2024-09-27 13:42:07, Info DISM PID=19548 TID=19552 Scratch directory set to 'C:\Users\Tester\AppData\Local\Temp\'. - CDISMManager:
ut_ScratchDir
2024-09-27 13:42:07, Info DISM PID=19548 TID=19552 DismCore.dll version: 10.0.19041.3636 - CDISMManager::FinalConstruct
2024-09-27 13:42:07, Info DISM Initialized Panther logging at C:\WINDOWS\Logs\DISM\dism.log
2024-09-27 13:42:07, Info DISM PID=19548 TID=19552 Successfully loaded the ImageSession at "C:\Windows\system32\Dism" - CDISMManager::LoadLocalImageSession
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19548 TID=19552 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19548 TID=19552 Failed to get and initialize the PE Provider. Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19548 TID=19552 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2024-09-27 13:42:07, Info DISM DISM Manager: PID=19548 TID=19552 Successfully created the local image session and provider store. - CDISMManager::CreateLocalImageSession
2024-09-27 13:42:07, Info DISM DISM.EXE:
2024-09-27 13:42:07, Info DISM DISM.EXE: <----- Starting Dism.exe session ----->
2024-09-27 13:42:07, Info DISM DISM.EXE: Host machine information: OS Version=10.0.19045, Running architecture=amd64, Number of processors=20
2024-09-27 13:42:07, Info DISM DISM.EXE: Dism.exe version: 10.0.19041.3636
2024-09-27 13:42:07, Info DISM DISM.EXE: Executing command line: "C:\Windows\system32\Dism.exe" /Online /Cleanup-Image /RestoreHealth /Source:G:\Sources\install.wim
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19548 TID=19552 Connecting to the provider located at C:\Windows\system32\Dism\FolderProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2024-09-27 13:42:07, Info DISM DISM Manager: PID=19548 TID=19552 physical location path: C:\ - CDISMManager::CreateImageSession
2024-09-27 13:42:07, Info DISM DISM Manager: PID=19548 TID=19552 Event name for current DISM session is Global\{1DD26781-5B3A-4284-A141-6310CC67B72A} - CDISMManager::CheckSessionAndLock
2024-09-27 13:42:07, Info DISM DISM Manager: PID=19548 TID=19552 Create session event 0x230 for current DISM session and event name is Global\{1DD26781-5B3A-4284-A141-6310CC67B72A} - CDISMManager::CheckSessionAndLock
2024-09-27 13:42:07, Info DISM DISM Manager: PID=19548 TID=19552 Copying DISM from "C:\WINDOWS\System32\Dism" - CDISMManager::CreateImageSessionFromLocation
2024-09-27 13:42:07, Info DISM DISM Manager: PID=19548 TID=19552 Successfully loaded the ImageSession at "C:\Users\Tester\AppData\Local\Temp\6CAECD07-56F4-46B2-8440-69E122C33F15" - CDISMManager::LoadRemoteImageSession
2024-09-27 13:42:07, Info DISM DISM Image Session: PID=19780 TID=19724 Instantiating the Provider Store. - CDISMImageSession::get_ProviderStore
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19780 TID=19724 Initializing a provider store for the IMAGE session type. - CDISMProviderStore::Final_OnConnect
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19780 TID=19724 Connecting to the provider located at C:\Users\Tester\AppData\Local\Temp\6CAECD07-56F4-46B2-8440-69E122C33F15\OSProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2024-09-27 13:42:07, Info DISM DISM OS Provider: PID=19780 TID=19724 Defaulting SystemPath to C:\ - CDISMOSServiceManager::Final_OnConnect
2024-09-27 13:42:07, Info DISM DISM OS Provider: PID=19780 TID=19724 Defaulting Windows folder to C:\Windows - CDISMOSServiceManager::Final_OnConnect
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19780 TID=19724 Attempting to initialize the logger from the Image Session. - CDISMProviderStore::Final_OnConnect
