Commander64
- Mai 2006
Ich habe vorhin Bioshock gezockt und Bioshock minimiert, um im Internet kurz was zu schauen. Dann habe ich Bioshock wieder maximiert und mein PC legte einen Neustart hin. Vorher lief alles bestens. Nach dem Neustart habe ich auch gleich mal die Temps gecheckt, alles soweit im grünen Bereich. Im Verdacht habe ich den 7.11 Beta, der das Crysis Hotfix beinhaltet. Die Minidump habe ich mal auswerten lassen.
Microsoft (R) Windows Debugger Version 6.8.0004.0 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\Minidump\Mini112407-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 2) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055c700
Debug session time: Sat Nov 24 22:54:43.328 2007 (GMT+1)
System Uptime: 0 days 6:22:37.042
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Unable to load image ati2cqag.dll, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ati2cqag.dll
*** ERROR: Module load completed but symbols could not be loaded for ati2cqag.dll
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 10000050, {e9fa667c, 0, bf075fd6, 1}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
Probably caused by : ati2cqag.dll ( ati2cqag+1efd6 )
Followup: MachineOwner
Edit: Folgende Temps hab ich Idle
CPU: 40°C
GPU: 55°C
GPU VRM: 55°C
Mobo: 37°C
HDD1: 35°C
HDD2: 40°C
Sind die Temps für die Graka normal?
Folgende Temps unter Last (Bioshock, 1,5 Stunden)
CPU: 48°C
GPU: 65°C
GPU VRM: 65°C
Mobo: 39°C
HDD1: 34°C
HDD2: 39°C
Keiner eine Ahnung? Bitte auch Vermutungen posten.
*** work. ***
*** work. ***
CPU: 40°C
GPU: 55°C
GPU VRM: 55°C
Mobo: 37°C
HDD1: 35°C
HDD2: 40°C
CPU: 48°C
GPU: 65°C
GPU VRM: 65°C
Mobo: 39°C
HDD1: 34°C
HDD2: 39°C
