System Information (local)
computer name: USER-PC
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
Hardware: H97-D3H, Gigabyte Technology Co., Ltd., H97-D3H-CF
CPU: GenuineIntel Intel(R) Xeon(R) CPU E3-1231 v3 @ 3.40GHz Intel586, level: 6
8 logical processors, active mask: 255
RAM: 17107369984 total
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Thu 24.07.2014 20:10:53 GMT your computer crashed
crash dump file: C:\Windows\Minidump\072414-11715-01.dmp
This was probably caused by the following module: atikmdag.sys (atikmdag+0x28ECE)
Bugcheck code: 0xA0000001 (0x5, 0x0, 0x0, 0x0)
Error: CUSTOM_ERROR
file path: C:\Windows\system32\drivers\atikmdag.sys
product: ATI Radeon Family
company: Advanced Micro Devices, Inc.
description: ATI Radeon Kernel Mode Driver
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: atikmdag.sys (ATI Radeon Kernel Mode Driver, Advanced Micro Devices, Inc.).
Google query: Advanced Micro Devices, Inc. CUSTOM_ERROR
crash dump file: C:\Windows\memory.dmp
Error: CUSTOM_ERROR
On Wed 23.07.2014 13:47:05 GMT your computer crashed
crash dump file: C:\Windows\Minidump\072314-5257-01.dmp
Error: CUSTOM_ERROR
Conclusion
3 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Als die Bluescreens aufgetreten sind habe ich garnichts gemacht.Pc ist neu hochgefahren und habe weiter gezockt