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19780 TID=19724 Connecting to the provider located at C:\Users\Tester\AppData\Local\Temp\6CAECD07-56F4-46B2-8440-69E122C33F15\LogProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19780 TID=19724 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2024-09-27 13:42:07, Warning DISM DISM Provider Store: PID=19780 TID=19724 Failed to load the provider: C:\Users\Tester\AppData\Local\Temp\6CAECD07-56F4-46B2-8440-69E122C33F15\PEProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19780 TID=19724 Failed to get and initialize the PE Provider. Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19780 TID=19724 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2024-09-27 13:42:07, Info DISM DISM Manager: PID=19548 TID=19552 Image session successfully loaded from the temporary location: C:\Users\Tester\AppData\Local\Temp\6CAECD07-56F4-46B2-8440-69E122C33F15 - CDISMManager::CreateImageSession
2024-09-27 13:42:07, Info DISM DISM.EXE: Target image information: OS Version=10.0.19045.4780, Image architecture=amd64
2024-09-27 13:42:07, Info DISM DISM.EXE: Image session version: 10.0.19041.3636
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19780 TID=19724 Getting the collection of providers from an image provider store type. - CDISMProviderStore::GetProviderCollection
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19780 TID=19724 Connecting to the provider located at C:\Users\Tester\AppData\Local\Temp\6CAECD07-56F4-46B2-8440-69E122C33F15\CbsProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19780 TID=19724 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider
2024-09-27 13:42:07, Info CSI 00000001 Shim considered [l:126]'\??\C:\WINDOWS\Servicing\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.4892_none_7de7b6f67ca95529\wcp.dll' : got STATUS_OBJECT_PATH_NOT_FOUND
2024-09-27 13:42:07, Info CSI 00000002 Shim considered [l:123]'\??\C:\WINDOWS\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_10.0.19041.4892_none_7de7b6f67ca95529\wcp.dll' : got STATUS_SUCCESS
2024-09-27 13:42:07, Info DISM DISM OS Provider: PID=19780 TID=19724 Determined System directory to be C:\Windows\System32 - CDISMOSServiceManager::get_SystemDirectory
2024-09-27 13:42:07, Info DISM DISM Package Manager: PID=19780 TID=19724 Finished initializing the CbsConUI Handler. - CCbsConUIHandler::Initialize
2024-09-27 13:42:07, Info DISM DISM Package Manager: PID=19780 TID=19724 CBS is being initialized for online use. More information about CBS actions can be located at: %windir%\logs\cbs\cbs.log - CDISMPackageManager::Initialize
2024-09-27 13:42:07, Info DISM DISM Package Manager: PID=19780 TID=19724 Loaded servicing stack for online use only. - CDISMPackageManager::CreateCbsSession
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19780 TID=19724 Connecting to the provider located at C:\Users\Tester\AppData\Local\Temp\6CAECD07-56F4-46B2-8440-69E122C33F15\MsiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19780 TID=19724 Connecting to the provider located at C:\Users\Tester\AppData\Local\Temp\6CAECD07-56F4-46B2-8440-69E122C33F15\IntlProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19780 TID=19724 Connecting to the provider located at C:\Users\Tester\AppData\Local\Temp\6CAECD07-56F4-46B2-8440-69E122C33F15\IBSProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19780 TID=19724 Connecting to the provider located at C:\Users\Tester\AppData\Local\Temp\6CAECD07-56F4-46B2-8440-69E122C33F15\DmiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2024-09-27 13:42:07, Info DISM DISM Driver Manager: PID=19780 TID=19724 Further logs for driver related operations can be found in the target operating system at %WINDIR%\inf\setupapi.offline.log - CDriverManager::Initialize
