Alternate 1
tomato - Interessante Firmware für WRT54
Meine Lieblings Tomato Mod (läuft super auf meinem WRT54GL):
Firmware Tomato RAF 1.25.8xxx by Victek (Beta)
Changelog:
_ DNSMasq 2.49
_ Busybox 1.14.2
_ Passive mode for Wireless Survey
_ Regulatory mode for wireless
_ Wireless Auto channel by default
_ TCP_Conntrack up to 8192 connection
_ Allow multiple MAC address per device
_ SSH remote forwarding allowed
_ More precise match for l7 ftp pattern
_ Miniupnpd updated to ver. 20090605
_ Wan_is_a_LAN feature included when WAN is disabled
_ All the features of Official Tomato 1.25
_ All the features of Tomato RAF
_ ND version with wireless driver 4.158.4.0
_ 140 IP/MAC in restriction table
_ 140 IP/MAC limit in IP/MAC limiter
Download und weitere Infos:
http://victek.is-a-geek.com/tomato.html
Forum-Link zur Victek Mod-Version:
http://www.linksysinfo.org/forums/showthread.php?t=62248
Tomato 1.26
  • Allow a different port to be entered in Basic:Network:Static DNS (enter as "ip : port"). Be aware that dnsmasq must act as the DNS server (the default setting) when not using the normal port 53.
  • Allow DHCP to serve the user-entered gateway (in Basic:Network) if the option in Advanced : DHCP is enabled.
  • Do not start miniupnpd early to avoid warning messages.
  • Update Australian DST (need to re-select), add Darwin, Brisbane TZ. Thanks to Peter O. for the info.
  • Avoid double loading of tomato.css
  • Fix possible null dereference in sendpage
  • Collapsed all menus. For the old look, set nvram: "web_mx=status,bwm,tools"
  • Obscured some key/password fields when not in focus.
  • Accept more than two MAC addresses per IP address (ex: one IP for a laptop either wired or wireless [one at a time]). Note: Some computers may not like seeing the same IP unless it's restarted.
  • Added LED options back in Admin:Buttons/LED.
  • Added ID for WLA2-G54L, TrueMobile 2300 thanks to Nick B. and David J.
  • Added EditDNS thanks to Keith M.
  • Added UTC+4:30 Kabul time zone.
  • Fixed port set validation allowed more than what could be handled.
  • Allow rstats to log if WAN port is used for LAN.
  • Update dnsmasq to 2.51, miniupnpd 1.4, busybox 1.14.4, matrixssl 1.8.8.
Homepage und Download: http://www.polarcloud.com/firmware
FAQ: http://www.polarcloud.com/tomatofaq
Deutsches Wiki: http://de.wikibooks.org/wiki/Tomato_(Firmware)
Virtual Tomato GUI: http://lampiweb.com/tomato/about.htm
Tomato 1.28
  • Fixes for udhcpc. Thanks to fedor for his help.
  • Warn if saving an empty Access Restriction since it's the same as blocking everything.
  • Add option in Admin:Access to select which menus are permanently expanded.
  • Increase PPPoE username and password length.
  • Increase limit for web_printf to avoid problems handling very long variables.
  • Update Dnsmasq to 2.55.
This is basically beta 1812 with an updated Dnsmasq.
Hab die 1.28 schon ein paar Tage drauf... merk keinen Unterschied zu den vorherigen Versionen...
QoS brauch ich bisher gar nicht, aber der Bandwith-Monitor ist ganz praktisch :)
Auf jeden Fall rennt Tomota wie Sau auf meinem WRT54GL :D
Ich hätte da mal eine dringende Frage an euch.
Ich verstehe das System von QOS bei Tomato nicht.Ich habe noch keinen Router, werde mir aber demnächst einen zulegen und dort Tomato draufspielen.
Folgende Situation:
Bei uns gibts demnächst DSL (über Funk), bisher waren wir mit 2 5GB-Flats von O2 unterwegs.Zwei deshalb, da uns einer nicht reicht (mehr wie 5GB Verbrauch) und weil ich UNGESTÖRT ZOCKEN möchte.Deshalb habe ich mir einen eigenen Anschluss zugelegt.
Da jetzt aber DSL kommt, hab ich die Wahl zwischen zwei getrennten Anschlüssen (höhere Kosten) oder einen "großen" DSL-Anschluss.
Würde den großen natürlich vorziehen, aber dazu muß die Bandbreitenaufteilung funktionieren, und zwar so:
1.Mein PC soll bei Online-Spielen bestmögliche PING-Zeiten haben
2.Es sind insgesamt 4 PC´s im Haushalt + 2 Laptops.Es soll nach Möglichkeit jeder anteilig seine Bandbreite bekommen, wenn aber weniger Online sind soll man auch volle Geschwindigkeit bekommen.
Das wars eigentlich auch schon.Wenn das funktioniert, wäre alles perfekt.
Ich würde dann nämlich einen 10000er DSL-Anschluss nehmen.
Funktioniert das mit der Tomato-Firmware? Wie müßten dann die Einstellungen lauten?
Ich verstehe auch diese Bandbreiten-Einstellung von Tomato nicht.
Wenn ich z.b. bei Highest 20% / 100% einstelle, was bedeutet das dann genau?
Die 20% sind die zugesicherte Bandbreite? Soll heissen, die bekommt er zwingend oder?
Was passiert dann, wenn ich z.b. 5 PC´s 30% Mindestbandbreite gebe? Das kann ja dann gar nicht mehr funktionieren, da es insgesamt dann 150% sind.Wird dann einfach gleichmäßig aufgeteilt?
Auch hab ich gelesen, dass man dieses "Prioritize ICMP" anklicken soll, das soll die Ping-Zeit verbessern, ist das richtig?
Eine Frage, vielleicht kann einer fix helfen.
Nach enttäuschendem DD-WRT Test bin ich zum Stock-Rom zurück.
Hat Tomato die Möglichkeit einzustellen das der Router jeden Tag, oder auch wöchentlich an einem Tag, Rebooten soll ?
Danke
PS: DD-WRT hat nur 10-12Mbit vom Kabelmodem angenommen, auf 8 Mbit will ich dann doch nicht verzichten.
Tomato finde ich klasse. Doch VLAN gibt's leider nicht. Welche Alternativen kommen noch in Frage? (DD-WRT gefällt mir nicht ..)
