONMENT_IS_WORKER){readBinary=url=>{var xhr=new XMLHttpRequest;xhr.open("GET",url,false);xhr.responseType="arraybuffer";xhr.send(null);return new Uint8Array(xhr.response)}}readAsync=async url=>{if(isFileURI(url)){return new Promise((resolve,reject)=>{var xhr=new XMLHttpRequest;xhr.open("GET",url,true);xhr.responseType="arraybuffer";xhr.onload=()=>{if(xhr.status==200||xhr.status==0&&xhr.response){resolve(xhr.response);return}reject(xhr.status)};xhr.onerror=reject;xhr.send(null)})}var response=await fetch(url,{credentials:"same-origin"});if(response.ok){return response.arrayBuffer()}throw new Error(response.status+" : "+response.url)}}}else{}var out=Module["print"]||console.log.bind(console);var err=Module["printErr"]||console.error.bind(console);Object.assign(Module,moduleOverrides);moduleOverrides=null;if(Module["arguments"])arguments_=Module["arguments"];if(Module["thisProgram"])thisProgram=Module["thisProgram"];var wasmBinary=Module["wasmBinary"];var wasmMemory;var ABORT=false;var EXITSTATUS;var HEAP8,HEAPU8,HEAP16,HEAPU16,HEAP32,HEAPU32,HEAPF32,HEAP64,HEAPU64,HEAPF64;var runtimeInitialized=false;var runtimeExited=false;var isFileURI=filename=>filename.startsWith("file://");function updateMemoryViews(){var b=wasmMemory.buffer;Module["HEAP8"]=HEAP8=new Int8Array(b);Module["HEAP16"]=HEAP16=new Int16Array(b);Module["HEAPU8"]=HEAPU8=new Uint8Array(b);Module["HEAPU16"]=HEAPU16=new Uint16Array(b);Module["HEAP32"]=HEAP32=new Int32Array(b);Module["HEAPU32"]=HEAPU32=new Uint32Array(b);Module["HEAPF32"]=HEAPF32=new Float32Array(b);Module["HEAPF64"]=HEAPF64=new Float64Array(b);Module["HEAP64"]=HEAP64=new BigInt64Array(b);Module["HEAPU64"]=HEAPU64=new BigUint64Array(b)}function preRun(){if(Module["preRun"]){if(typeof Module["preRun"]=="function")Module["preRun"]=[Module["preRun"]];while(Module["preRun"].length){addOnPreRun(Module["preRun"].shift())}}callRuntimeCallbacks(onPreRuns)}function initRuntime(){runtimeInitialized=true;if(!Module["noFSInit"]&&!FS.initialized)FS.init();TTY.init();wasmExports["E"]();FS.ignorePermissions=false}function preMain(){}function exitRuntime(){___funcs_on_exit();FS.quit();TTY.shutdown();runtimeExited=true}function postRun(){if(Module["postRun"]){if(typeof Module["postRun"]=="function")Module["postRun"]=[Module["postRun"]];while(Module["postRun"].length){addOnPostRun(Module["postRun"].shift())}}callRuntimeCallbacks(onPostRuns)}var runDependencies=0;var dependenciesFulfilled=null;function getUniqueRunDependency(id){return id}function addRunDependency(id){runDependencies++;Module["monitorRunDependencies"]?.(runDependencies)}function removeRunDependency(id){runDependencies--;Module["monitorRunDependencies"]?.(runDependencies);if(runDependencies==0){if(dependenciesFulfilled){var callback=dependenciesFulfilled;dependenciesFulfilled=null;callback()}}}function abort(what){Module["onAbort"]?.(what);what="Aborted("+what+")";err(what);ABORT=true;what+=". Build with -sASSERTIONS for more info.";var e=new WebAssembly.RuntimeError(what);throw e}var wasmBinaryFile;function findWasmBinary(){return locateFile("ldbdump.wasm")}function getBinarySync(file){if(file==wasmBinaryFile&&wasmBinary){return new Uint8Array(wasmBinary)}if(readBinary){return readBinary(file)}throw"both async and sync fetching of the wasm failed"}async function getWasmBinary(binaryFile){if(!wasmBinary){try{var response=await readAsync(binaryFile);return new Uint8Array(response)}catch{}}return getBinarySync(binaryFile)}async function instantiateArrayBuffer(binaryFile,imports){try{var binary=await getWasmBinary(binaryFile);var instance=await WebAssembly.instantiate(binary,imports);return instance}catch(reason){err(`failed to asynchronously prepare wasm: ${reason}`);abort(reason)}}async function instantiateAsync(binary,binaryFile,imports){if(!binary&&typeof WebAssembly.instantiateStreaming=="function"&&!isFileURI(binaryFile)&&!ENVIRONMENT_IS_NODE){try{var response=fetch(binaryFile,{credentials:"same-origin"});var instantiationResult=await WebAssembly.instantiateStreaming(response,imports);return instantiationResult}catch(reason){err(`wasm streaming compile failed: ${reason}`);err("falling back to ArrayBuffer instantiation")}}return instantiateArrayBuffer(binaryFile,imports)}function getWasmImports(){return{a:wasmImports}}async function createWasm(){function receiveInstance(instance,module){wasmExports=instance.exports;wasmMemory=wasmExports["D"];updateMemoryViews();removeRunDependency("wasm-instantiate");return wasmExports}addRunDependency("wasm-instantiate");function receiveInstantiationResult(result){return receiveInstance(result["instance"])}var info=getWasmImports();if(Module["instantiateWasm"]){return new Promise((resolve,reject)=>{Module["instantiateWasm"](info,(mod,inst)=>{receiveInstance(mod,inst);resolve(mod.exports)})})}wasmBinaryFile??=findWasmBinary();var result=await instantiateAsync(wasmBinary,wasmBinaryFile,info);var exports=receiveInstantiationResult(result);return exports}class ExitStatus{name="ExitStatus";constructor(status){this.message=`Program terminated with exit(${status})`;this.status=status}}var callRuntimeCallbacks=callbacks=>{while(callbacks.length>0){callbacks.shift()(Module)}};var onPostRuns=[];var addOnPostRun=cb=>onPostRuns.unshift(cb);var onPreRuns=[];var addOnPreRun=cb=>onPreRuns.unshift(cb);function getValue(ptr,type="i8"){if(type.endsWith("*"))type="*";switch(type){case"i1":return HEAP8[ptr];case"i8":return HEAP8[ptr];case"i16":return HEAP16[ptr>>1];case"i32":return HEAP32[ptr>>2];case"i64":return HEAP64[ptr>>3];case"float":return HEAPF32[ptr>>2];case"double":return HEAPF64[ptr>>3];case"*":return HEAPU32[ptr>>2];default:abort(`invalid type for getValue: ${type}`)}}var noExitRuntime=Module["noExitRuntime"]||false;var UTF8Decoder=typeof TextDecoder!="undefined"?new TextDecoder:undefined;var UTF8ArrayToString=(heapOrArray,idx=0,maxBytesToRead=NaN)=>{var endIdx=idx+maxBytesToRead;var endPtr=idx;while(heapOrArray[endPtr]&&!(endPtr>=endIdx))++endPtr;if(endPtr-idx>16&&heapOrArray.buffer&&UTF8Decoder){return UTF8Decoder.decode(heapOrArray.subarray(idx,endPtr))}var str="";while(idx<endPtr){var u0=heapOrArray[idx++];if(!(u0&128)){str+=String.fromCharCode(u0);continue}var u1=heapOrArray[idx++]&63;if((u0&224)==192){str+=String.fromCharCode((u0&31)<<6|u1);continue}var u2=heapOrArray[idx++]&63;if((u0&240)==224){u0=(u0&15)<<12|u1<<6|u2}else{u0=(u0&7)<<18|u1<<12|u2<<6|heapOrArray[idx++]&63}if(u0<65536){str+=String.fromCharCode(u0)}else{var ch=u0-65536;str+=String.fromCharCode(55296|ch>>10,56320|ch&1023)}}return str};var UTF8ToString=(ptr,maxBytesToRead)=>ptr?UTF8ArrayToString(HEAPU8,ptr,maxBytesToRead):"";var ___assert_fail=(condition,filename,line,func)=>abort(`Assertion failed: ${UTF8ToString(condition)}, at: `+[filename?UTF8ToString(filename):"unknown filename",line,func?UTF8ToString(func):"unknown function"]);class ExceptionInfo{constructor(excPtr){this.excPtr=excPtr;this.ptr=excPtr-24}set_type(type){HEAPU32[this.ptr+4>>2]=type}get_type(){return HEAPU32[this.ptr+4>>2]}set_destructor(destructor){HEAPU32[this.ptr+8>>2]=destructor}get_destructor(){return HEAPU32[this.ptr+8>>2]}set_caught(caught){caught=caught?1:0;HEAP8[this.ptr+12]=caught}get_caught(){return HEAP8[this.ptr+12]!=0}set_rethrown(rethrown){rethrown=rethrown?1:0;HEAP8[this.ptr+13]=rethrown}get_rethrown(){return HEAP8[this.ptr+13]!=0}init(type,destructor){this.set_adjusted_ptr(0);this.set_type(type);this.set_destructor(destructor)}set_adjusted_ptr(adjustedPtr){HEAPU32[this.ptr+16>>2]=adjustedPtr}get_adjusted_ptr(){return HEAPU32[this.ptr+16>>2]}}var exceptionLast=0;var uncaughtExceptionCount=0;var ___cxa_throw=(ptr,type,destructor)=>{var info=new ExceptionInfo(ptr);info.init(type,destructor);exceptionLast=ptr;uncaughtExceptionCount++;throw exceptionLast};var PATH={isAbs:path=>path.charAt(0)==="/",splitPath:filename=>{var splitPathRe=/^(\/?|)([\s\S]*?)((?:\.{1,2}|[^\/]+?|)(\.[^.\/]*|))(?:[\/]*)$/;return splitPathRe.exec(filename).slice(1)},normalizeArray:(parts,allowAboveRoot)=>{var up=0;for(var i=parts.length-1;i>=0;i--){var last=parts[i];if(last==="."){parts.splice(i,1)}else if(last===".."){parts.splice(i,1);up++}else if(up){parts.splice(i,1);up--}}if(allowAboveRoot){for(;up;up--){parts.unshift("..")}}return parts},normalize:path=>{var isAbsolute=PATH.isAbs(path),trailingSlash=path.slice(-1)==="/";path=PATH.normalizeArray(path.split("/").filter(p=>!!p),!isAbsolute).join("/");if(!path&&!isAbsolute){path="."}if(path&&trailingSlash){path+="/"}return(isAbsolute?"/":"")+path},dirname:path=>{var result=PATH.splitPath(path),root=result[0],dir=result[1];if(!root&&!dir){return"."}if(dir){dir=dir.slice(0,-1)}return root+dir},basename:path=>path&&path.match(/([^\/]+|\/)\/*$/)[1],join:(...paths)=>PATH.normalize(paths.join("/")),join2:(l,r)=>PATH.normalize(l+"/"+r)};var initRandomFill=()=>{if(ENVIRONMENT_IS_NODE){var nodeCrypto=require("crypto");return view=>nodeCrypto.randomFillSync(view)}return view=>crypto.getRandomValues(view)};var randomFill=view=>{(randomFill=initRandomFill())(view)};var PATH_FS={resolve:(...args)=>{var resolvedPath="",resolvedAbsolute=false;for(var i=args.length-1;i>=-1&&!resolvedAbsolute;i--){var path=i>=0?args[i]:FS.cwd();if(typeof path!="string"){throw new TypeError("Arguments to path.resolve must be strings")}else if(!path){return""}resolvedPath=path+"/"+resolvedPath;resolvedAbsolute=PATH.isAbs(path)}resolvedPath=PATH.normalizeArray(resolvedPath.split("/").filter(p=>!!p),!resolvedAbsolute).join("/");return(resolvedAbsolute?"/":"")+resolvedPath||"."},relative:(from,to)=>{from=PATH_FS.resolve(from).slice(1);to=PATH_FS.resolve(to).slice(1);function trim(arr){var start=0;for(;start<arr.length;start++){if(arr[start]!=="")break}var end=arr.length-1;for(;end>=0;end--){if(arr[end]!=="")break}if(start>end)return[];return arr.slice(start,end-start+1)}var fromParts=trim(from.split("/"));var toParts=trim(to.split("/"));var length=Math.min(fromParts.length,toParts.length);var samePartsLength=length;for(var i=0;i<length;i++){if(fromParts[i]!==toParts[i]){samePartsLength=i;break}}var outputParts=[];for(var i=samePartsLength;i<fromParts.length;i++){outputParts.push("..")