Winamp 5.5
zeitwidrig
Feb. 2004
Final ist ab heute verfügbar. Schon jemand getestet oder Erfahrungen mit der Beta?
Changelog:
  • New: Bento SingleUI Skin
  • New: Auto-Tagger in File Info dialog (powered by Gracenote)
  • New: Album Art support, including new window for Winamp Modern skin
  • New: Fully translatable Localization support
  • New: WLZ (Winamp Language Zip) filetype support
  • New: Global 'playback thread priority' setting for decoders
  • New: Media Monitor and MP3 Blog site scraper (in Bento browser)
  • New: Option to set the number of lines to scroll in the Playlist
  • New: Option to not show playlist item number in classic songticker
  • New: Option to not show the playlist number in the Windows taskbar
  • New: Redesigned Installer
  • New: Run Setup switch, winamp.exe /REG=S
  • New: Unified File Editor, with Artwork tab (for mp3, m4a, wma, ogg, flac)
  • New: Version History drop-down selector and Search (in About dialog)
  • New: Winamp Toolbar for Internet Explorer (optional)
  • New: %family% ATF string for identifying filetypes
  • New: $split() ATF function for splitting x/y disc & track strings
  • New: [in_mp3] Multi-channel mp3surround support
  • New: [gen_ml] Tree Options tab in Media Library Preferences
  • New: [ml_autotag] Mass Auto-Tagger in Send-To menu (powered by Gracenote)
  • New: [ml_local] 3 pane view options in 'Add/Edit View' dialog
  • New: [ml_local] Smart View Presets
  • New: [ml_local] Album Art support/pane and retrieval service
  • New: [ml_local] Toolbar buttons to control view options
  • New: [ml_plg] Winamp Playlist Generator (powered by Gracenote MusicID)
  • New: [ml_pmp] New fields, configurable filter panes & columns, 3 pane view
  • New: [ml_pmp] Album Art view & support for iPod and P4S Devices
  • New: [ml_pmp] Separate view for video files
  • New: [vis_milk2] Milkdrop2 Visualizer
  • Improved: General misc UI/Dialog tweaks & improvements
  • Improved: Re-tuned and optimized classic Spectrum Analyzer
  • Improved: Surround indicator in Winamp Modern skin for multi-channel files
  • Improved: Classic Songticker option for Winamp Modern skin (via Config drawer)
  • Improved: [in_cdda] Conductor metadata support
  • Improved: [in_cdda] Handling of multiple discs
  • Improved: [in_flac/in_vorbis] ALBUM ARTIST & ENSEMBLE read support
  • Improved: [in_flac] Advanced Editor mode
  • Improved: [in_mod] Added support for more than 256 samples
  • Improved: [in_mp3] Faster metadata gathering (also speeds up ReplayGain scan)
  • Improved: [in_mp4] Smoother data sent to vis & other minor tweaks
  • Improved: [in_wm] Faster WMA/WMV metadata gathering
  • Improved: [gen_ff] General freeform skinning engine optimizations
  • Improved: [gen_ml] Collapsed/expanded state of treeview items now remembered
  • Improved: [gen_ml] Skinned scrollbars in Media Library for newer Modern skins
  • Improved: [gen_ml] Reordering of treeview items (via drag+drop)
  • Improved: [ml_disc] Better Unicode support & other misc tweaks
  • Improved: [ml_history] Unicode support
  • Improved: [ml_local] Customize Columns menu for top filter panes
  • Improved: [ml_local] Option to show horizontal scrollbar for top panes
  • Improved: [ml_local] New 'Podcasts' view (appears after downloading a podcast)
  • Improved: [ml_local] Added ISPODCAST and PODCASTCHANNEL field names
  • Improved: [ml_local] Added BEGINSLIKE comparison operator
  • Improved: [ml_local] Dragging of headers to sort column order
  • Improved: [ml_local] Redesigned Smart View Editor
  • Improved: [ml_local] Star Rating display and selection
  • Improved: [ml_pmp] 'Copy to Local Media' config separated from CD Ripping settings
  • Improved: [ml_pmp] Portables "Sync" can now keep podcasts updated
  • Improved: [ml_rg] ReplayGain calculation support for 64, 88.2 & 96 KHz samplerates
  • Improved: [ml_wire] Optional automatic downloading of new podcast episodes
  • Improved: [ml_wire] Multi-select, 'Send To' menu and other general enhancements
  • Improved: [ml_wire] Podcast downloads now saved in channel subfolders
  • Improved: [ml_wire] Updated podcast directory
  • Improved: [pmp_ipod] Now uses the iPod's podcast menu for podcasts
