Bearbeitung eines Win7-ISOs bricht mit Fehler ab
F
flax341
Hallo, ich wollte mit 7Customizer ein Win7x64-ISO bearbeiten, mein BS ist Win7HPx86, WAIK ist installiert und die Pfade richting angegeben. Wenn ich den Pfad zu einer entpackten ISO angebe, spuckt er aus: Unexepted Error: Check your log.
Im log steht :
=====STARTING imageinfo.bat========
"C:\Program Files\Windows AIK\Tools\amd64\imagex.exe" /XML /info C:\Win7x64\sources\install.wim>work\imagesinfo.xml
=====FINISHED imageinfo.bat========
=====STARTING imagesinfo.xml========
=====FINISHED imagesinfo.xml========
=====STARTING log.txt========
=== 7Customizer Started===
7Customizer verion: 0.5.0 Beta 1
7Customizer path: C:\7Customizer_0.5.0\7Customizer.exe
Current directory: C:\7Customizer_0.5.0
OS: Microsoft Windows NT 6.1.7600.0
OS architecture: x86
Work folder found: True
Mount folder found: True
Themes folder found: True
Languages folder found: True
Extract utility found: True
Configuration file found: True
bootorder.txt file found: True
Boot sector file found: True
Components folder found: True
Number of components xml: 3
Elevated: True
No language loaded
Getting drive info
Free space: 110,851245880127 GB
Getting drive info: Done
Saved Imagex path: C:\Program Files\Windows AIK\Tools\amd64\imagex.exe
Saved DISM path: C:\Program Files\Windows AIK\Tools\amd64\Servicing\Dism.exe
Saved odcdimg path: C:\Program Files\Windows AIK\Tools\amd64\oscdimg.exe
Windows source path selected
Sources folder found
install.wim found
install.wim size: 1857 MB
Added: "C:\Program Files\Windows AIK\Tools\amd64\imagex.exe">work\testimagex.txt
Testing imagex
Imagex result begin:
Imagex result file created.
Imagex result end.
Added: "C:\Program Files\Windows AIK\Tools\amd64\Servicing\Dism.exe">work\testdism.txt
Testing dism
dism result begin:
dism result end.
added: "C:\Program Files\Windows AIK\Tools\amd64\imagex.exe" /XML /info "C:\Win7x64\sources\install.wim">work\imagesinfo.xml
Starting imagex
Imagex created imagesinfo.xml Successfully
Reading images information from imagesinfo.xml
First 5 lines of imagesinfo.xml
Unexpected Error: Das Stammelement ist nicht vorhanden.
bei System.Xml.XmlTextReaderImpl.Throw(Exception e)
bei System.Xml.XmlTextReaderImpl.ThrowWithoutLineInfo(String res)
bei System.Xml.XmlTextReaderImpl.ParseDocumentContent()
bei System.Xml.XmlTextReaderImpl.Read()
bei System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
bei System.Xml.XmlDocument.Load(XmlReader reader)
bei System.Xml.XmlDocument.Load(String filename)
bei _7Customizer.Form1.selectImagePathBtn_Click(Object sender, EventArgs e)
=====FINISHED log.txt========
=====STARTING testdism.bat========
=====FINISHED testdism.bat========
=====STARTING testdism.txt========
=====FINISHED testdism.txt========
=====STARTING testimagex.bat========
=====FINISHED testimagex.bat========
=====STARTING testimagex.txt========
=====FINISHED testimagex.txt========
Wenn ich allerdings ein x86-ISO (+passende Pfade) benutze, funktioniert es einwandfrei :confused_alt:.
Ging auch nicht,
der log in x64 sagt :
"E:\Program Files\Windows AIK\Tools\amd64\imagex.exe" /XML /info C:\Win7x64\sources\install.wim>work\imagesinfo.xml
Error opening file [C:\Win7x64\sources\install.wim].
Die Daten sind unzulässig.
OS: Microsoft Windows NT 6.1.7601 Service Pack 1
OS architecture: AMD64
Elevated: True
No language loaded
Getting drive info
Free space: 136,688945770264 GB
Saved Imagex path:
Saved DISM path:
Saved odcdimg path:
ImageX Path Selected
ImageX Path: E:\Program Files\Windows AIK\Tools\amd64\imagex.exe
Dism Path Selected
Dism Path: E:\Program Files\Windows AIK\Tools\amd64\Servicing\Dism.exe
Oscdimg Path Selected
oscdimg Path: E:\Program Files\Windows AIK\Tools\amd64\oscdimg.exe
install.wim found
install.wim size: 2693 MB
Added: "E:\Program Files\Windows AIK\Tools\amd64\imagex.exe">work\testimagex.txt
Testing imagex
ImageX Tool for Windows
Copyright (C) Microsoft Corp. All rights reserved.