}outputParts=outputParts.concat(toParts.slice(samePartsLength));return outputParts.join("/")}};var FS_stdin_getChar_buffer=[];var lengthBytesUTF8=str=>{var len=0;for(var i=0;i<str.length;++i){var c=str.charCodeAt(i);if(c<=127){len++}else if(c<=2047){len+=2}else if(c>=55296&&c<=57343){len+=4;++i}else{len+=3}}return len};var stringToUTF8Array=(str,heap,outIdx,maxBytesToWrite)=>{if(!(maxBytesToWrite>0))return 0;var startIdx=outIdx;var endIdx=outIdx+maxBytesToWrite-1;for(var i=0;i<str.length;++i){var u=str.charCodeAt(i);if(u>=55296&&u<=57343){var u1=str.charCodeAt(++i);u=65536+((u&1023)<<10)|u1&1023}if(u<=127){if(outIdx>=endIdx)break;heap[outIdx++]=u}else if(u<=2047){if(outIdx+1>=endIdx)break;heap[outIdx++]=192|u>>6;heap[outIdx++]=128|u&63}else if(u<=65535){if(outIdx+2>=endIdx)break;heap[outIdx++]=224|u>>12;heap[outIdx++]=128|u>>6&63;heap[outIdx++]=128|u&63}else{if(outIdx+3>=endIdx)break;heap[outIdx++]=240|u>>18;heap[outIdx++]=128|u>>12&63;heap[outIdx++]=128|u>>6&63;heap[outIdx++]=128|u&63}}heap[outIdx]=0;return outIdx-startIdx};var intArrayFromString=(stringy,dontAddNull,length)=>{var len=length>0?length:lengthBytesUTF8(stringy)+1;var u8array=new Array(len);var numBytesWritten=stringToUTF8Array(stringy,u8array,0,u8array.length);if(dontAddNull)u8array.length=numBytesWritten;return u8array};var FS_stdin_getChar=()=>{if(!FS_stdin_getChar_buffer.length){var result=null;if(ENVIRONMENT_IS_NODE){var BUFSIZE=256;var buf=Buffer.alloc(BUFSIZE);var bytesRead=0;var fd=process.stdin.fd;try{bytesRead=fs.readSync(fd,buf,0,BUFSIZE)}catch(e){if(e.toString().includes("EOF"))bytesRead=0;else throw e}if(bytesRead>0){result=buf.slice(0,bytesRead).toString("utf-8")}}else if(typeof window!="undefined"&&typeof window.prompt=="function"){result=window.prompt("Input: ");if(result!==null){result+="\n"}}else{}if(!result){return null}FS_stdin_getChar_buffer=intArrayFromString(result,true)}return FS_stdin_getChar_buffer.shift()};var TTY={ttys:[],init(){},shutdown(){},register(dev,ops){TTY.ttys[dev]={input:[],output:[],ops};FS.registerDevice(dev,TTY.stream_ops)},stream_ops:{open(stream){var tty=TTY.ttys[stream.node.rdev];if(!tty){throw new FS.ErrnoError(43)}stream.tty=tty;stream.seekable=false},close(stream){stream.tty.ops.fsync(stream.tty)},fsync(stream){stream.tty.ops.fsync(stream.tty)},read(stream,buffer,offset,length,pos){if(!stream.tty||!stream.tty.ops.get_char){throw new FS.ErrnoError(60)}var bytesRead=0;for(var i=0;i<length;i++){var result;try{result=stream.tty.ops.get_char(stream.tty)}catch(e){throw new FS.ErrnoError(29)}if(result===undefined&&bytesRead===0){throw new FS.ErrnoError(6)}if(result===null||result===undefined)break;bytesRead++;buffer[offset+i]=result}if(bytesRead){stream.node.atime=Date.now()}return bytesRead},write(stream,buffer,offset,length,pos){if(!stream.tty||!stream.tty.ops.put_char){throw new FS.ErrnoError(60)}try{for(var i=0;i<length;i++){stream.tty.ops.put_char(stream.tty,buffer[offset+i])}}catch(e){throw new FS.ErrnoError(29)}if(length){stream.node.mtime=stream.node.ctime=Date.now()}return i}},default_tty_ops:{get_char(tty){return FS_stdin_getChar()},put_char(tty,val){if(val===null||val===10){out(UTF8ArrayToString(tty.output));tty.output=[]}else{if(val!=0)tty.output.push(val)}},fsync(tty){if(tty.output?.length>0){out(UTF8ArrayToString(tty.output));tty.output=[]}},ioctl_tcgets(tty){return{c_iflag:25856,c_oflag:5,c_cflag:191,c_lflag:35387,c_cc:[3,28,127,21,4,0,1,0,17,19,26,0,18,15,23,22,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]}},ioctl_tcsets(tty,optional_actions,data){return 0},ioctl_tiocgwinsz(tty){return[24,80]}},default_tty1_ops:{put_char(tty,val){if(val===null||val===10){err(UTF8ArrayToString(tty.output));tty.output=[]}else{if(val!=0)tty.output.push(val)}},fsync(tty){if(tty.output?.length>0){err(UTF8ArrayToString(tty.output));tty.output=[]}}}};var zeroMemory=(ptr,size)=>HEAPU8.fill(0,ptr,ptr+size);var alignMemory=(size,alignment)=>Math.ceil(size/alignment)*alignment;var mmapAlloc=size=>{size=alignMemory(size,65536);var ptr=_emscripten_builtin_memalign(65536,size);if(ptr)zeroMemory(ptr,size);return ptr};var MEMFS={ops_table:null,mount(mount){return MEMFS.createNode(null,"/",16895,0)},createNode(parent,name,mode,dev){if(FS.isBlkdev(mode)||FS.isFIFO(mode)){throw new FS.ErrnoError(63)}MEMFS.ops_table||={dir:{node:{getattr:MEMFS.node_ops.getattr,setattr:MEMFS.node_ops.setattr,lookup:MEMFS.node_ops.lookup,mknod:MEMFS.node_ops.mknod,rename:MEMFS.node_ops.rename,unlink:MEMFS.node_ops.unlink,rmdir:MEMFS.node_ops.rmdir,readdir:MEMFS.node_ops.readdir,symlink:MEMFS.node_ops.symlink},stream:{llseek:MEMFS.stream_ops.llseek}},file:{node:{getattr:MEMFS.node_ops.getattr,setattr:MEMFS.node_ops.setattr},stream:{llseek:MEMFS.stream_ops.llseek,read:MEMFS.stream_ops.read,write:MEMFS.stream_ops.write,mmap:MEMFS.stream_ops.mmap,msync:MEMFS.stream_ops.msync}},link:{node:{getattr:MEMFS.node_ops.getattr,setattr:MEMFS.node_ops.setattr,readlink:MEMFS.node_ops.readlink},stream:{}},chrdev:{node:{getattr:MEMFS.node_ops.getattr,setattr:MEMFS.node_ops.setattr},stream:FS.chrdev_stream_ops}};var node=FS.createNode(parent,name,mode,dev);if(FS.isDir(node.mode)){node.node_ops=MEMFS.ops_table.dir.node;node.stream_ops=MEMFS.ops_table.dir.stream;node.contents={}}else if(FS.isFile(node.mode)){node.node_ops=MEMFS.ops_table.file.node;node.stream_ops=MEMFS.ops_table.file.stream;node.usedBytes=0;node.contents=null}else if(FS.isLink(node.mode)){node.node_ops=MEMFS.ops_table.link.node;node.stream_ops=MEMFS.ops_table.link.stream}else if(FS.isChrdev(node.mode)){node.node_ops=MEMFS.ops_table.chrdev.node;node.stream_ops=MEMFS.ops_table.chrdev.stream}node.atime=node.mtime=node.ctime=Date.now();if(parent){parent.contents[name]=node;parent.atime=parent.mtime=parent.ctime=node.atime}return node},getFileDataAsTypedArray(node){if(!node.contents)return new Uint8Array(0);if(node.contents.subarray)return node.contents.subarray(0,node.usedBytes);return new Uint8Array(node.contents)},expandFileStorage(node,newCapacity){var prevCapacity=node.contents?node.contents.length:0;if(prevCapacity>=newCapacity)return;var CAPACITY_DOUBLING_MAX=1024*1024;newCapacity=Math.max(newCapacity,prevCapacity*(prevCapacity<CAPACITY_DOUBLING_MAX?2:1.125)>>>0);if(prevCapacity!=0)newCapacity=Math.max(newCapacity,256);var oldContents=node.contents;node.contents=new Uint8Array(newCapacity);if(node.usedBytes>0)node.contents.set(oldContents.subarray(0,node.usedBytes),0)},resizeFileStorage(node,newSize){if(node.usedBytes==newSize)return;if(newSize==0){node.contents=null;node.usedBytes=0}else{var oldContents=node.contents;node.contents=new Uint8Array(newSize);if(oldContents){node.contents.set(oldContents.subarray(0,Math.min(newSize,node.usedBytes)))}node.usedBytes=newSize}},node_ops:{getattr(node){var attr={};attr.dev=FS.isChrdev(node.mode)?node.id:1;attr.ino=node.id;attr.mode=node.mode;attr.nlink=1;attr.uid=0;attr.gid=0;attr.rdev=node.rdev;if(FS.isDir(node.mode)){attr.size=4096}else if(FS.isFile(node.mode)){attr.size=node.usedBytes}else if(FS.isLink(node.mode)){attr.size=node.link.length}else{attr.size=0}attr.atime=new Date(node.atime);attr.mtime=new Date(node.mtime);attr.ctime=new Date(node.ctime);attr.blksize=4096;attr.blocks=Math.ceil(attr.size/attr.blksize);return attr},setattr(node,attr){for(const key of["mode","atime","mtime","ctime"]){if(attr[key]!=null){node[key]=attr[key]}}if(attr.size!==undefined){MEMFS.resizeFileStorage(node,attr.size)}},lookup(parent,name){throw MEMFS.doesNotExistError},mknod(parent,name,mode,dev){return MEMFS.createNode(parent,name,mode,dev)},rename(old_node,new_dir,new_name){var new_node;try{new_node=FS.lookupNode(new_dir,new_name)}catch(e){}if(new_node){if(FS.isDir(old_node.mode)){for(var i in new_node.contents){throw new FS.ErrnoError(55)}}FS.hashRemoveNode(new_node)}delete old_node.parent.contents[old_node.name];new_dir.contents[new_name]=old_node;old_node.name=new_name;new_dir.ctime=new_dir.mtime=old_node.parent.ctime=old_node.parent.mtime=Date.now()},unlink(parent,name){delete parent.contents[name];parent.ctime=parent.mtime=Date.now()},rmdir(parent,name){var node=FS.lookupNode(parent,name);for(var i in node.contents){throw new FS.ErrnoError(55)}delete parent.contents[name];parent.ctime=parent.mtime=Date.now()},readdir(node){return[".","..",...Object.keys(node.contents)]},symlink(parent,newname,oldpath){var node=MEMFS.createNode(parent,newname,511|40960,0);node.link=oldpath;return node},readlink(node){if(!FS.isLink(node.mode)){throw new FS.ErrnoError(28)}return node.link}},stream_ops:{read(stream,buffer,offset,length,position){var contents=stream.node.contents;if(position>=stream.node.usedBytes)return 0;var size=Math.min(stream.node.usedBytes-position,length);if(size>8&&contents.subarray){buffer.set(contents.subarray(position,position+size),offset)}else{for(var i=0;i<size;i++)buffer[offset+i]=contents[position+i]}return size},write(stream,buffer,offset,length,position,canOwn){if(buffer.buffer===HEAP8.buffer){canOwn=false}if(!length)return 0;var node=stream.node;node.mtime=node.ctime=Date.now();if(buffer.subarray&&(!node.contents||node.contents.subarray)){if(canOwn){node.contents=buffer.subarray(offset,offset+length);node.usedBytes=length;return length}else if(node.usedBytes===0&&position===0){node.contents=buffer.slice(offset,offset+length);node.usedBytes=length;return length}else if(position+length<=node.usedBytes){node.contents.set(buffer.subarray(offset,offset+length),position);return length}}MEMFS.expandFileStorage(node,position+length);if(node.contents.subarray&&buffer.subarray){node.contents.set(buffer.subarray(offset,offset+length),position)}else{for(var i=0;i<length;i++){node.contents[position+i]=buffer[offset+i]}}node.usedBytes=Math.max(node.usedBytes,position+length);return length},llseek(stream,offset,whence){var position=offset;if(whence===1){position+=stream.position}else if(whence===2){if(FS.isFile(stream.node.mode)){position+=stream.node.usedBytes}}if(position<0){throw new FS.ErrnoError(28)}return position},mmap(stream,length,position,prot,flags){if(!FS.isFile(stream.node.mode)){throw new FS.ErrnoError(43)}var ptr;var allocated;var contents=stream.node.contents;if(!