NAS
Electronics
C++ WM_CHAR Message kommt nicht an!?
Magogan
Aug. 2013
ich habe schon gegoogelt und in diversenen Foren nachgelesen, aber ich finde einfach den Fehler nicht. Aus irgendeinem Grund kommen keine WM_CHAR Messages an bzw. InterfaceClass::HandleCharInput wird nie ausgeführt. Die Maus-Messages kommen aber an und werden auch verarbeitet...
Mein Code:
Code:
#include "systemclass.h"
SystemClass::SystemClass()
	m_Application = 0;
SystemClass::SystemClass(const SystemClass& other)
SystemClass::~SystemClass()
bool SystemClass::Initialize()
	int screenWidth, screenHeight;
	bool result;
	// Initialize the width and height of the screen to zero before sending the variables into the function.
	screenWidth = 0;
	screenHeight = 0;
	// Initialize the windows api.
	InitializeWindows(screenWidth, screenHeight);
	// Create the application wrapper object.
	m_Application = new ApplicationClass;
	if(!m_Application)
		return false;
	// Initialize the application wrapper object.
	result = ApplicationClass::Initialize(m_hinstance, m_hwnd, screenWidth, screenHeight);
	if(!result)
		return false;
	ApplicationClass::WorldInitializationThreadHandle = CreateThread(0, 0, ApplicationClass::ThreadWorldInitialization, 0, 0, 0);
	SetThreadPriority(GetCurrentThread(), THREAD_PRIORITY_HIGHEST);
	return true;
void SystemClass::Shutdown()
	// Release the application wrapper object.
	if(m_Application)
		ApplicationClass::Shutdown();
		delete m_Application;
		m_Application = 0;
	// Shutdown the window.
	ShutdownWindows();
	return;
void SystemClass::Run()
	MSG msg;
	bool done, result;
	ZeroMemory(&msg, sizeof(MSG));
	done = false;
	while(!done)
		if(PeekMessage(&msg, NULL, 0, 0, PM_REMOVE))
			TranslateMessage(&msg);
			DispatchMessage(&msg);
			switch(msg.message){
				case WM_QUIT:
					done = true;
					break;
				case WM_MOUSEWHEEL:
				case WM_RBUTTONDOWN:
					ApplicationClass::HandleMouseInput(msg.message, msg.wParam, msg.lParam);
					break;
				case WM_CHAR:
					InterfaceClass::HandleCharInput(msg.wParam, msg.lParam);
					break;
				default: break;
		else{
			if (NetworkClass::Error != 0){
				exit(NetworkClass::Error); // TBD
			if(!Frame()){
				done = true;
	return;
bool SystemClass::Frame()
	bool result;
	if (GetForegroundWindow() == m_hwnd){
		// Do the frame processing for the application object.
		result = ApplicationClass::Frame();
		if (!result)
			return false;
	else{
		Sleep(100);
	return true;
LRESULT CALLBACK SystemClass::MessageHandler(HWND hwnd, UINT umsg, WPARAM wparam, LPARAM lparam)
	return DefWindowProc(hwnd, umsg, wparam, lparam);
void SystemClass::InitializeWindows(int& screenWidth, int& screenHeight)
	WNDCLASSEX wc;
	DEVMODE dmScreenSettings;
	int posX, posY;
	// Get an external pointer to this object.
	ApplicationHandle = this;
	// Get the instance of this application.
	m_hinstance = GetModuleHandle(NULL);
	// Give the application a name.
	m_applicationName = L"Application";
	// Setup the windows class with default settings.
	wc.style         = CS_HREDRAW | CS_VREDRAW | CS_OWNDC;
	wc.lpfnWndProc   = WndProc;
	wc.cbClsExtra    = 0;
	wc.cbWndExtra    = 0;
	wc.hInstance     = m_hinstance;
	wc.hIcon		 = LoadIcon(NULL, IDI_WINLOGO);
	wc.hIconSm       = wc.hIcon;
	wc.hCursor       = LoadCursor(NULL, IDC_ARROW);
	wc.hbrBackground = (HBRUSH)GetStockObject(BLACK_BRUSH);
	wc.lpszMenuName  = NULL;
	wc.lpszClassName = m_applicationName;
	wc.cbSize        = sizeof(WNDCLASSEX);
	// Register the window class.