  • Fixed: 'All supported files' showing all filetypes in Open Files dialog
  • Fixed: Esc key not working in Credits & Winamp tabs of About Box
  • Fixed: Long filepaths corrupted when opening Winamp via Explorer context menu
  • Fixed: Oversized preference pages with large DPI setting
  • Fixed: Recurrence of multiple instances bug (previously fixed in 5.3)
  • Fixed: Selecting 'No' for 'Physically Remove' prompt removes playlist/mldb item
  • Fixed: TV button in video window not working
  • Fixed: Windows showing if switching from modern to classic skin in minimized state
  • Fixed: [ASX Loader] Recursive playlist loading & case-insensitive element matching
  • Fixed: [ASX Loader] Handling of entries embedded within a REPEAT tag
  • Fixed: [dsp_sps] DEP incompatibility
  • Fixed: [gen_ff] "Can't unload script while in script" error when switching skins
  • Fixed: [gen_ff] Remember ML size when switching between Modern & Classic skins
  • Fixed: [gen_ff] Transparent docked toolbars for skins using alpha-blending
  • Fixed: [gen_ff] 10% opacity not applying on skins that add items to rt-click menu
  • Fixed: [gen_jumpex] Crash when loading multiple files via Explorer context menu
  • Fixed: [gen_jumpex] Remove Duplicate Entries action broken in pledit
  • Fixed: [gen_ml] %playcount% returning Comment on drag+drop from ML to pledit
  • Fixed: [gen_ml] Shift+Insert (New Playlist) and F1 (Help) keyboard shortcuts
  • Fixed: [in_cdda] CDDB crash when attempting to rip a CD in a 2nd instance of Winamp
  • Fixed: [in_flac] General FLAC Editor quirks (Comments field, Enter key, etc)
  • Fixed: [in_flac] 24bit files don't play when 'Allow 24bit' setting is disabled
  • Fixed: [in_mod] Fadeout value goes below 0.0 sec in in_mod config
  • Fixed: [in_mod] Interpolator 'division by zero' crash bug
  • Fixed: [in_mp3] Crash on some mp3's with corrupt ID3v2 extended headers (rare)
  • Fixed: [in_mp3] Crash on loading corrupt id3v2.3 tags of a later revision
  • Fixed: [in_mp3] Negative bitrate in File Info for long mp3's
  • Fixed: [in_mp4] Glitch when modifying metadata on playing track
  • Fixed: [in_mp4/libmp4v2] Memory leaks
  • Fixed: [in_wave/libsndfile] Crash on invalid .au files
  • Fixed: [in_wm] Garbage characters when editing filetypes in config
  • Fixed: [in_wm] Potential DRM lockup issue
  • Fixed: [ml_disc] 0 byte temp files not deleted after ripping
  • Fixed: [ml_disc] Double-click drive icon in Rip & Burn not selecting tree item
  • Fixed: [ml_disc] Crash when using <trackartist> in playlist filename generation
  • Fixed: [ml_disc] Drag+drop from Audio CD view to Playlist Editor
  • Fixed: [ml_local] (no album) items adding to Album count in Artist pane
  • Fixed: [ml_local] isempty and =0 queries now return same results
  • Fixed: [ml_local] Add dir to 'Watch Folders' path truncated to 64 characters
  • Fixed: [ml_pmp] Inserting extra period in filename when transcoding to mp4/aac
  • Fixed: [ml_pmp] Sending ansi-converted titles instead of Unicode
  • Fixed: [ml_pmp] Transfer caption building when Artist metadata is empty
  • Fixed: [ml_wire] Subscription Updates setting always resets to 'Never'
  • Fixed: [pmp_ipod] Potential incompatability issues with latest version of iTunes
  • Fixed: [pmp_p4s] 'Error In Insert' when transferring to some P4S devices
  • Fixed: [pmp_usb] Slow Winamp startup when external usb drive connected
  • Fixed: [vis_milk] Milkdrop DEP incompatibility
  • Misc: Winamp Remote is now an installer option (ml_orb.dll)
  • Misc: Moved drawing engine out of gen_ff to tataki.dll
  • Misc: Moved freetype font renderer out of gen_ff to freetype.wac
  • Misc: Removed deprecated .LNG Language file support
  • Misc: Removed db.w5s (replaced by new Gracenote database system)
  • Misc: Removed Station Info window and Prefs page
  • Misc: Removed unicows.lib/dll as we have officially dropped support for Win9x
  • Updated: Gracenote MusicID/CDDB v2.5
  • Updated: libpng 1.2.20
  • Updated: [enc_aacplus] Coding Technologies aacPlus Encoder v8.1.0
  • Updated: [gen_jumpex] JTFE v0.99.2
  • Updated: [in_flac] FLAC 1.2.1
  • Updated: [in_mp3] FhG Decoder v4.10
  • Updated: [in_vorbis] libvorbis 1.2.0
Ich nutze momentan noch die Beta, wird aber geändert sobald ich zu Hause bin.