(flags&2)&&contents&&contents.buffer===HEAP8.buffer){allocated=false;ptr=contents.byteOffset}else{allocated=true;ptr=mmapAlloc(length);if(!ptr){throw new FS.ErrnoError(48)}if(contents){if(position>0||position+length<contents.length){if(contents.subarray){contents=contents.subarray(position,position+length)}else{contents=Array.prototype.slice.call(contents,position,position+length)}}HEAP8.set(contents,ptr)}}return{ptr,allocated}},msync(stream,buffer,offset,length,mmapFlags){MEMFS.stream_ops.write(stream,buffer,0,length,offset,false);return 0}}};var asyncLoad=async url=>{var arrayBuffer=await readAsync(url);return new Uint8Array(arrayBuffer)};var FS_createDataFile=(parent,name,fileData,canRead,canWrite,canOwn)=>{FS.createDataFile(parent,name,fileData,canRead,canWrite,canOwn)};var preloadPlugins=Module["preloadPlugins"]||[];var FS_handledByPreloadPlugin=(byteArray,fullname,finish,onerror)=>{if(typeof Browser!="undefined")Browser.init();var handled=false;preloadPlugins.forEach(plugin=>{if(handled)return;if(plugin["canHandle"](fullname)){plugin["handle"](byteArray,fullname,finish,onerror);handled=true}});return handled};var FS_createPreloadedFile=(parent,name,url,canRead,canWrite,onload,onerror,dontCreateFile,canOwn,preFinish)=>{var fullname=name?PATH_FS.resolve(PATH.join2(parent,name)):parent;var dep=getUniqueRunDependency(`cp ${fullname}`);function processData(byteArray){function finish(byteArray){preFinish?.();if(!dontCreateFile){FS_createDataFile(parent,name,byteArray,canRead,canWrite,canOwn)}onload?.();removeRunDependency(dep)}if(FS_handledByPreloadPlugin(byteArray,fullname,finish,()=>{onerror?.();removeRunDependency(dep)})){return}finish(byteArray)}addRunDependency(dep);if(typeof url=="string"){asyncLoad(url).then(processData,onerror)}else{processData(url)}};var FS_modeStringToFlags=str=>{var flagModes={r:0,"r+":2,w:512|64|1,"w+":512|64|2,a:1024|64|1,"a+":1024|64|2};var flags=flagModes[str];if(typeof flags=="undefined"){throw new Error(`Unknown file open mode: ${str}`)}return flags};var FS_getMode=(canRead,canWrite)=>{var mode=0;if(canRead)mode|=292|73;if(canWrite)mode|=146;return mode};var ERRNO_CODES={EPERM:63,ENOENT:44,ESRCH:71,EINTR:27,EIO:29,ENXIO:60,E2BIG:1,ENOEXEC:45,EBADF:8,ECHILD:12,EAGAIN:6,EWOULDBLOCK:6,ENOMEM:48,EACCES:2,EFAULT:21,ENOTBLK:105,EBUSY:10,EEXIST:20,EXDEV:75,ENODEV:43,ENOTDIR:54,EISDIR:31,EINVAL:28,ENFILE:41,EMFILE:33,ENOTTY:59,ETXTBSY:74,EFBIG:22,ENOSPC:51,ESPIPE:70,EROFS:69,EMLINK:34,EPIPE:64,EDOM:18,ERANGE:68,ENOMSG:49,EIDRM:24,ECHRNG:106,EL2NSYNC:156,EL3HLT:107,EL3RST:108,ELNRNG:109,EUNATCH:110,ENOCSI:111,EL2HLT:112,EDEADLK:16,ENOLCK:46,EBADE:113,EBADR:114,EXFULL:115,ENOANO:104,EBADRQC:103,EBADSLT:102,EDEADLOCK:16,EBFONT:101,ENOSTR:100,ENODATA:116,ETIME:117,ENOSR:118,ENONET:119,ENOPKG:120,EREMOTE:121,ENOLINK:47,EADV:122,ESRMNT:123,ECOMM:124,EPROTO:65,EMULTIHOP:36,EDOTDOT:125,EBADMSG:9,ENOTUNIQ:126,EBADFD:127,EREMCHG:128,ELIBACC:129,ELIBBAD:130,ELIBSCN:131,ELIBMAX:132,ELIBEXEC:133,ENOSYS:52,ENOTEMPTY:55,ENAMETOOLONG:37,ELOOP:32,EOPNOTSUPP:138,EPFNOSUPPORT:139,ECONNRESET:15,ENOBUFS:42,EAFNOSUPPORT:5,EPROTOTYPE:67,ENOTSOCK:57,ENOPROTOOPT:50,ESHUTDOWN:140,ECONNREFUSED:14,EADDRINUSE:3,ECONNABORTED:13,ENETUNREACH:40,ENETDOWN:38,ETIMEDOUT:73,EHOSTDOWN:142,EHOSTUNREACH:23,EINPROGRESS:26,EALREADY:7,EDESTADDRREQ:17,EMSGSIZE:35,EPROTONOSUPPORT:66,ESOCKTNOSUPPORT:137,EADDRNOTAVAIL:4,ENETRESET:39,EISCONN:30,ENOTCONN:53,ETOOMANYREFS:141,EUSERS:136,EDQUOT:19,ESTALE:72,ENOTSUP:138,ENOMEDIUM:148,EILSEQ:25,EOVERFLOW:61,ECANCELED:11,ENOTRECOVERABLE:56,EOWNERDEAD:62,ESTRPIPE:135};var NODEFS={isWindows:false,staticInit(){NODEFS.isWindows=!!process.platform.match(/^win/);var flags=process.binding("constants")["fs"];NODEFS.flagsForNodeMap={1024:flags["O_APPEND"],64:flags["O_CREAT"],128:flags["O_EXCL"],256:flags["O_NOCTTY"],0:flags["O_RDONLY"],2:flags["O_RDWR"],4096:flags["O_SYNC"],512:flags["O_TRUNC"],1:flags["O_WRONLY"],131072:flags["O_NOFOLLOW"]}},convertNodeCode(e){var code=e.code;return ERRNO_CODES[code]},tryFSOperation(f){try{return f()}catch(e){if(!e.code)throw e;if(e.code==="UNKNOWN")throw new FS.ErrnoError(28);throw new FS.ErrnoError(NODEFS.convertNodeCode(e))}},mount(mount){return NODEFS.createNode(null,"/",NODEFS.getMode(mount.opts.root),0)},createNode(parent,name,mode,dev){if(!FS.isDir(mode)&&!FS.isFile(mode)&&!FS.isLink(mode)){throw new FS.ErrnoError(28)}var node=FS.createNode(parent,name,mode);node.node_ops=NODEFS.node_ops;node.stream_ops=NODEFS.stream_ops;return node},getMode(path){return NODEFS.tryFSOperation(()=>{var mode=fs.lstatSync(path).mode;if(NODEFS.isWindows){mode|=(mode&292)>>2}return mode})},realPath(node){var parts=[];while(node.parent!==node){parts.push(node.name);node=node.parent}parts.push(node.mount.opts.root);parts.reverse();return PATH.join(...parts)},flagsForNode(flags){flags&=~2097152;flags&=~2048;flags&=~32768;flags&=~524288;flags&=~65536;var newFlags=0;for(var k in NODEFS.flagsForNodeMap){if(flags&k){newFlags|=NODEFS.flagsForNodeMap[k];flags^=k}}if(flags){throw new FS.ErrnoError(28)}return newFlags},getattr(func,node){var stat=NODEFS.tryFSOperation(func);if(NODEFS.isWindows){if(!stat.blksize){stat.blksize=4096}if(!stat.blocks){stat.blocks=(stat.size+stat.blksize-1)/stat.blksize|0}stat.mode|=(stat.mode&292)>>2}return{dev:stat.dev,ino:node.id,mode:stat.mode,nlink:stat.nlink,uid:stat.uid,gid:stat.gid,rdev:stat.rdev,size:stat.size,atime:stat.atime,mtime:stat.mtime,ctime:stat.ctime,blksize:stat.blksize,blocks:stat.blocks}},setattr(arg,node,attr,chmod,utimes,truncate,stat){NODEFS.tryFSOperation(()=>{if(attr.mode!==undefined){var mode=attr.mode;if(NODEFS.isWindows){mode&=384}chmod(arg,mode);node.mode=attr.mode}if(typeof(attr.atime??attr.mtime)==="number"){var atime=new Date(attr.atime??stat(arg).atime);var mtime=new Date(attr.mtime??stat(arg).mtime);utimes(arg,atime,mtime)}if(attr.size!==undefined){truncate(arg,attr.size)}})},node_ops:{getattr(node){var path=NODEFS.realPath(node);return NODEFS.getattr(()=>fs.lstatSync(path),node)},setattr(node,attr){var path=NODEFS.realPath(node);if(attr.mode!=null&&attr.dontFollow){throw new FS.ErrnoError(52)}NODEFS.setattr(path,node,attr,fs.chmodSync,fs.utimesSync,fs.truncateSync,fs.lstatSync)},lookup(parent,name){var path=PATH.join2(NODEFS.realPath(parent),name);var mode=NODEFS.getMode(path);return NODEFS.createNode(parent,name,mode)},mknod(parent,name,mode,dev){var node=NODEFS.createNode(parent,name,mode,dev);var path=NODEFS.realPath(node);NODEFS.tryFSOperation(()=>{if(FS.isDir(node.mode)){fs.mkdirSync(path,node.mode)}else{fs.writeFileSync(path,"",{mode:node.mode})}});return node},rename(oldNode,newDir,newName){var oldPath=NODEFS.realPath(oldNode);var newPath=PATH.join2(NODEFS.realPath(newDir),newName);try{FS.unlink(newPath)}catch(e){}NODEFS.tryFSOperation(()=>fs.renameSync(oldPath,newPath));oldNode.name=newName},unlink(parent,name){var path=PATH.join2(NODEFS.realPath(parent),name);NODEFS.tryFSOperation(()=>fs.unlinkSync(path))},rmdir(parent,name){var path=PATH.join2(NODEFS.realPath(parent),name);NODEFS.tryFSOperation(()=>fs.rmdirSync(path))},readdir(node){var path=NODEFS.realPath(node);return NODEFS.tryFSOperation(()=>fs.readdirSync(path))},symlink(parent,newName,oldPath){var newPath=PATH.join2(NODEFS.realPath(parent),newName);NODEFS.tryFSOperation(()=>fs.symlinkSync(oldPath,newPath))},readlink(node){var path=NODEFS.realPath(node);return NODEFS.tryFSOperation(()=>fs.readlinkSync(path))},statfs(path){var stats=NODEFS.tryFSOperation(()=>fs.statfsSync(path));stats.frsize=stats.bsize;return stats}},stream_ops:{getattr(stream){return NODEFS.getattr(()=>fs.fstatSync(stream.nfd),stream.node)},setattr(stream,attr){NODEFS.setattr(stream.nfd,stream.node,attr,fs.fchmodSync,fs.futimesSync,fs.ftruncateSync,fs.fstatSync)},open(stream){var path=NODEFS.realPath(stream.node);NODEFS.tryFSOperation(()=>{stream.shared.refcount=1;stream.nfd=fs.openSync(path,NODEFS.flagsForNode(stream.flags))})},close(stream){NODEFS.tryFSOperation(()=>{if(stream.nfd&&--stream.shared.refcount===0){fs.closeSync(stream.nfd)}})},dup(stream){stream.shared.refcount++},read(stream,buffer,offset,length,position){return NODEFS.tryFSOperation(()=>fs.readSync(stream.nfd,new Int8Array(buffer.buffer,offset,length),0,length,position))},write(stream,buffer,offset,length,position){return NODEFS.tryFSOperation(()=>fs.writeSync(stream.nfd,new Int8Array(buffer.buffer,offset,length),0,length,position))},llseek(stream,offset,whence){var position=offset;if(whence===1){position+=stream.position}else if(whence===2){if(FS.isFile(stream.node.mode)){NODEFS.tryFSOperation(()=>{var stat=fs.fstatSync(stream.nfd);position+=stat.size})}}if(position<0){throw new FS.ErrnoError(28)}return position},mmap(stream,length,position,prot,flags){if(!FS.isFile(stream.node.mode)){throw new FS.ErrnoError(43)}var ptr=mmapAlloc(length);NODEFS.stream_ops.read(stream,HEAP8,ptr,length,position);return{ptr,allocated:true}},msync(stream,buffer,offset,length,mmapFlags){NODEFS.stream_ops.write(stream,buffer,0,length,offset,false);return 0}}};var NODERAWFS={lookup(parent,name){return FS.lookupPath(`${parent.path}/${name}`).node},lookupPath(path,opts={}){if(opts.parent){path=PATH.dirname(path)}var st=fs.lstatSync(path);var mode=NODEFS.getMode(path);return{path,node:{id:st.ino,mode,node_ops:NODERAWFS,path}}},createStandardStreams(){FS.createStream({nfd:0,position:0,path:"/dev/stdin",flags:0,tty:true,seekable:false},0);var paths=[,"/dev/stdout","/dev/stderr"];for(var i=1;i<3;i++){FS.createStream({nfd:i,position:0,path:paths[i],flags:577,tty:true,seekable:false},i)}},cwd(){return process.cwd()},chdir(...args){process.chdir(...args)},mknod(path,mode){if(FS.isDir(path)){fs.mkdirSync(path,mode)}else{fs.writeFileSync(path,"",{mode})}},mkdir(...args){fs.mkdirSync(...args)},symlink(...args){fs.symlinkSync(...args)},rename(...args){fs.renameSync(...args)},rmdir(...args){fs.rmdirSync(...args)},readdir(...args){return[".",".."].concat(fs.readdirSync(...args))},unlink(...args){fs.unlinkSync(...args)},readlink(...args){return