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19780 TID=19724 Connecting to the provider located at C:\Users\Tester\AppData\Local\Temp\6CAECD07-56F4-46B2-8440-69E122C33F15\UnattendProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19780 TID=19724 Connecting to the provider located at C:\Users\Tester\AppData\Local\Temp\6CAECD07-56F4-46B2-8440-69E122C33F15\SmiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2024-09-27 13:42:07, Warning DISM DISM Provider Store: PID=19780 TID=19724 Failed to load the provider: C:\Users\Tester\AppData\Local\Temp\6CAECD07-56F4-46B2-8440-69E122C33F15\EmbeddedProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19780 TID=19724 Connecting to the provider located at C:\Users\Tester\AppData\Local\Temp\6CAECD07-56F4-46B2-8440-69E122C33F15\AppxProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19780 TID=19724 Connecting to the provider located at C:\Users\Tester\AppData\Local\Temp\6CAECD07-56F4-46B2-8440-69E122C33F15\ProvProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19780 TID=19724 Connecting to the provider located at C:\Users\Tester\AppData\Local\Temp\6CAECD07-56F4-46B2-8440-69E122C33F15\AssocProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19780 TID=19724 Connecting to the provider located at C:\Users\Tester\AppData\Local\Temp\6CAECD07-56F4-46B2-8440-69E122C33F15\GenericProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19780 TID=19724 Connecting to the provider located at C:\Users\Tester\AppData\Local\Temp\6CAECD07-56F4-46B2-8440-69E122C33F15\OfflineSetupProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19780 TID=19724 Connecting to the provider located at C:\Users\Tester\AppData\Local\Temp\6CAECD07-56F4-46B2-8440-69E122C33F15\SysprepProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19780 TID=19724 Connecting to the provider located at C:\Users\Tester\AppData\Local\Temp\6CAECD07-56F4-46B2-8440-69E122C33F15\TransmogProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2024-09-27 13:42:07, Info DISM DISM Transmog Provider: PID=19780 TID=19724 Current image session is [ONLINE] - CTransmogManager::GetMode
2024-09-27 13:42:07, Info DISM DISM Transmog Provider: PID=19780 TID=19724 Audit Mode: [No] - CTransmogManager::Initialize
2024-09-27 13:42:07, Info DISM DISM Transmog Provider: PID=19780 TID=19724 GetProductType: ProductType = [WinNT] - CTransmogManager::GetProductType
2024-09-27 13:42:07, Info DISM DISM Transmog Provider: PID=19780 TID=19724 Product Type: [WinNT] - CTransmogManager::Initialize
2024-09-27 13:42:07, Info DISM DISM Transmog Provider: PID=19780 TID=19724 Product Type ServerNT : [No] - CTransmogManager::Initialize
2024-09-27 13:42:07, Info DISM DISM Provider Store: PID=19780 TID=19724 Connecting to the provider located at C:\Users\Tester\AppData\Local\Temp\6CAECD07-56F4-46B2-8440-69E122C33F15\SetupPlatformProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2024-09-27 13:42:07, Info DISM DISM.EXE: Got the collection of providers. Now enumerating them to build the command table.
2024-09-27 13:42:07, Info DISM DISM.EXE: Attempting to add the commands from provider: DISM Log Provider
2024-09-27 13:42:07, Info DISM DISM.EXE: Attempting to add the commands from provider: OSServices
2024-09-27 13:42:07, Info DISM DISM.EXE: Attempting to add the commands from provider: DISM Package Manager
2024-09-27 13:42:07, Info DISM DISM.EXE: Succesfully registered commands for the provider: DISM Package Manager.
2024-09-27 13:42:07, Info DISM DISM.EXE: Attempting to add the commands from provider: MsiManager
2024-09-27 13:42:07, Info DISM DISM.EXE: Succesfully registered commands for the provider: MsiManager.
2024-09-27 13:42:07, Info DISM DISM.EXE: Attempting to add the commands from provider: IntlManager
2024-09-27 13:42:07, Info DISM DISM.EXE: Succesfully registered commands for the provider: IntlManager.