	RegisterClassEx(&wc);
	// Determine the resolution of the clients desktop screen.
	screenWidth  = GetSystemMetrics(SM_CXSCREEN);
	screenHeight = GetSystemMetrics(SM_CYSCREEN);
	// Setup the screen settings depending on whether it is running in full screen or in windowed mode.
	if(FULL_SCREEN)
		// If full screen set the screen to maximum size of the users desktop and 32bit.
		memset(&dmScreenSettings, 0, sizeof(dmScreenSettings));
		dmScreenSettings.dmSize       = sizeof(dmScreenSettings);
		dmScreenSettings.dmPelsWidth  = (unsigned long)screenWidth;
		dmScreenSettings.dmPelsHeight = (unsigned long)screenHeight;
		dmScreenSettings.dmBitsPerPel = 32;
		dmScreenSettings.dmFields     = DM_BITSPERPEL | DM_PELSWIDTH | DM_PELSHEIGHT;
		// Change the display settings to full screen.
		ChangeDisplaySettings(&dmScreenSettings, CDS_FULLSCREEN);
		// Set the position of the window to the top left corner.
		posX = posY = 0;
	else
		// If windowed then set it to 800x600 resolution.
		screenWidth  = WINDOWED_SCREEN_WIDTH;
		screenHeight = WINDOWED_SCREEN_HEIGHT;
		// Place the window in the middle of the screen.
		posX = (GetSystemMetrics(SM_CXSCREEN) - screenWidth)  / 2;
		posY = (GetSystemMetrics(SM_CYSCREEN) - screenHeight) / 2;
	// Create the window with the screen settings and get the handle to it.
	m_hwnd = CreateWindowEx(WS_EX_APPWINDOW, m_applicationName, m_applicationName,
						    WS_CLIPSIBLINGS | WS_CLIPCHILDREN | WS_POPUP,
						    posX, posY, screenWidth, screenHeight, NULL, NULL, m_hinstance, NULL);
	// Bring the window up on the screen and set it as main focus.
	ShowWindow(m_hwnd, SW_SHOW);
	SetActiveWindow(m_hwnd);
	SetForegroundWindow(m_hwnd);
	SetFocus(m_hwnd);
	// Hide the mouse cursor.
	ShowCursor(false);
	return;
void SystemClass::ShutdownWindows()
	// Show the mouse cursor.
	ShowCursor(true);
	// Fix the display settings if leaving full screen mode.
	if(FULL_SCREEN)
		ChangeDisplaySettings(NULL, 0);
	// Remove the window.
	DestroyWindow(m_hwnd);
	m_hwnd = NULL;
	// Remove the application instance.
	UnregisterClass(m_applicationName, m_hinstance);
	m_hinstance = NULL;
	// Release the pointer to this class.
	ApplicationHandle = NULL;
	return;
LRESULT CALLBACK WndProc(HWND hwnd, UINT umessage, WPARAM wparam, LPARAM lparam)
	switch(umessage)
		// Check if the window is being destroyed.
		case WM_DESTROY:
			PostQuitMessage(0);
			return 0;
		// Check if the window is being closed.
		case WM_CLOSE:
			PostQuitMessage(0);
			return 0;
		case WM_CHAR:
			InterfaceClass::HandleCharInput(wparam, lparam);
			return 0;
		case WM_KEYDOWN:
			return 0;
		// All other messages pass to the message handler in the system class.
		default:
			return ApplicationHandle->MessageHandler(hwnd, umessage, wparam, lparam);
Hat jemand eine Idee, woran es liegen könnte? Das Fenster müsste doch den Keyboard-Fokus haben, ich verstehe das nicht...
Grüße,
Magogan
Auf die Schnelle: Kommentier mal case WM_KEYDOWN: return 0; aus. Das hebelt ja die Default Behandlung aus.
Ansonsten schau mal mit Spy++ was das Fenster so an Nachrichten kriegt.
Denke ich auch. Laut MSDN:
WM_CHAR message
Posted to the window with the keyboard focus when a WM_KEYDOWN message is translated by the TranslateMessage function.
Da du aber die WM_KEYDOWN-Message schon selber behandelst und das System die nie zu sehen bekommt, kann es doch zum dem oben rot markierten Ereignis gar nicht kommen.
Hab kein Spy++, das gibt es nicht in der Express-Version...
Das Auskommentieren hat nichts gebracht, ich bekomme ja nicht einmal eine WM_KEYDOWN Message...
Edit: Okay, Lösung gefunden: Es lag daran, dass ich DirectInput genutzt habe und mir da die Tastatur exklusiv gesichert habe... Das sollte man natürlich nicht machen, wenn man noch WM_CHAR benutzen will...