fs.readlinkSync(...args)},stat(path,dontFollow){var stat=dontFollow?fs.lstatSync(path):fs.statSync(path);if(NODEFS.isWindows){stat.mode|=(stat.mode&292)>>2}return stat},fstat(fd){var stream=FS.getStreamChecked(fd);return fs.fstatSync(stream.nfd)},statfsStream(stream){return fs.statfsSync(stream.path)},statfsNode(node){return fs.statfsSync(node.path)},chmod(path,mode,dontFollow){mode&=4095;if(NODEFS.isWindows){mode&=384}if(dontFollow&&fs.lstatSync(path).isSymbolicLink()){throw new FS.ErrnoError(138)}fs.chmodSync(path,mode)},fchmod(fd,mode){var stream=FS.getStreamChecked(fd);fs.fchmodSync(stream.nfd,mode)},chown(...args){fs.chownSync(...args)},fchown(fd,owner,group){var stream=FS.getStreamChecked(fd);fs.fchownSync(stream.nfd,owner,group)},truncate(path,len){if(len<0){throw new FS.ErrnoError(28)}return fs.truncateSync(path,len)},ftruncate(fd,len){if(len<0){throw new FS.ErrnoError(28)}var stream=FS.getStreamChecked(fd);fs.ftruncateSync(stream.nfd,len)},utime(path,atime,mtime){if(atime===null||mtime===null){var st=fs.statSync(path);atime||=st.atimeMs;mtime||=st.mtimeMs}fs.utimesSync(path,atime/1e3,mtime/1e3)},open(path,flags,mode){if(typeof flags=="string"){flags=FS_modeStringToFlags(flags)}var pathTruncated=path.split("/").map(s=>s.slice(0,255)).join("/");var nfd=fs.openSync(pathTruncated,NODEFS.flagsForNode(flags),mode);var st=fs.fstatSync(nfd);if(flags&65536&&!st.isDirectory()){fs.closeSync(nfd);throw new FS.ErrnoError(ERRNO_CODES.ENOTDIR)}var newMode=NODEFS.getMode(pathTruncated);var node={id:st.ino,mode:newMode,node_ops:NODERAWFS,path};return FS.createStream({nfd,position:0,path,flags,node,seekable:true})},createStream(stream,fd){var rtn=VFS.createStream(stream,fd);if(typeof rtn.shared.refcnt=="undefined"){rtn.shared.refcnt=1}else{rtn.shared.refcnt++}return rtn},close(stream){VFS.closeStream(stream.fd);if(!stream.stream_ops&&--stream.shared.refcnt<=0){fs.closeSync(stream.nfd)}},llseek(stream,offset,whence){if(stream.stream_ops){return VFS.llseek(stream,offset,whence)}var position=offset;if(whence===1){position+=stream.position}else if(whence===2){position+=fs.fstatSync(stream.nfd).size}else if(whence!==0){throw new FS.ErrnoError(28)}if(position<0){throw new FS.ErrnoError(28)}stream.position=position;return position},read(stream,buffer,offset,length,position){if(stream.stream_ops){return VFS.read(stream,buffer,offset,length,position)}var seeking=typeof position!="undefined";if(!seeking&&stream.seekable)position=stream.position;var bytesRead=fs.readSync(stream.nfd,new Int8Array(buffer.buffer,offset,length),0,length,position);if(!seeking)stream.position+=bytesRead;return bytesRead},write(stream,buffer,offset,length,position){if(stream.stream_ops){return VFS.write(stream,buffer,offset,length,position)}if(stream.flags&+"1024"){FS.llseek(stream,0,+"2")}var seeking=typeof position!="undefined";if(!seeking&&stream.seekable)position=stream.position;var bytesWritten=fs.writeSync(stream.nfd,new Int8Array(buffer.buffer,offset,length),0,length,position);if(!seeking)stream.position+=bytesWritten;return bytesWritten},mmap(stream,length,position,prot,flags){if(!length){throw new FS.ErrnoError(28)}if(stream.stream_ops){return VFS.mmap(stream,length,position,prot,flags)}var ptr=mmapAlloc(length);FS.read(stream,HEAP8,ptr,length,position);return{ptr,allocated:true}},msync(stream,buffer,offset,length,mmapFlags){if(stream.stream_ops){return VFS.msync(stream,buffer,offset,length,mmapFlags)}FS.write(stream,buffer,0,length,offset);return 0},ioctl(){throw new FS.ErrnoError(59)}};var FS={root:null,mounts:[],devices:{},streams:[],nextInode:1,nameTable:null,currentPath:"/",initialized:false,ignorePermissions:true,filesystems:null,syncFSRequests:0,readFiles:{},ErrnoError:class{name="ErrnoError";constructor(errno){this.errno=errno}},FSStream:class{shared={};get object(){return this.node}set object(val){this.node=val}get isRead(){return(this.flags&2097155)!==1}get isWrite(){return(this.flags&2097155)!==0}get isAppend(){return this.flags&1024}get flags(){return this.shared.flags}set flags(val){this.shared.flags=val}get position(){return this.shared.position}set position(val){this.shared.position=val}},FSNode:class{node_ops={};stream_ops={};readMode=292|73;writeMode=146;mounted=null;constructor(parent,name,mode,rdev){if(!parent){parent=this}this.parent=parent;this.mount=parent.mount;this.id=FS.nextInode++;this.name=name;this.mode=mode;this.rdev=rdev;this.atime=this.mtime=this.ctime=Date.now()}get read(){return(this.mode&this.readMode)===this.readMode}set read(val){val?this.mode|=this.readMode:this.mode&=~this.readMode}get write(){return(this.mode&this.writeMode)===this.writeMode}set write(val){val?this.mode|=this.writeMode:this.mode&=~this.writeMode}get isFolder(){return FS.isDir(this.mode)}get isDevice(){return FS.isChrdev(this.mode)}},lookupPath(path,opts={}){if(!path){throw new FS.ErrnoError(44)}opts.follow_mount??=true;if(!PATH.isAbs(path)){path=FS.cwd()+"/"+path}linkloop:for(var nlinks=0;nlinks<40;nlinks++){var parts=path.split("/").filter(p=>!!p);var current=FS.root;var current_path="/";for(var i=0;i<parts.length;i++){var islast=i===parts.length-1;if(islast&&opts.parent){break}if(parts[i]==="."){continue}if(parts[i]===".."){current_path=PATH.dirname(current_path);current=current.parent;continue}current_path=PATH.join2(current_path,parts[i]);try{current=FS.lookupNode(current,parts[i])}catch(e){if(e?.errno===44&&islast&&opts.noent_okay){return{path:current_path}}throw e}if(FS.isMountpoint(current)&&(!islast||opts.follow_mount)){current=current.mounted.root}if(FS.isLink(current.mode)&&(!islast||opts.follow)){if(!current.node_ops.readlink){throw new FS.ErrnoError(52)}var link=current.node_ops.readlink(current);if(!PATH.isAbs(link)){link=PATH.dirname(current_path)+"/"+link}path=link+"/"+parts.slice(i+1).join("/");continue linkloop}}return{path:current_path,node:current}}throw new FS.ErrnoError(32)},getPath(node){var path;while(true){if(FS.isRoot(node)){var mount=node.mount.mountpoint;if(!path)return mount;return mount[mount.length-1]!=="/"?`${mount}/${path}`:mount+path}path=path?`${node.name}/${path}`:node.name;node=node.parent}},hashName(parentid,name){var hash=0;for(var i=0;i<name.length;i++){hash=(hash<<5)-hash+name.charCodeAt(i)|0}return(parentid+hash>>>0)%FS.nameTable.length},hashAddNode(node){var hash=FS.hashName(node.parent.id,node.name);node.name_next=FS.nameTable[hash];FS.nameTable[hash]=node},hashRemoveNode(node){var hash=FS.hashName(node.parent.id,node.name);if(FS.nameTable[hash]===node){FS.nameTable[hash]=node.name_next}else{var current=FS.nameTable[hash];while(current){if(current.name_next===node){current.name_next=node.name_next;break}current=current.name_next}}},lookupNode(parent,name){var errCode=FS.mayLookup(parent);if(errCode){throw new FS.ErrnoError(errCode)}var hash=FS.hashName(parent.id,name);for(var node=FS.nameTable[hash];node;node=node.name_next){var nodeName=node.name;if(node.parent.id===parent.id&&nodeName===name){return node}}return FS.lookup(parent,name)},createNode(parent,name,mode,rdev){var node=new FS.FSNode(parent,name,mode,rdev);FS.hashAddNode(node);return node},destroyNode(node){FS.hashRemoveNode(node)},isRoot(node){return node===node.parent},isMountpoint(node){return!!node.mounted},isFile(mode){return(mode&61440)===32768},isDir(mode){return(mode&61440)===16384},isLink(mode){return(mode&61440)===40960},isChrdev(mode){return(mode&61440)===8192},isBlkdev(mode){return(mode&61440)===24576},isFIFO(mode){return(mode&61440)===4096},isSocket(mode){return(mode&49152)===49152},flagsToPermissionString(flag){var perms=["r","w","rw"][flag&3];if(flag&512){perms+="w"}return perms},nodePermissions(node,perms){if(FS.ignorePermissions){return 0}if(perms.includes("r")&&!(node.mode&292)){return 2}else if(perms.includes("w")&&!(node.mode&146)){return 2}else if(perms.includes("x")&&!(node.mode&73)){return 2}return 0},mayLookup(dir){if(!FS.isDir(dir.mode))return 54;var errCode=FS.nodePermissions(dir,"x");if(errCode)return errCode;if(!dir.node_ops.lookup)return 2;return 0},mayCreate(dir,name){if(!FS.isDir(dir.mode)){return 54}try{var node=FS.lookupNode(dir,name);return 20}catch(e){}return FS.nodePermissions(dir,"wx")},mayDelete(dir,name,isdir){var node;try{node=FS.lookupNode(dir,name)}catch(e){return e.errno}var errCode=FS.nodePermissions(dir,"wx");if(errCode){return errCode}if(isdir){if(!FS.isDir(node.mode)){return 54}if(FS.isRoot(node)||FS.getPath(node)===FS.cwd()){return 10}}else{if(FS.isDir(node.mode)){return 31}}return 0},mayOpen(node,flags){if(!node){return 44}if(FS.isLink(node.mode)){return 32}else if(FS.isDir(node.mode)){if(FS.flagsToPermissionString(flags)!=="r"||flags&(512|64)){return 31}}return FS.nodePermissions(node,FS.flagsToPermissionString(flags))},checkOpExists(op,err){if(!op){throw new FS.ErrnoError(err)}return op},MAX_OPEN_FDS:4096,nextfd(){for(var fd=0;fd<=FS.MAX_OPEN_FDS;fd++){if(!FS.streams[fd]){return fd}}throw new FS.ErrnoError(33)},getStreamChecked(fd){var stream=FS.getStream(fd);if(!stream){throw new FS.ErrnoError(8)}return stream},getStream:fd=>FS.streams[fd],createStream(stream,fd=-1){stream=Object.assign(new FS.FSStream,stream);if(fd==-1){fd=FS.nextfd()}stream.fd=fd;FS.streams[fd]=stream;return stream},closeStream(fd){FS.streams[fd]=null},dupStream(origStream,fd=-1){var stream=FS.createStream(origStream,fd);stream.stream_ops?.dup?.(stream);return stream},doSetAttr(stream,node,attr){var setattr=stream?.stream_ops.setattr;var arg=setattr?stream:node;setattr??=node.node_ops.setattr;FS.checkOpExists(setattr,63);setattr(arg,attr)},chrdev_stream_ops:{open(stream){var device=FS.getDevice(stream.node.rdev);stream.stream_ops=device.stream_ops;stream.stream_ops.open?.