Version: 6.1.7600.16385
Imagex result end.
Added: "E:\Program Files\Windows AIK\Tools\amd64\Servicing\Dism.exe">work\testdism.txt
Testing dism
dism result begin:
Tool zur Abbildverwaltung f�r die Bereitstellung
dism result end.
added: "E:\Program Files\Windows AIK\Tools\amd64\imagex.exe" /XML /info "C:\Win7x64\sources\install.wim">work\imagesinfo.xml
Starting imagex
Unexpected Error: Ungültige Daten auf Stammebene. Zeile 2, Position 1.
bei System.Xml.XmlTextReaderImpl.ParseRootLevelWhitespace()
DISM.exe [DISM-Optionen] {WIM-Befehl} [<WIM-Argumente>]
DISM.exe {/Image:<Pfad zum Offlineabbild> | /Online} [DISM-Optionen]
{Wartungsbefehl} [<Wartungsargumente>]
BESCHREIBUNG:
DISM dient zum Aufz�hlen, Installieren, Deinstallieren, Konfigurieren
und Aktualisieren von Funktionen und Paketen in Windows-Abbildern.
Welche Befehle verf�gbar sind, h�ngt davon ab, welches Abbild gewartet
wird und ob es sich bei dem Abbild um ein Offlineabbild oder um ein
Onlineabbild handelt.
WIM-BEFEHLE:
/Get-MountedWimInfo - Zeigt Informationen zu bereitgestellten
WIM-Abbildern an.
/Get-WimInfo - Zeigt Informationen zu Abbildern in einer
WIM-Datei an.
/Commit-Wim - Speichert �nderungen auf einem bereit-
gestellten WIM-Abbild.
/Unmount-Wim - Hebt die Bereitstellung eines bereit-
gestellten WIM-Abbilds auf.
/Mount-Wim - Stellt ein Abbild aus einer WIM-Datei bereit.
/Remount-Wim - Stellt ein verwaistes WIM-Bereitstellungs-
verzeichnis wieder her.
/Cleanup-Wim - L�scht Ressourcen, die mit besch�digten bereit-
gestellten WIM-Abbildern verkn�pft sind.
ABBILDSPEZIFIKATIONEN:
/Online - Verwendet das ausgef�hrte Betriebssystem als Ziel.
/Image - Gibt den Pfad zum Stammverzeichnis eines
Windows-Offlineabbilds an.
DISM-OPTIONEN:
/English - Zeigt die Befehlszeile in englischer Sprache an.
/Format - Gibt das Berichtsausgabeformat an.
/WinDir - Gibt den Pfad zum Windows-Verzeichnis an.
/SysDriveDir - Gibt den Pfad zur Systemladedatei namens
"BootMgr" an.
/LogPath - Gibt den Pfad zur Protokolldatei an.
/LogLevel - Gibt die Ausgabeebene f�r das Protokoll an (1 - 4).
/NoRestart - Unterdr�ckt automatische Neustarts und
Aufforderungen zum Neustart.
/Quiet - Unterdr�ckt alle Ausgaben mit Ausnahme
von Fehlermeldungen.
/ScratchDir - Gibt den Pfad zu einem Entwurfsverzeichnis an.
Weitere Informationen zu diesen DISM-Optionen und den zugeh�rigen
Argumenten erhalten Sie, indem Sie direkt vor "/?" eine Option angeben.
Beispiele:
DISM.exe /Mount-Wim /?
DISM.exe /ScratchDir /?
DISM.exe /Image:C:\test\offline /?
DISM.exe /Online /?
IMAGEX [Flags] /Operation [Parameter List]
Operation [ APPEND | APPLY | CAPTURE | DELETE |
DIR | EXPORT | INFO | SPLIT |
MOUNT | MOUNTRW | REMOUNT | UNMOUNT |
CLEANUP | COMMIT ]
For help on a specific operation type:
IMAGEX /Operation /?
Examples:
IMAGEX /APPEND /?
IMAGEX /APPLY /?
IMAGEX /CAPTURE /?
IMAGEX /DELETE /?
IMAGEX /DIR /?
IMAGEX /EXPORT /?
IMAGEX /INFO /?
IMAGEX /SPLIT /?
IMAGEX /MOUNT /?
IMAGEX /MOUNTRW /?
IMAGEX /REMOUNT /?
IMAGEX /COMMIT /?
IMAGEX /UNMOUNT /?
IMAGEX /CLEANUP /?
All operations accept the following flags:
/SCROLL
/LOGFILE logfile.log
