Winamp v5.23 Beta (Build 666)
AthlonXP
Captain
Apr. 2003
Whats new:
* Improved: [gen_jumpex] jump-to-file speed improvements
* Fixed: playlist saving with network share files
* Fixed: Media Library preferences not loading in correct order
* Fixed: main window not hilited when restoring from minimized state in classic skin.
* Fixed: slow loading of playlists with URLs
* Fixed: CD burning using third party input plugins
* Fixed: classic skin winshade playlist time display
* Fixed: [gen_ff] Wasabi XML font-related fixes from Martin Poehlmann
* Fixed: [gen_ff] Map.getHeight() maki script function returning width instead
* Fixed: [gen_ff] winshade global hotkeys broken w/ modern skins
* Fixed: [gen_jumpex] 'Add to Queue' issues
* Fixed: [gen_jumpex] NT4 incompatability
* Fixed: [gen_jumpex] misc bug fixes
* Fixed: [gen_ml] icon changes on drag+drop items
* Fixed: [in_mp3] playback of AAC streams
* Fixed: [in_mp4] seek bug when using right arrow key
* Fixed: [in_wm] Playback restarts from beginning when editing tags of a currently playing .wma file
* Fixed: [in_wm] protocol/extension reversed in config > filetype > edit
* Fixed: [in_wm] 'Audio only' always checked for ASF/WMV in config
* Fixed: [in_wm] seek bug when using right arrow key
* Fixed: [ml_bookmarks] 'Edit Bookmarks' menu item not working when Media Library is hidden
* Fixed: [ml_local] crash while rearranging media library views
* Fixed: [ml_local] crash on close
* Fixed: [ml_local] sort arrow reversed in some columns
* Fixed: [ml_playlists] Import Playlists uses containing dir for title instead of filename
* Fixed: [ml_playlists] No "Recurse" checkbox in Import Playlists From Folder
* Fixed: [ml_playlists] Add Dir adds all filetypes (not just all-supported)
* Fixed: [ml_playlists] rt-click enqueue not working & other issues
* Fixed: [ml_playlists] Not saving playlists in some situations
* Fixed: [ml_playlists] crash when loading badly formed WPL playlists
* Fixed: [ml_playlists] drag&drop into playlist not adding to correct position
* Fixed: [ml_playlists] root playlist screen not updating when adding new playlist
* Fixed: [ml_playlists] reverting changes on send-to: playlist
* Fixed: [ml_wire] some podcasts only display one item
* Fixed: [out_ds] stop with fade (shift+v) issue
* Fixed: [ml_pmp] Syncing duplicates finally fixed (thanks gordol)
* Fixed: [pmp_ipod] Playlist sort now works again
* Fixed: [ml_pmp] Removing items from a playlist not saving issue (thanks Nick)
* Updated: [in_cdda] CDDB 2.0.1.25
http://download.nullsoft.com/winamp/beta/w...6_beta_full.exe
:D
Antworten
45
Aufrufe
11.360