(stream)},llseek(){throw new FS.ErrnoError(70)}},major:dev=>dev>>8,minor:dev=>dev&255,makedev:(ma,mi)=>ma<<8|mi,registerDevice(dev,ops){FS.devices[dev]={stream_ops:ops}},getDevice:dev=>FS.devices[dev],getMounts(mount){var mounts=[];var check=[mount];while(check.length){var m=check.pop();mounts.push(m);check.push(...m.mounts)}return mounts},syncfs(populate,callback){if(typeof populate=="function"){callback=populate;populate=false}FS.syncFSRequests++;if(FS.syncFSRequests>1){err(`warning: ${FS.syncFSRequests} FS.syncfs operations in flight at once, probably just doing extra work`)}var mounts=FS.getMounts(FS.root.mount);var completed=0;function doCallback(errCode){FS.syncFSRequests--;return callback(errCode)}function done(errCode){if(errCode){if(!done.errored){done.errored=true;return doCallback(errCode)}return}if(++completed>=mounts.length){doCallback(null)}}mounts.forEach(mount=>{if(!mount.type.syncfs){return done(null)}mount.type.syncfs(mount,populate,done)})},mount(type,opts,mountpoint){var root=mountpoint==="/";var pseudo=!mountpoint;var node;if(root&&FS.root){throw new FS.ErrnoError(10)}else if(!root&&!pseudo){var lookup=FS.lookupPath(mountpoint,{follow_mount:false});mountpoint=lookup.path;node=lookup.node;if(FS.isMountpoint(node)){throw new FS.ErrnoError(10)}if(!FS.isDir(node.mode)){throw new FS.ErrnoError(54)}}var mount={type,opts,mountpoint,mounts:[]};var mountRoot=type.mount(mount);mountRoot.mount=mount;mount.root=mountRoot;if(root){FS.root=mountRoot}else if(node){node.mounted=mount;if(node.mount){node.mount.mounts.push(mount)}}return mountRoot},unmount(mountpoint){var lookup=FS.lookupPath(mountpoint,{follow_mount:false});if(!FS.isMountpoint(lookup.node)){throw new FS.ErrnoError(28)}var node=lookup.node;var mount=node.mounted;var mounts=FS.getMounts(mount);Object.keys(FS.nameTable).forEach(hash=>{var current=FS.nameTable[hash];while(current){var next=current.name_next;if(mounts.includes(current.mount)){FS.destroyNode(current)}current=next}});node.mounted=null;var idx=node.mount.mounts.indexOf(mount);node.mount.mounts.splice(idx,1)},lookup(parent,name){return parent.node_ops.lookup(parent,name)},mknod(path,mode,dev){var lookup=FS.lookupPath(path,{parent:true});var parent=lookup.node;var name=PATH.basename(path);if(!name){throw new FS.ErrnoError(28)}if(name==="."||name===".."){throw new FS.ErrnoError(20)}var errCode=FS.mayCreate(parent,name);if(errCode){throw new FS.ErrnoError(errCode)}if(!parent.node_ops.mknod){throw new FS.ErrnoError(63)}return parent.node_ops.mknod(parent,name,mode,dev)},statfs(path){return FS.statfsNode(FS.lookupPath(path,{follow:true}).node)},statfsStream(stream){return FS.statfsNode(stream.node)},statfsNode(node){var rtn={bsize:4096,frsize:4096,blocks:1e6,bfree:5e5,bavail:5e5,files:FS.nextInode,ffree:FS.nextInode-1,fsid:42,flags:2,namelen:255};if(node.node_ops.statfs){Object.assign(rtn,node.node_ops.statfs(node.mount.opts.root))}return rtn},create(path,mode=438){mode&=4095;mode|=32768;return FS.mknod(path,mode,0)},mkdir(path,mode=511){mode&=511|512;mode|=16384;return FS.mknod(path,mode,0)},mkdirTree(path,mode){var dirs=path.split("/");var d="";for(var dir of dirs){if(!dir)continue;if(d||PATH.isAbs(path))d+="/";d+=dir;try{FS.mkdir(d,mode)}catch(e){if(e.errno!=20)throw e}}},mkdev(path,mode,dev){if(typeof dev=="undefined"){dev=mode;mode=438}mode|=8192;return FS.mknod(path,mode,dev)},symlink(oldpath,newpath){if(!PATH_FS.resolve(oldpath)){throw new FS.ErrnoError(44)}var lookup=FS.lookupPath(newpath,{parent:true});var parent=lookup.node;if(!parent){throw new FS.ErrnoError(44)}var newname=PATH.basename(newpath);var errCode=FS.mayCreate(parent,newname);if(errCode){throw new FS.ErrnoError(errCode)}if(!parent.node_ops.symlink){throw new FS.ErrnoError(63)}return parent.node_ops.symlink(parent,newname,oldpath)},rename(old_path,new_path){var old_dirname=PATH.dirname(old_path);var new_dirname=PATH.dirname(new_path);var old_name=PATH.basename(old_path);var new_name=PATH.basename(new_path);var lookup,old_dir,new_dir;lookup=FS.lookupPath(old_path,{parent:true});old_dir=lookup.node;lookup=FS.lookupPath(new_path,{parent:true});new_dir=lookup.node;if(!old_dir||!new_dir)throw new FS.ErrnoError(44);if(old_dir.mount!==new_dir.mount){throw new FS.ErrnoError(75)}var old_node=FS.lookupNode(old_dir,old_name);var relative=PATH_FS.relative(old_path,new_dirname);if(relative.charAt(0)!=="."){throw new FS.ErrnoError(28)}relative=PATH_FS.relative(new_path,old_dirname);if(relative.charAt(0)!=="."){throw new FS.ErrnoError(55)}var new_node;try{new_node=FS.lookupNode(new_dir,new_name)}catch(e){}if(old_node===new_node){return}var isdir=FS.isDir(old_node.mode);var errCode=FS.mayDelete(old_dir,old_name,isdir);if(errCode){throw new FS.ErrnoError(errCode)}errCode=new_node?FS.mayDelete(new_dir,new_name,isdir):FS.mayCreate(new_dir,new_name);if(errCode){throw new FS.ErrnoError(errCode)}if(!old_dir.node_ops.rename){throw new FS.ErrnoError(63)}if(FS.isMountpoint(old_node)||new_node&&FS.isMountpoint(new_node)){throw new FS.ErrnoError(10)}if(new_dir!==old_dir){errCode=FS.nodePermissions(old_dir,"w");if(errCode){throw new FS.ErrnoError(errCode)}}FS.hashRemoveNode(old_node);try{old_dir.node_ops.rename(old_node,new_dir,new_name);old_node.parent=new_dir}catch(e){throw e}finally{FS.hashAddNode(old_node)}},rmdir(path){var lookup=FS.lookupPath(path,{parent:true});var parent=lookup.node;var name=PATH.basename(path);var node=FS.lookupNode(parent,name);var errCode=FS.mayDelete(parent,name,true);if(errCode){throw new FS.ErrnoError(errCode)}if(!parent.node_ops.rmdir){throw new FS.ErrnoError(63)}if(FS.isMountpoint(node)){throw new FS.ErrnoError(10)}parent.node_ops.rmdir(parent,name);FS.destroyNode(node)},readdir(path){var lookup=FS.lookupPath(path,{follow:true});var node=lookup.node;var readdir=FS.checkOpExists(node.node_ops.readdir,54);return readdir(node)},unlink(path){var lookup=FS.lookupPath(path,{parent:true});var parent=lookup.node;if(!parent){throw new FS.ErrnoError(44)}var name=PATH.basename(path);var node=FS.lookupNode(parent,name);var errCode=FS.mayDelete(parent,name,false);if(errCode){throw new FS.ErrnoError(errCode)}if(!parent.node_ops.unlink){throw new FS.ErrnoError(63)}if(FS.isMountpoint(node)){throw new FS.ErrnoError(10)}parent.node_ops.unlink(parent,name);FS.destroyNode(node)},readlink(path){var lookup=FS.lookupPath(path);var link=lookup.node;if(!link){throw new FS.ErrnoError(44)}if(!link.node_ops.readlink){throw new FS.ErrnoError(28)}return link.node_ops.readlink(link)},stat(path,dontFollow){var lookup=FS.lookupPath(path,{follow:!dontFollow});var node=lookup.node;var getattr=FS.checkOpExists(node.node_ops.getattr,63);return getattr(node)},fstat(fd){var stream=FS.getStreamChecked(fd);var node=stream.node;var getattr=stream.stream_ops.getattr;var arg=getattr?stream:node;getattr??=node.node_ops.getattr;FS.checkOpExists(getattr,63);return getattr(arg)},lstat(path){return FS.stat(path,true)},doChmod(stream,node,mode,dontFollow){FS.doSetAttr(stream,node,{mode:mode&4095|node.mode&~4095,ctime:Date.now(),dontFollow})},chmod(path,mode,dontFollow){var node;if(typeof path=="string"){var lookup=FS.lookupPath(path,{follow:!dontFollow});node=lookup.node}else{node=path}FS.doChmod(null,node,mode,dontFollow)},lchmod(path,mode){FS.chmod(path,mode,true)},fchmod(fd,mode){var stream=FS.getStreamChecked(fd);FS.doChmod(stream,stream.node,mode,false)},doChown(stream,node,dontFollow){FS.doSetAttr(stream,node,{timestamp:Date.now(),dontFollow})},chown(path,uid,gid,dontFollow){var node;if(typeof path=="string"){var lookup=FS.lookupPath(path,{follow:!dontFollow});node=lookup.node}else{node=path}FS.doChown(null,node,dontFollow)},lchown(path,uid,gid){FS.chown(path,uid,gid,true)},fchown(fd,uid,gid){var stream=FS.getStreamChecked(fd);FS.doChown(stream,stream.node,false)},doTruncate(stream,node,len){if(FS.isDir(node.mode)){throw new FS.ErrnoError(31)}if(!FS.isFile(node.mode)){throw new FS.ErrnoError(28)}var errCode=FS.nodePermissions(node,"w");if(errCode){throw new FS.ErrnoError(errCode)}FS.doSetAttr(stream,node,{size:len,timestamp:Date.now()})},truncate(path,len){if(len<0){throw new FS.ErrnoError(28)}var node;if(typeof path=="string"){var lookup=FS.lookupPath(path,{follow:true});node=lookup.node}else{node=path}FS.doTruncate(null,node,len)},ftruncate(fd,len){var stream=FS.getStreamChecked(fd);if(len<0||(stream.flags&2097155)===0){throw new FS.ErrnoError(28)}FS.doTruncate(stream,stream.node,len)},utime(path,atime,mtime){var lookup=FS.lookupPath(path,{follow:true});var node=lookup.node;var setattr=FS.checkOpExists(node.node_ops.setattr,63);setattr(node,{atime,mtime})},open(path,flags,mode=438){if(path===""){throw new FS.ErrnoError(44)}flags=typeof flags=="string"?FS_modeStringToFlags(flags):flags;if(flags&64){mode=mode&4095|32768}else{mode=0}var node;var isDirPath;if(typeof path=="object"){node=path}else{isDirPath=path.endsWith("/");var lookup=FS.lookupPath(path,{follow:!(flags&131072),noent_okay:true});node=lookup.node;path=lookup.path}var created=false;if(flags&64){if(node){if(flags&128){throw new FS.ErrnoError(20)}}else if(isDirPath){throw new FS.ErrnoError(31)}else{node=FS.mknod(path,mode|511,0);created=true}}if(!node){throw new FS.ErrnoError(44)}if(FS.isChrdev(node.mode)){flags&=~512}if(flags&65536&&!FS.isDir(node.mode)){throw new FS.ErrnoError(54)}if(!created){var errCode=FS.mayOpen(node,flags);if(errCode){throw new FS.ErrnoError(errCode)}}if(flags&512&&!created){FS.truncate(node,0)}flags&=~(128|512|131072);var stream=FS.createStream({node,path:FS.getPath(node),flags,seekable:true,position:0,stream_ops:node.stream_ops,ungotten:[],error:false});if(stream.stream_ops.open){stream.stream_ops.open(stream)}if(created){FS.chmod(node,mode&511)}if(Module["logReadFiles"]&&!(flags&1)){if(!(path in FS.readFiles)){FS.readFiles[path]=1}}return stream},close(stream){if(FS.isClosed(stream)){throw new FS.ErrnoError(8)}if(stream.getdents)stream.getdents=null;try{if(stream.stream_ops.close){stream.stream_ops.close(stream)}}catch(e){throw e}finally{FS.closeStream(stream.fd)}stream.fd=null},isClosed(stream){return stream.fd===null},llseek(stream,offset,whence){if(FS.isClosed(stream)){throw new FS.ErrnoError(8)}if(!stream.seekable||!stream.stream_ops.llseek){throw new FS.ErrnoError(70)}if(whence!=0&&whence!=1&&whence!