2024-09-27 13:42:07, Info DISM DISM.EXE: Attempting to add the commands from provider: IBSManager
2024-09-27 13:42:07, Info DISM DISM.EXE: Attempting to add the commands from provider: DriverManager
2024-09-27 13:42:07, Info DISM DISM.EXE: Succesfully registered commands for the provider: DriverManager.
2024-09-27 13:42:07, Info DISM DISM.EXE: Attempting to add the commands from provider: DISM Unattend Manager
2024-09-27 13:42:07, Info DISM DISM.EXE: Succesfully registered commands for the provider: DISM Unattend Manager.
2024-09-27 13:42:07, Info DISM DISM.EXE: Attempting to add the commands from provider: SmiManager
2024-09-27 13:42:07, Info DISM DISM.EXE: Attempting to add the commands from provider: AppxManager
2024-09-27 13:42:07, Info DISM DISM.EXE: Succesfully registered commands for the provider: AppxManager.
2024-09-27 13:42:07, Info DISM DISM.EXE: Attempting to add the commands from provider: ProvManager
2024-09-27 13:42:07, Info DISM DISM.EXE: Succesfully registered commands for the provider: ProvManager.
2024-09-27 13:42:07, Info DISM DISM.EXE: Attempting to add the commands from provider: AssocManager
2024-09-27 13:42:07, Info DISM DISM.EXE: Succesfully registered commands for the provider: AssocManager.
2024-09-27 13:42:07, Info DISM DISM.EXE: Attempting to add the commands from provider: GenericManager
2024-09-27 13:42:07, Info DISM DISM.EXE: Succesfully registered commands for the provider: GenericManager.
2024-09-27 13:42:07, Info DISM DISM.EXE: Attempting to add the commands from provider: OfflineSetupManager
2024-09-27 13:42:07, Info DISM DISM.EXE: Succesfully registered commands for the provider: OfflineSetupManager.
2024-09-27 13:42:07, Info DISM DISM.EXE: Attempting to add the commands from provider: SysprepManager
2024-09-27 13:42:07, Info DISM DISM.EXE: Succesfully registered commands for the provider: SysprepManager.
2024-09-27 13:42:07, Info DISM DISM.EXE: Attempting to add the commands from provider: Edition Manager
2024-09-27 13:42:07, Info DISM DISM.EXE: Succesfully registered commands for the provider: Edition Manager.
2024-09-27 13:42:07, Info DISM DISM.EXE: Attempting to add the commands from provider: SetupPlatformManager
2024-09-27 13:42:07, Info DISM DISM.EXE: Succesfully registered commands for the provider: SetupPlatformManager.
2024-09-27 13:42:07, Info DISM DISM Package Manager: PID=19780 TID=19724 Processing the top level command token(cleanup-image). - CPackageManagerCLIHandler:
rivate_ValidateCmdLine
2024-09-27 13:42:07, Info DISM DISM Package Manager: PID=19780 TID=19724 Attempting to route to appropriate command handler. - CPackageManagerCLIHandler::ExecuteCmdLine
2024-09-27 13:42:07, Info DISM DISM Package Manager: PID=19780 TID=19724 Routing the command... - CPackageManagerCLIHandler::ExecuteCmdLine
2024-09-27 13:42:07, Warning DISM DISM Package Manager: PID=19780 TID=19724 CBS AddSource failed with HRESULT=0x8007010b! - CDISMPackageManager::Internal_Finalize
2024-09-27 13:42:07, Info DISM DISM Package Manager: PID=19780 TID=19724 CBS session options=0x40100! - CDISMPackageManager::Internal_Finalize
2024-09-27 13:45:43, Info DISM DISM Package Manager: PID=19780 TID=19748 Error in operation: source for package or file not found, ResolveSource() unsuccessful. (CBS HRESULT=0x800f081f) - CCbsConUIHandler::Error
2024-09-27 13:45:43, Error DISM DISM Package Manager: PID=19780 TID=19724 Failed finalizing changes. - CDISMPackageManager::Internal_Finalize(hr:0x800f081f)
2024-09-27 13:45:43, Error DISM DISM Package Manager: PID=19780 TID=19724 The source files could not be found; their location must be specified using the /source option to restore the feature. - GetCbsErrorMsg
2024-09-27 13:45:43, Error DISM DISM Package Manager: PID=19780 TID=19724 Failed processing package changes with session option CbsSessionOptionRepairStoreCorruption - CDISMPackageManager::RestoreHealth(hr:0x800f081f)
2024-09-27 13:45:52, Error DISM DISM Package Manager: PID=19780 TID=19724 Failed to restore the image health. - CPackageManagerCLIHandler:
rocessCmdLine_CleanupImage(hr:0x800f081f)
2024-09-27 13:45:52, Error DISM DISM Package Manager: PID=19780 TID=19724 Failed while processing command cleanup-image. - CPackageManagerCLIHandler::ExecuteCmdLine(hr:0x800f081f)
2024-09-27 13:45:52, Info DISM DISM Package Manager: PID=19780 TID=19724 Further logs for online package and feature related operations can be found at %WINDIR%\logs\CBS\cbs.log - CPackageManagerCLIHandler::ExecuteCmdLine