Der neue Skin ist recht nett.
Stabil rannte die Beta auch, und was di ganzen Changes angeht, soviel Funktionen nutze ich gar nicht.
Ich bin grad am testen, aber eines gefällt mir.
Die neue Auto-Tag Funktion ist der Hammer. Ich hatte hier einige mp3's von denen ich weder Artist noch Titel wusste. Der Auto-Tag hat alle gefunden! Jipee! :)
Edit:
Hab jetzt noch mehr mit der Auto-Tag Funktion rumgespielt. Die Trefferrate bei meinen mp3's liegt bei 7/10 richtig erkannten.
Also man darf sich nicht blind auf Auto-Tag verlassen
stürzt bei mir bei so ca. jedem 10. Click ab, bei der Beta gabs das nicht
naja, weniger gelungenes Jubiläum...
bzw. bleibt hängen ^^
Habe folgendes Problem mit Winamp 5.5:
Ist eine Datei in einer Playlist zu Ende gespielt, wird diese endlos wiederholt. Es kommt also nicht die nächste Datei in der Playlist.
Winamp 5.5 läuft bei mir unter einem topaktuellen Vista.
Hat jemand das gleiche Problem?
Edit
Problem behoben
Habs auch mal runtergeladen. Aber kann es sein, dass die Playlist beim neuen Skin fest an den Player gebunden ist?
Dem schließe ich mich an. Aber ich habe mal eine Frage: Wie funktioniert das eigentlich? - Woher weiß Winamp denn, wie ein Lied heißt, wenn da keinerlei Informationen drin enthalten sind?
Ich habe ein Problem. Ich benutze Windows Vista Home Premium 64Bit und ich kann keine Elemente per Drag and Drop in die Playlist ziehen.
Vielleich hat ja jemand von euch eine Ahnunh womit da zusammenhängen kann?
Mfg LH
Also bis vor kurzem hab ich Winamp benutzt, ich nutze Winamp seit ich Jahren, seit es MP3´s gibt...
Aber am coolsten fand ich immer Winam Video... welches aber nicht oder so gut wie nicht mehr geht, alles ist irgendwie bei AOL .... über den IE abzurufen örks... ich bin zZt am probieren, der russische AIMP2 ist wie Winamp, nur mit einer Suchfunktion innerhalb der Playlist und mit JetAudio kann ich meine Songs in der Playlist gleich brennen ... kostenlos in angenehmer Geschwindigkeit...
Wenn Winam da nicht nachzieht... tja schade tschüß Winamp
Also wenn du eine Suchfunktion in Winamp vermisst versuch doch mal Dynamic Library.
Mit dem Tool kannst du deine mp3 Ordner in Tree-View anzeigen lassen.
Find ich sehr praktisch und man muss nicht mehr selbst Playlists erstellen.
PS: No. 2000 :)
logan_1968@gmx. schrieb:
auch gerade installiert, absolut TOP!
habe ebenfalls viele Jahre nur Winamp benutzt, aber das AIMP ist dem 5.5er überlegen, wie ich finde
außerdem ist alles schon selbst konfigurierbar... toll!