=2){throw new FS.ErrnoError(28)}stream.position=stream.stream_ops.llseek(stream,offset,whence);stream.ungotten=[];return stream.position},read(stream,buffer,offset,length,position){if(length<0||position<0){throw new FS.ErrnoError(28)}if(FS.isClosed(stream)){throw new FS.ErrnoError(8)}if((stream.flags&2097155)===1){throw new FS.ErrnoError(8)}if(FS.isDir(stream.node.mode)){throw new FS.ErrnoError(31)}if(!stream.stream_ops.read){throw new FS.ErrnoError(28)}var seeking=typeof position!="undefined";if(!seeking){position=stream.position}else if(!stream.seekable){throw new FS.ErrnoError(70)}var bytesRead=stream.stream_ops.read(stream,buffer,offset,length,position);if(!seeking)stream.position+=bytesRead;return bytesRead},write(stream,buffer,offset,length,position,canOwn){if(length<0||position<0){throw new FS.ErrnoError(28)}if(FS.isClosed(stream)){throw new FS.ErrnoError(8)}if((stream.flags&2097155)===0){throw new FS.ErrnoError(8)}if(FS.isDir(stream.node.mode)){throw new FS.ErrnoError(31)}if(!stream.stream_ops.write){throw new FS.ErrnoError(28)}if(stream.seekable&&stream.flags&1024){FS.llseek(stream,0,2)}var seeking=typeof position!="undefined";if(!seeking){position=stream.position}else if(!stream.seekable){throw new FS.ErrnoError(70)}var bytesWritten=stream.stream_ops.write(stream,buffer,offset,length,position,canOwn);if(!seeking)stream.position+=bytesWritten;return bytesWritten},mmap(stream,length,position,prot,flags){if((prot&2)!==0&&(flags&2)===0&&(stream.flags&2097155)!==2){throw new FS.ErrnoError(2)}if((stream.flags&2097155)===1){throw new FS.ErrnoError(2)}if(!stream.stream_ops.mmap){throw new FS.ErrnoError(43)}if(!length){throw new FS.ErrnoError(28)}return stream.stream_ops.mmap(stream,length,position,prot,flags)},msync(stream,buffer,offset,length,mmapFlags){if(!stream.stream_ops.msync){return 0}return stream.stream_ops.msync(stream,buffer,offset,length,mmapFlags)},ioctl(stream,cmd,arg){if(!stream.stream_ops.ioctl){throw new FS.ErrnoError(59)}return stream.stream_ops.ioctl(stream,cmd,arg)},readFile(path,opts={}){opts.flags=opts.flags||0;opts.encoding=opts.encoding||"binary";if(opts.encoding!=="utf8"&&opts.encoding!=="binary"){throw new Error(`Invalid encoding type "${opts.encoding}"`)}var ret;var stream=FS.open(path,opts.flags);var stat=FS.stat(path);var length=stat.size;var buf=new Uint8Array(length);FS.read(stream,buf,0,length,0);if(opts.encoding==="utf8"){ret=UTF8ArrayToString(buf)}else if(opts.encoding==="binary"){ret=buf}FS.close(stream);return ret},writeFile(path,data,opts={}){opts.flags=opts.flags||577;var stream=FS.open(path,opts.flags,opts.mode);if(typeof data=="string"){var buf=new Uint8Array(lengthBytesUTF8(data)+1);var actualNumBytes=stringToUTF8Array(data,buf,0,buf.length);FS.write(stream,buf,0,actualNumBytes,undefined,opts.canOwn)}else if(ArrayBuffer.isView(data)){FS.write(stream,data,0,data.byteLength,undefined,opts.canOwn)}else{throw new Error("Unsupported data type")}FS.close(stream)},cwd:()=>FS.currentPath,chdir(path){var lookup=FS.lookupPath(path,{follow:true});if(lookup.node===null){throw new FS.ErrnoError(44)}if(!FS.isDir(lookup.node.mode)){throw new FS.ErrnoError(54)}var errCode=FS.nodePermissions(lookup.node,"x");if(errCode){throw new FS.ErrnoError(errCode)}FS.currentPath=lookup.path},createDefaultDirectories(){FS.mkdir("/tmp");FS.mkdir("/home");FS.mkdir("/home/web_user")},createDefaultDevices(){FS.mkdir("/dev");FS.registerDevice(FS.makedev(1,3),{read:()=>0,write:(stream,buffer,offset,length,pos)=>length,llseek:()=>0});FS.mkdev("/dev/null",FS.makedev(1,3));TTY.register(FS.makedev(5,0),TTY.default_tty_ops);TTY.register(FS.makedev(6,0),TTY.default_tty1_ops);FS.mkdev("/dev/tty",FS.makedev(5,0));FS.mkdev("/dev/tty1",FS.makedev(6,0));var randomBuffer=new Uint8Array(1024),randomLeft=0;var randomByte=()=>{if(randomLeft===0){randomFill(randomBuffer);randomLeft=randomBuffer.byteLength}return randomBuffer[--randomLeft]};FS.createDevice("/dev","random",randomByte);FS.createDevice("/dev","urandom",randomByte);FS.mkdir("/dev/shm");FS.mkdir("/dev/shm/tmp")},createSpecialDirectories(){FS.mkdir("/proc");var proc_self=FS.mkdir("/proc/self");FS.mkdir("/proc/self/fd");FS.mount({mount(){var node=FS.createNode(proc_self,"fd",16895,73);node.stream_ops={llseek:MEMFS.stream_ops.llseek};node.node_ops={lookup(parent,name){var fd=+name;var stream=FS.getStreamChecked(fd);var ret={parent:null,mount:{mountpoint:"fake"},node_ops:{readlink:()=>stream.path},id:fd+1};ret.parent=ret;return ret},readdir(){return Array.from(FS.streams.entries()).filter(([k,v])=>v).map(([k,v])=>k.toString())}};return node}},{},"/proc/self/fd")},createStandardStreams(input,output,error){if(input){FS.createDevice("/dev","stdin",input)}else{FS.symlink("/dev/tty","/dev/stdin")}if(output){FS.createDevice("/dev","stdout",null,output)}else{FS.symlink("/dev/tty","/dev/stdout")}if(error){FS.createDevice("/dev","stderr",null,error)}else{FS.symlink("/dev/tty1","/dev/stderr")}var stdin=FS.open("/dev/stdin",0);var stdout=FS.open("/dev/stdout",1);var stderr=FS.open("/dev/stderr",1)},staticInit(){FS.nameTable=new Array(4096);FS.mount(MEMFS,{},"/");FS.createDefaultDirectories();FS.createDefaultDevices();FS.createSpecialDirectories();FS.filesystems={MEMFS,NODEFS}},init(input,output,error){FS.initialized=true;input??=Module["stdin"];output??=Module["stdout"];error??=Module["stderr"];FS.createStandardStreams(input,output,error)},quit(){FS.initialized=false;_fflush(0);for(var stream of FS.streams){if(stream){FS.close(stream)}}},findObject(path,dontResolveLastLink){var ret=FS.analyzePath(path,dontResolveLastLink);if(!ret.exists){return null}return ret.object},analyzePath(path,dontResolveLastLink){try{var lookup=FS.lookupPath(path,{follow:!dontResolveLastLink});path=lookup.path}catch(e){}var ret={isRoot:false,exists:false,error:0,name:null,path:null,object:null,parentExists:false,parentPath:null,parentObject:null};try{var lookup=FS.lookupPath(path,{parent:true});ret.parentExists=true;ret.parentPath=lookup.path;ret.parentObject=lookup.node;ret.name=PATH.basename(path);lookup=FS.lookupPath(path,{follow:!dontResolveLastLink});ret.exists=true;ret.path=lookup.path;ret.object=lookup.node;ret.name=lookup.node.name;ret.isRoot=lookup.path==="/"}catch(e){ret.error=e.errno}return ret},createPath(parent,path,canRead,canWrite){parent=typeof parent=="string"?parent:FS.getPath(parent);var parts=path.split("/").reverse();while(parts.length){var part=parts.pop();if(!part)continue;var current=PATH.join2(parent,part);try{FS.mkdir(current)}catch(e){if(e.errno!=20)throw e}parent=current}return current},createFile(parent,name,properties,canRead,canWrite){var path=PATH.join2(typeof parent=="string"?parent:FS.getPath(parent),name);var mode=FS_getMode(canRead,canWrite);return FS.create(path,mode)},createDataFile(parent,name,data,canRead,canWrite,canOwn){var path=name;if(parent){parent=typeof parent=="string"?parent:FS.getPath(parent);path=name?PATH.join2(parent,name):parent}var mode=FS_getMode(canRead,canWrite);var node=FS.create(path,mode);if(data){if(typeof data=="string"){var arr=new Array(data.length);for(var i=0,len=data.length;i<len;++i)arr[i]=data.charCodeAt(i);data=arr}FS.chmod(node,mode|146);var stream=FS.open(node,577);FS.write(stream,data,0,data.length,0,canOwn);FS.close(stream);FS.chmod(node,mode)}},createDevice(parent,name,input,output){var path=PATH.join2(typeof parent=="string"?parent:FS.getPath(parent),name);var mode=FS_getMode(!!input,!!output);FS.createDevice.major??=64;var dev=FS.makedev(FS.createDevice.major++,0);FS.registerDevice(dev,{open(stream){stream.seekable=false},close(stream){if(output?.buffer?.length){output(10)}},read(stream,buffer,offset,length,pos){var bytesRead=0;for(var i=0;i<length;i++){var result;try{result=input()}catch(e){throw new FS.ErrnoError(29)}if(result===undefined&&bytesRead===0){throw new FS.ErrnoError(6)}if(result===null||result===undefined)break;bytesRead++;buffer[offset+i]=result}if(bytesRead){stream.node.atime=Date.now()}return bytesRead},write(stream,buffer,offset,length,pos){for(var i=0;i<length;i++){try{output(buffer[offset+i])}catch(e){throw new FS.ErrnoError(29)}}if(length){stream.node.mtime=stream.node.ctime=Date.now()}return i}});return FS.mkdev(path,mode,dev)},forceLoadFile(obj){if(obj.isDevice||obj.isFolder||obj.link||obj.contents)return true;if(typeof XMLHttpRequest!="undefined"){throw new Error("Lazy loading should have been performed (contents set) in createLazyFile, but it was not. Lazy loading only works in web workers. Use --embed-file or --preload-file in emcc on the main thread.")}else{try{obj.contents=readBinary(obj.url);obj.usedBytes=obj.contents.length}catch(e){throw new FS.ErrnoError(29)}}},createLazyFile(parent,name,url,canRead,canWrite){class LazyUint8Array{lengthKnown=false;chunks=[];get(idx){if(idx>this.length-1||idx<0){return undefined}var chunkOffset=idx%this.chunkSize;var chunkNum=idx/this.chunkSize|0;return this.getter(chunkNum)[chunkOffset]}setDataGetter(getter){this.getter=getter}cacheLength(){var xhr=new XMLHttpRequest;xhr.open("HEAD",url,false);xhr.send(null);if(!(xhr.status>=200&&xhr.status<300||xhr.status===304))throw new Error("Couldn't load "+url+". Status: "+xhr.status);var datalength=Number(xhr.getResponseHeader("Content-length"));var header;var hasByteServing=(header=xhr.getResponseHeader("Accept-Ranges"))&&header==="bytes";var usesGzip=(header=xhr.getResponseHeader("Content-Encoding"))&&header==="gzip";var chunkSize=1024*1024;if(!hasByteServing)chunkSize=datalength;var doXHR=(from,to)=>{if(from>to)throw new Error("invalid range ("+from+", "+to+") or no bytes requested!");if(to>datalength-1)throw new Error("only "+datalength+" bytes available! programmer error!");var xhr=new XMLHttpRequest;xhr.open("GET",url,false);if(datalength!==chunkSize)xhr.setRequestHeader("Range","bytes="+from+"-"+to);xhr.responseType="arraybuffer";if(xhr.overrideMimeType){xhr.overrideMimeType("text/plain; charset=x-user-defined")}xhr.send(null);if(!(xhr.status>=200&&xhr.status<300||xhr.status===304))throw new Error("Couldn't load "+url+". Status: "+xhr.status);if(xhr.response!