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Found the OSServices. Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Found the PE Provider. Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Finalizing the servicing provider(DISM Package Manager) - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Package Manager: PID=19780 TID=19724 Finalizing CBS core. - CDISMPackageManager::Finalize
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Disconnecting Provider: DISM Package Manager - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Finalizing the servicing provider(MsiManager) - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Disconnecting Provider: MsiManager - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Finalizing the servicing provider(IntlManager) - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Disconnecting Provider: IntlManager - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Finalizing the servicing provider(IBSManager) - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Disconnecting Provider: IBSManager - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Finalizing the servicing provider(DriverManager) - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Disconnecting Provider: DriverManager - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Finalizing the servicing provider(DISM Unattend Manager) - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Disconnecting Provider: DISM Unattend Manager - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Finalizing the servicing provider(SmiManager) - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Disconnecting Provider: SmiManager - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Finalizing the servicing provider(AppxManager) - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Disconnecting Provider: AppxManager - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Finalizing the servicing provider(ProvManager) - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Disconnecting Provider: ProvManager - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Finalizing the servicing provider(AssocManager) - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Disconnecting Provider: AssocManager - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Finalizing the servicing provider(GenericManager) - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Disconnecting Provider: GenericManager - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Finalizing the servicing provider(OfflineSetupManager) - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Disconnecting Provider: OfflineSetupManager - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Finalizing the servicing provider(SysprepManager) - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Disconnecting Provider: SysprepManager - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Finalizing the servicing provider(Edition Manager) - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Disconnecting Provider: Edition Manager - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Finalizing the servicing provider(SetupPlatformManager) - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Disconnecting Provider: SetupPlatformManager - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Releasing the local reference to OSServices. - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Disconnecting Provider: OSServices - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19780 TID=19724 Releasing the local reference to DISMLogger. Stop logging. - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Manager: PID=19548 TID=19552 Closing session event handle 0x230 - CDISMManager::CleanupImageSessionEntry
2024-09-27 13:45:52, Info DISM DISM.EXE: Image session has been closed. Reboot required=no.
2024-09-27 13:45:52, Info DISM DISM.EXE: <----- Ending Dism.exe session ----->
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19548 TID=19552 Found the OSServices. Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19548 TID=19552 Disconnecting Provider: FolderManager - CDISMProviderStore::Internal_DisconnectProvider
2024-09-27 13:45:52, Info DISM DISM Provider Store: PID=19548 TID=19552 Releasing the local reference to DISMLogger. Stop logging. - CDISMProviderStore::Internal_DisconnectProvider