Hmm, ganz nett, wobei dir Übersetzung nach deutsch war bei mir wirklich grauenhaft, gleich wieder auf Englisch umgestellt und auch das alte Theme wieder genommen. So gesehen hat sich für mich gar nichts verändert. Trotzdem immer noch ne tolle Software, die ich nicht mehr missen möchte!
lg
Hab zwei Fragen:
1) Ist es möglich, Livestreams zu bookmarken oder sonst wie festzuhalten? Im Verlauf bleiben sie zwar ne Zeit, aber die beste Lösung ist das nicht.
2) Wie erreiche ich es, dass Livestreams, die pausiert werden, weiter gebuffert werden, sodass man später ohne Unterbrechung weiterhören kann? Im Moment ist es bei mir so, dass nach "Pause" die Wiedergabe noch ein paar Sekunden läuft, dann ist der Buffer leer und es geht wieder beim aktuellen Lied weiter - alles was dazwischen war, ist futsch.
achtung! bei liefert der auto tagger tonnenweise falsche tags, also nicht vorschnell speichern!
und das die playlist fest gebunden ist hab ich auch festgesellt, deshalb nehm ich wieder winamp modern
Also bis auf dass Last.fm mit der neuen Version nicht richtig funktioniert, kann ich mich nicht über den neuen Winamp beklagen, ganz im Gegenteil, ich bin schwer begeistert. :)
Ja, im neuen Skin ist die Playlist fix in das Fenster integriert, alles ist in einem Fenster. Bei ML & Playlist hab ich es früher vllt. besser gefunden, wenn diese getrennt waren, aber jetzt auch noch Albencover, evtl. Video-Fenster etc. - das wird einfach zu viel. So ist die Bündelung in ein großes Fenster durchaus sinnvoll. Der neue Skin gibt echt was her und die Anordnung der einzelnen Elemente ist gut gelöst (insb. Albencover - endlich dabei :) ) und ist mMn auch schneller als der bisherige modern Skin.
Ich verwende Winamp ja im Docked Toolbar Modus (am oberen Bildschirmrand), da fand ich es vllt. nicht so praktisch, dass ich immer den kompletten Player aus dem Toolbar-Modus befreien musste, um zur ML bzw. zur Playlist zu gelangen. Aber das geht jetzt sehr schnell (< 1 Sek.), beim alten Skin hat das oft 5-10 Sek. gedauert, von daher auch kein Problem.
Was mir noch aufgefallen ist - seit der Unicode-Unterstützung wurden die Titelinformationen von Dateien mit Umlauten im Titel im Docked Toolbar Modus etwas anders (unleserlicher bzw. in 5.5 sogar etwas abgeschnitten) dargestellt, beim neuen Skin sieht alles gleich aus.
Die Auto Tagging funktion hab ich noch gar nicht entdeckt. ;)
Irgendwie bietet die neue Version auch ein besseres Video-Gefühl, werde zwar weiterhin den MPC für Videos verwenden, aber diese Version ekelt mich beim Videos schaun zumindest nicht mehr an. :)
Milkdrop 2.0 ist doch auch neu? Bisher war doch nur 1.04 integriert und auf der Homepage ist das auch weiterhin die aktuelle Version.
Ich weiß ja gar nicht, was sonst noch alles neu ist, aber was ich bisher schon so gesehen und ausprobiert habe, bin ich begeistert.
PS: Ich sags immer wieder AIMP2 ist vllt. ein guter Player und viele behaupten, dass er viel mehr als Winamp könne. Winamp ist aber sicherlich trotzdem noch um einiges reifer, vor allem auch unter der Haube.
hab auch mal ne frage zu dem autotagger, wie er so prinzipiell funktioniert?
gibts ne möglichkeiten dass dieser meine mp3sammlung scannt und dann automatisch alles updatet, wo infos fehlen? weil bei jedem lied einzeln is mir des n bissl zu umständlich.
also quasi bei den mp3s wo entweder titel oder interpret fehlen, diese dann der autotager ergänzen soll, geht sowas, oder is die erkennungsrate so schlecht?
ja die gewünschten in der playlist markieren und dann send to: autotagger, dann kannste taggen lassen, er gibt dir dann sogar ne übersicht im vergleich zum alten tag jeweils, aber das ergebnis war bei mir grottig....
also ich hatte des gefühl bei mir sei das ergebnis fehlerlos gewesen aber ich guck nochmal danke auf jeden fall schonmal, hatten bei dir die lieder auch keinen dateinamen oder hat nur der id3tag gefehlt?