==undefined){return new Uint8Array(xhr.response||[])}return intArrayFromString(xhr.responseText||"",true)};var lazyArray=this;lazyArray.setDataGetter(chunkNum=>{var start=chunkNum*chunkSize;var end=(chunkNum+1)*chunkSize-1;end=Math.min(end,datalength-1);if(typeof lazyArray.chunks[chunkNum]=="undefined"){lazyArray.chunks[chunkNum]=doXHR(start,end)}if(typeof lazyArray.chunks[chunkNum]=="undefined")throw new Error("doXHR failed!");return lazyArray.chunks[chunkNum]});if(usesGzip||!datalength){chunkSize=datalength=1;datalength=this.getter(0).length;chunkSize=datalength;out("LazyFiles on gzip forces download of the whole file when length is accessed")}this._length=datalength;this._chunkSize=chunkSize;this.lengthKnown=true}get length(){if(!this.lengthKnown){this.cacheLength()}return this._length}get chunkSize(){if(!this.lengthKnown){this.cacheLength()}return this._chunkSize}}if(typeof XMLHttpRequest!="undefined"){if(!ENVIRONMENT_IS_WORKER)throw"Cannot do synchronous binary XHRs outside webworkers in modern browsers. Use --embed-file or --preload-file in emcc";var lazyArray=new LazyUint8Array;var properties={isDevice:false,contents:lazyArray}}else{var properties={isDevice:false,url}}var node=FS.createFile(parent,name,properties,canRead,canWrite);if(properties.contents){node.contents=properties.contents}else if(properties.url){node.contents=null;node.url=properties.url}Object.defineProperties(node,{usedBytes:{get:function(){return this.contents.length}}});var stream_ops={};var keys=Object.keys(node.stream_ops);keys.forEach(key=>{var fn=node.stream_ops[key];stream_ops[key]=(...args)=>{FS.forceLoadFile(node);return fn(...args)}});function writeChunks(stream,buffer,offset,length,position){var contents=stream.node.contents;if(position>=contents.length)return 0;var size=Math.min(contents.length-position,length);if(contents.slice){for(var i=0;i<size;i++){buffer[offset+i]=contents[position+i]}}else{for(var i=0;i<size;i++){buffer[offset+i]=contents.get(position+i)}}return size}stream_ops.read=(stream,buffer,offset,length,position)=>{FS.forceLoadFile(node);return writeChunks(stream,buffer,offset,length,position)};stream_ops.mmap=(stream,length,position,prot,flags)=>{FS.forceLoadFile(node);var ptr=mmapAlloc(length);if(!ptr){throw new FS.ErrnoError(48)}writeChunks(stream,HEAP8,ptr,length,position);return{ptr,allocated:true}};node.stream_ops=stream_ops;return node}};var SYSCALLS={DEFAULT_POLLMASK:5,calculateAt(dirfd,path,allowEmpty){if(PATH.isAbs(path)){return path}var dir;if(dirfd===-100){dir=FS.cwd()}else{var dirstream=SYSCALLS.getStreamFromFD(dirfd);dir=dirstream.path}if(path.length==0){if(!allowEmpty){throw new FS.ErrnoError(44)}return dir}return dir+"/"+path},writeStat(buf,stat){HEAP32[buf>>2]=stat.dev;HEAP32[buf+4>>2]=stat.mode;HEAPU32[buf+8>>2]=stat.nlink;HEAP32[buf+12>>2]=stat.uid;HEAP32[buf+16>>2]=stat.gid;HEAP32[buf+20>>2]=stat.rdev;HEAP64[buf+24>>3]=BigInt(stat.size);HEAP32[buf+32>>2]=4096;HEAP32[buf+36>>2]=stat.blocks;var atime=stat.atime.getTime();var mtime=stat.mtime.getTime();var ctime=stat.ctime.getTime();HEAP64[buf+40>>3]=BigInt(Math.floor(atime/1e3));HEAPU32[buf+48>>2]=atime%1e3*1e3*1e3;HEAP64[buf+56>>3]=BigInt(Math.floor(mtime/1e3));HEAPU32[buf+64>>2]=mtime%1e3*1e3*1e3;HEAP64[buf+72>>3]=BigInt(Math.floor(ctime/1e3));HEAPU32[buf+80>>2]=ctime%1e3*1e3*1e3;HEAP64[buf+88>>3]=BigInt(stat.ino);return 0},writeStatFs(buf,stats){HEAP32[buf+4>>2]=stats.bsize;HEAP32[buf+40>>2]=stats.bsize;HEAP32[buf+8>>2]=stats.blocks;HEAP32[buf+12>>2]=stats.bfree;HEAP32[buf+16>>2]=stats.bavail;HEAP32[buf+20>>2]=stats.files;HEAP32[buf+24>>2]=stats.ffree;HEAP32[buf+28>>2]=stats.fsid;HEAP32[buf+44>>2]=stats.flags;HEAP32[buf+36>>2]=stats.namelen},doMsync(addr,stream,len,flags,offset){if(!FS.isFile(stream.node.mode)){throw new FS.ErrnoError(43)}if(flags&2){return 0}var buffer=HEAPU8.slice(addr,addr+len);FS.msync(stream,buffer,offset,len,flags)},getStreamFromFD(fd){var stream=FS.getStreamChecked(fd);return stream},varargs:undefined,getStr(ptr){var ret=UTF8ToString(ptr);return ret}};function ___syscall_faccessat(dirfd,path,amode,flags){try{path=SYSCALLS.getStr(path);path=SYSCALLS.calculateAt(dirfd,path);if(amode&~7){return-28}var lookup=FS.lookupPath(path,{follow:true});var node=lookup.node;if(!node){return-44}var perms="";if(amode&4)perms+="r";if(amode&2)perms+="w";if(amode&1)perms+="x";if(perms&&FS.nodePermissions(node,perms)){return-2}return 0}catch(e){if(typeof FS=="undefined"||!(e.name==="ErrnoError"))throw e;return-e.errno}}var syscallGetVarargI=()=>{var ret=HEAP32[+SYSCALLS.varargs>>2];SYSCALLS.varargs+=4;return ret};var syscallGetVarargP=syscallGetVarargI;function ___syscall_fcntl64(fd,cmd,varargs){SYSCALLS.varargs=varargs;try{var stream=SYSCALLS.getStreamFromFD(fd);switch(cmd){case 0:{var arg=syscallGetVarargI();if(arg<0){return-28}while(FS.streams[arg]){arg++}var newStream;newStream=FS.dupStream(stream,arg);return newStream.fd}case 1:case 2:return 0;case 3:return stream.flags;case 4:{var arg=syscallGetVarargI();stream.flags|=arg;return 0}case 12:{var arg=syscallGetVarargP();var offset=0;HEAP16[arg+offset>>1]=2;return 0}case 13:case 14:return 0}return-28}catch(e){if(typeof FS=="undefined"||!(e.name==="ErrnoError"))throw e;return-e.errno}}function ___syscall_fdatasync(fd){try{var stream=SYSCALLS.getStreamFromFD(fd);return 0}catch(e){if(typeof FS=="undefined"||!(e.name==="ErrnoError"))throw e;return-e.errno}}var stringToUTF8=(str,outPtr,maxBytesToWrite)=>stringToUTF8Array(str,HEAPU8,outPtr,maxBytesToWrite);function ___syscall_getdents64(fd,dirp,count){try{var stream=SYSCALLS.getStreamFromFD(fd);stream.getdents||=FS.readdir(stream.path);var struct_size=280;var pos=0;var off=FS.llseek(stream,0,1);var startIdx=Math.floor(off/struct_size);var endIdx=Math.min(stream.getdents.length,startIdx+Math.floor(count/struct_size));for(var idx=startIdx;idx<endIdx;idx++){var id;var type;var name=stream.getdents[idx];if(name==="."){id=stream.node.id;type=4}else if(name===".."){var lookup=FS.lookupPath(stream.path,{parent:true});id=lookup.node.id;type=4}else{var child;try{child=FS.lookupNode(stream.node,name)}catch(e){if(e?.errno===28){continue}throw e}id=child.id;type=FS.isChrdev(child.mode)?2:FS.isDir(child.mode)?4:FS.isLink(child.mode)?10:8}HEAP64[dirp+pos>>3]=BigInt(id);HEAP64[dirp+pos+8>>3]=BigInt((idx+1)*struct_size);HEAP16[dirp+pos+16>>1]=280;HEAP8[dirp+pos+18]=type;stringToUTF8(name,dirp+pos+19,256);pos+=struct_size}FS.llseek(stream,idx*struct_size,0);return pos}catch(e){if(typeof FS=="undefined"||!(e.name==="ErrnoError"))throw e;return-e.errno}}function ___syscall_ioctl(fd,op,varargs){SYSCALLS.varargs=varargs;try{var stream=SYSCALLS.getStreamFromFD(fd);switch(op){case 21509:{if(!stream.tty)return-59;return 0}case 21505:{if(!stream.tty)return-59;if(stream.tty.ops.ioctl_tcgets){var termios=stream.tty.ops.ioctl_tcgets(stream);var argp=syscallGetVarargP();HEAP32[argp>>2]=termios.c_iflag||0;HEAP32[argp+4>>2]=termios.c_oflag||0;HEAP32[argp+8>>2]=termios.c_cflag||0;HEAP32[argp+12>>2]=termios.c_lflag||0;for(var i=0;i<32;i++){HEAP8[argp+i+17]=termios.c_cc[i]||0}return 0}return 0}case 21510:case 21511:case 21512:{if(!stream.tty)return-59;return 0}case 21506:case 21507:case 21508:{if(!stream.tty)return-59;if(stream.tty.ops.ioctl_tcsets){var argp=syscallGetVarargP();var c_iflag=HEAP32[argp>>2];var c_oflag=HEAP32[argp+4>>2];var c_cflag=HEAP32[argp+8>>2];var c_lflag=HEAP32[argp+12>>2];var c_cc=[];for(var i=0;i<32;i++){c_cc.push(HEAP8[argp+i+17])}return stream.tty.ops.ioctl_tcsets(stream.tty,op,{c_iflag,c_oflag,c_cflag,c_lflag,c_cc})}return 0}case 21519:{if(!stream.tty)return-59;var argp=syscallGetVarargP();HEAP32[argp>>2]=0;return 0}case 21520:{if(!stream.tty)return-59;return-28}case 21531:{var argp=syscallGetVarargP();return FS.ioctl(stream,op,argp)}case 21523:{if(!stream.tty)return-59;if(stream.tty.ops.ioctl_tiocgwinsz){var winsize=stream.tty.ops.ioctl_tiocgwinsz(stream.tty);var argp=syscallGetVarargP();HEAP16[argp>>1]=winsize[0];HEAP16[argp+2>>1]=winsize[1]}return 0}case 21524:{if(!stream.tty)return-59;return 0}case 21515:{if(!stream.tty)return-59;return 0}default:return-28}}catch(e){if(typeof FS=="undefined"||!(e.name==="ErrnoError"))throw e;return-e.errno}}function ___syscall_mkdirat(dirfd,path,mode){try{path=SYSCALLS.getStr(path);path=SYSCALLS.calculateAt(dirfd,path);FS.mkdir(path,mode,0);return 0}catch(e){if(typeof FS=="undefined"||!(e.name==="ErrnoError"))throw e;return-e.errno}}function ___syscall_openat(dirfd,path,flags,varargs){SYSCALLS.varargs=varargs;try{path=SYSCALLS.getStr(path);path=SYSCALLS.calculateAt(dirfd,path);var mode=varargs?syscallGetVarargI():0;return FS.open(path,flags,mode).fd}catch(e){if(typeof FS=="undefined"||!(e.name==="ErrnoError"))throw e;return-e.errno}}function ___syscall_renameat(olddirfd,oldpath,newdirfd,newpath){try{oldpath=SYSCALLS.getStr(oldpath);newpath=SYSCALLS.getStr(newpath);oldpath=SYSCALLS.calculateAt(olddirfd,oldpath);newpath=SYSCALLS.calculateAt(newdirfd,newpath);FS.rename(oldpath,newpath);return 0}catch(e){if(typeof FS=="undefined"||!(e.name==="ErrnoError"))throw e;return-e.errno}}function ___syscall_rmdir(path){try{path=SYSCALLS.getStr(path);FS.rmdir(path);return 0}catch(e){if(typeof FS=="undefined"||!(e.name==="ErrnoError"))throw e;return-e.errno}}function ___syscall_stat64(path,buf){try{path=SYSCALLS.getStr(path);return SYSCALLS.writeStat(buf,FS.stat(path))}catch(e){if(typeof FS=="undefined"||!(e.name==="ErrnoError"))throw e;return-e.errno}}function ___syscall_unlinkat(dirfd,path,flags){try{path=SYSCALLS.getStr(path);path=SYSCALLS.calculateAt(dirfd,path);if(flags===0){FS.unlink(path)}else if(flags===512){FS.rmdir(path)}else{abort("Invalid flags passed to unlinkat")}return 0}catch(e){if(typeof FS=="undefined"||!(e.name==="ErrnoError"))throw e;return-e.errno}}var __abort_js=()=>abort("");var isLeapYear=year=>year%4===0&&(year%100!==0||year%400===0);var MONTH_DAYS_LEAP_CUMULATIVE=[0,31,60,91,121,152,182,213,244,274,305,335];var MONTH_DAYS_REGULAR_CUMULATIVE=[0,31,59,90,120,151,181,212,243,273,304,334];var ydayFromDate=date=>{var leap=isLeapYear(date.getFullYear());var monthDaysCumulative=leap?MONTH_DAYS_LEAP_CUMULATIVE:MONTH_DAYS_REGULAR_CUMULATIVE;var yday=monthDaysCumulative[date.getMonth()]+date.getDate()-1;return yday};var INT53_MAX=9007199254740992;var INT53_MIN=-9007199254740992;var bigintToI53Checked=num=>num<INT53_MIN||num>INT53_MAX?NaN:Number(num);function __localtime_js(time,tmPtr){time=bigintToI53Checked(time);var date=new Date(time*1e3);HEAP32[tmPtr>>2]=date.getSeconds();HEAP32[tmPtr+4>>2]=date.getMinutes();HEAP32[tmPtr+8>>2]=date.getHours();HEAP32[tmPtr+12>>2]=date.getDate();HEAP32[tmPtr+16>>2]=date.getMonth();HEAP32[tmPtr+20>>2]=date.getFullYear()-1900;HEAP32[tmPtr+24>>2]=date.getDay();var yday=ydayFromDate(date)|0;HEAP32[tmPtr+28>>2]=yday;HEAP32[tmPtr+36>>2]=-(date.getTimezoneOffset()*60);var start=new Date(date.getFullYear(),0,1);var summerOffset=new Date(date.getFullYear(),6,1).getTimezoneOffset();var winterOffset=start.getTimezoneOffset();var dst=(summerOffset!=winterOffset&&date.getTimezoneOffset()==Math.min(winterOffset,summerOffset))|0;HEAP32[tmPtr+32>>2]=dst}function __mmap_js(len,prot,flags,fd,offset,allocated,addr){offset=bigintToI53Checked(offset);try{if(isNaN(offset))return 61;var stream=SYSCALLS.getStreamFromFD(fd);var res=FS.mmap(stream,len,offset,prot,flags);var ptr=res.ptr;HEAP32[allocated>>2]=res.allocated;HEAPU32[addr>>2]=ptr;return 0}catch(e){if(typeof FS=="undefined"||!(e.name==="ErrnoError"))throw e;return-e.errno}}function __munmap_js(addr,len,prot,flags,fd,offset){offset=bigintToI53Checked(offset);try{var stream=SYSCALLS.getStreamFromFD(fd);if(prot&2){SYSCALLS.doMsync(addr,stream,len,flags,offset)}}catch(e){if(typeof FS=="undefined"||!(e.name==="ErrnoError"))throw e;return-e.errno}}var __tzset_js=(timezone,daylight,std_name,dst_name)=>{var currentYear=(new Date).getFullYear();var winter=new Date(currentYear,0,1);var summer=new Date(currentYear,6,1);var winterOffset=winter.getTimezoneOffset();var summerOffset=summer.getTimezoneOffset();var stdTimezoneOffset=Math.max(winterOffset,summerOffset);HEAPU32[timezone>>2]=stdTimezoneOffset*60;HEAP32[daylight>>2]=Number(winterOffset!=summerOffset);var extractZone=timezoneOffset=>{var sign=timezoneOffset>=0?"-":"+";var absOffset=Math.abs(timezoneOffset);var hours=String(Math.floor(absOffset/60)).padStart(2,"0");var minutes=String(absOffset%60).padStart(2,"0");return`UTC${sign}${hours}${minutes}`};var winterName=extractZone(winterOffset);var summerName=extractZone(summerOffset);if(summerOffset<winterOffset){stringToUTF8(winterName,std_name,17);stringToUTF8(summerName,dst_name,17)}else{stringToUTF8(winterName,dst_name,17);stringToUTF8(summerName,std_name,17)}};var _emscripten_get_now=()=>performance.now();var _emscripten_date_now=()=>Date.now();var getHeapMax=()=>2147483648;var growMemory=size=>{var b=wasmMemory.buffer;var pages=(size-b.byteLength+65535)/65536|0;try{wasmMemory.grow(pages);updateMemoryViews();return 1}catch(e){}};var _emscripten_resize_heap=requestedSize=>{var oldSize=HEAPU8.length;requestedSize>>>=0;var maxHeapSize=getHeapMax();if(requestedSize>maxHeapSize){return false}for(var cutDown=1;cutDown<=4;cutDown*=2){var overGrownHeapSize=oldSize*(1+.2/cutDown);overGrownHeapSize=Math.min(overGrownHeapSize,requestedSize+100663296);var newSize=Math.min(maxHeapSize,alignMemory(Math.max(requestedSize,overGrownHeapSize),65536));var replacement=growMemory(newSize);if(replacement){return true}}return false};var ENV={};var getExecutableName=()=>thisProgram||"./this.program";var getEnvStrings=()=>{if(!getEnvStrings.strings){var lang=(typeof navigator=="object"&&navigator.languages&&navigator.languages[0]||"C").replace("-","_")+".UTF-8";var env={USER:"web_user",LOGNAME:"web_user",PATH:"/",PWD:"/",HOME:"/home/web_user",LANG:lang,_:getExecutableName()};for(var x in ENV){if(ENV[x]===undefined)delete env[x];else env[x]=ENV[x]}var strings=[];for(var x in env){strings.push(`${x}=${env[x]}`)}getEnvStrings.strings=strings}return getEnvStrings.strings};var stringToAscii=(str,buffer)=>{for(var i=0;i<str.length;++i){HEAP8[buffer++]=str.charCodeAt(i)}HEAP8[buffer]=0};var _environ_get=(__environ,environ_buf)=>{var bufSize=0;getEnvStrings().forEach((string,i)=>{var ptr=environ_buf+bufSize;HEAPU32[__environ+i*4>>2]=ptr;stringToAscii(string,ptr);bufSize+=string.length+1});return 0};var _environ_sizes_get=(penviron_count,penviron_buf_size)=>{var strings=getEnvStrings();HEAPU32[penviron_count>>2]=strings.length;var bufSize=0;strings.forEach(string=>bufSize+=string.length+1);HEAPU32[penviron_buf_size>>2]=bufSize;return 0};function _fd_close(fd){try{var stream=SYSCALLS.getStreamFromFD(fd);FS.close(stream);return 0}catch(e){if(typeof FS=="undefined"||!(e.name==="ErrnoError"))throw e;return e.errno}}var doReadv=(stream,iov,iovcnt,offset)=>{var ret=0;for(var i=0;i<iovcnt;i++){var ptr=HEAPU32[iov>>2];var len=HEAPU32[iov+4>>2];iov+=8;var curr=FS.read(stream,HEAP8,ptr,len,offset);if(curr<0)return-1;ret+=curr;if(curr<len)break;if(typeof offset!="undefined"){offset+=curr}}return ret};function _fd_pread(fd,iov,iovcnt,offset,pnum){offset=bigintToI53Checked(offset);try{if(isNaN(offset))return 61;var stream=SYSCALLS.getStreamFromFD(fd);var num=doReadv(stream,iov,iovcnt,offset);HEAPU32[pnum>>2]=num;return 0}catch(e){if(typeof FS=="undefined"||!(e.name==="ErrnoError"))throw e;return e.errno}}function _fd_read(fd,iov,iovcnt,pnum){try{var stream=SYSCALLS.getStreamFromFD(fd);var num=doReadv(stream,iov,iovcnt);HEAPU32[pnum>>2]=num;return 0}catch(e){if(typeof FS=="undefined"||!(e.name==="ErrnoError"))throw e;return e.errno}}function _fd_seek(fd,offset,whence,newOffset){offset=bigintToI53Checked(offset);try{if(isNaN(offset))return 61;var stream=SYSCALLS.getStreamFromFD(fd);FS.llseek(stream,offset,whence);HEAP64[newOffset>>3]=BigInt(stream.position);if(stream.getdents&&offset===0&&whence===0)stream.getdents=null;return 0}catch(e){if(typeof FS=="undefined"||!(e.name==="ErrnoError"))throw e;return e.errno}}var doWritev=(stream,iov,iovcnt,offset)=>{var ret=0;for(var i=0;i<iovcnt;i++){var ptr=HEAPU32[iov>>2];var len=HEAPU32[iov+4>>2];iov+=8;var curr=FS.write(stream,HEAP8,ptr,len,offset);if(curr<0)return-1;ret+=curr;if(curr<len){break}if(typeof offset!="undefined"){offset+=curr}}return ret};function _fd_write(fd,iov,iovcnt,pnum){try{var stream=SYSCALLS.getStreamFromFD(fd);var num=doWritev(stream,iov,iovcnt);HEAPU32[pnum>>2]=num;return 0}catch(e){if(typeof FS=="undefined"||!(e.name==="ErrnoError"))throw e;return e.errno}}var runtimeKeepaliveCounter=0;var keepRuntimeAlive=()=>noExitRuntime||runtimeKeepaliveCounter>0;var _proc_exit=code=>{EXITSTATUS=code;if(!keepRuntimeAlive()){Module["onExit"]?.(code);ABORT=true}quit_(code,new ExitStatus(code))};var exitJS=(status,implicit)=>{EXITSTATUS=status;if(!keepRuntimeAlive()){exitRuntime()}_proc_exit(status)};var handleException=e=>{if(e instanceof ExitStatus||e=="unwind"){return EXITSTATUS}quit_(1,e)};var stackAlloc=sz=>__emscripten_stack_alloc(sz);var stringToUTF8OnStack=str=>{var size=lengthBytesUTF8(str)+1;var ret=stackAlloc(size);stringToUTF8(str,ret,size);return ret};FS.createPreloadedFile=FS_createPreloadedFile;FS.staticInit();MEMFS.doesNotExistError=new FS.ErrnoError(44);MEMFS.doesNotExistError.stack="<generic error, no stack>";if(ENVIRONMENT_IS_NODE){NODEFS.staticInit()}if(!ENVIRONMENT_IS_NODE){throw new Error("NODERAWFS is currently only supported on Node.js environment.")}var _wrapNodeError=function(func){return function(...args){try{return func(...args)}catch(e){if(e.code){throw new FS.ErrnoError(ERRNO_CODES[e.code])}throw e}}};var VFS={...FS};for(var _key in NODERAWFS){FS[_key]=_wrapNodeError(NODERAWFS[_key])}function to_stdout(buffer,length){const array=new Uint8Array(length);for(let i=0;i<length;i++){array[i]=getValue(buffer+i,"i8")}process.stdout.write(array)}var wasmImports={a:___assert_fail,B:___cxa_throw,g:___syscall_faccessat,d:___syscall_fcntl64,z:___syscall_fdatasync,o:___syscall_getdents64,i:___syscall_ioctl,v:___syscall_mkdirat,q:___syscall_openat,n:___syscall_renameat,m:___syscall_rmdir,l:___syscall_stat64,k:___syscall_unlinkat,h:__abort_js,t:__localtime_js,r:__mmap_js,s:__munmap_js,u:__tzset_js,A:_emscripten_date_now,f:_emscripten_get_now,j:_emscripten_resize_heap,x:_environ_get,y:_environ_sizes_get,c:_fd_close,p:_fd_pread,e:_fd_read,w:_fd_seek,b:_fd_write,C:to_stdout};var wasmExports;createWasm();var ___wasm_call_ctors=()=>(___wasm_call_ctors=wasmExports["E"])();var _main=Module["_main"]=(a0,a1)=>(_main=Module["_main"]=wasmExports["F"])(a0,a1);var _fflush=a0=>(_fflush=wasmExports["H"])(a0);var ___funcs_on_exit=()=>(___funcs_on_exit=wasmExports["I"])();var _emscripten_builtin_memalign=(a0,a1)=>(_emscripten_builtin_memalign=wasmExports["J"])(a0,a1);var __emscripten_stack_alloc=a0=>(__emscripten_stack_alloc=wasmExports["K"])(a0);function callMain(args=[]){var entryFunction=_main;args.unshift(thisProgram);var argc=args.length;var argv=stackAlloc((argc+1)*4);var argv_ptr=argv;args.forEach(arg=>{HEAPU32[argv_ptr>>2]=stringToUTF8OnStack(arg);argv_ptr+=4});HEAPU32[argv_ptr>>2]=0;try{var ret=entryFunction(argc,argv);exitJS(ret,true);return ret}catch(e){return handleException(e)}}function run(args=arguments_){if(runDependencies>0){dependenciesFulfilled=run;return}preRun();if(runDependencies>0){dependenciesFulfilled=run;return}function doRun(){Module["calledRun"]=true;if(ABORT)return;initRuntime();preMain();Module["onRuntimeInitialized"]?.();var noInitialRun=Module["noInitialRun"];if(!noInitialRun)callMain(args);postRun()}if(Module["setStatus"]){Module["setStatus"]("Running...");setTimeout(()=>{setTimeout(()=>Module["setStatus"](""),1);doRun()},1)}else{doRun()}}if(Module["preInit"]){if(typeof Module["preInit"]=="function")Module["preInit"]=[Module["preInit"]];while(Module["preInit"].length>0){Module["preInit"].pop()()}}run();
SyntaxError: Unexpected token '.'
at wrapSafe (internal/modules/cjs/loader.js:915:16)
at Module._compile (internal/modules/cjs/loader.js:963:27)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
at Module.load (internal/modules/cjs/loader.js:863:32)
at Function.Module._load (internal/modules/cjs/loader.js:708:14)
at Module.require (internal/modules/cjs/loader.js:887:19)
at require (internal/modules/cjs/helpers.js:85:18)
at Object.<anonymous> (/home/a54/node_modules/ldbdump/ldbdump:3:1)
at Module._compile (internal/modules/cjs/loader.js:999:30)
