Jackery IFA Fireplace
Mobile
Bluescreen Win7 HomePremium 64Bit
rensda
Cadet 1st Year
Sep. 2011
AB und zu tritt bei mir dieser Bluescreen auf....
Hat da jemand eine Idee was das sein kann?
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck A, {100060080, 2, 0, fffff80002ad1d75}
TRIAGER: Could not open triage file : C:\Program Files (x86)\Windows Kits\8.0\Debuggers\x64\triage\modclass.ini, error 2
Probably caused by : ntkrnlmp.exe ( nt!KeSetEvent+1e3 )
Followup: MachineOwner
0: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 0000000100060080, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff80002ad1d75, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002d00100
GetUlongFromAddress: unable to read from fffff80002d001c0
0000000100060080 Nonpaged pool
CURRENT_IRQL: 2
FAULTING_IP:
nt!KeSetEvent+1e3
fffff800`02ad1d75 488b00 mov rax,qword ptr [rax]
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
BUGCHECK_STR: 0xA
PROCESS_NAME: OUTLOOK.EXE
TRAP_FRAME: fffff88002932750 -- (.trap 0xfffff88002932750)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000100060080 rbx=0000000000000000 rcx=fffff80002c55bf8
rdx=fffff80002c55bf0 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002ad1d75 rsp=fffff880029328e0 rbp=0000000000000000
r8=0000000000000100 r9=0000000000000000 r10=0000000100060080
r11=fffffa8003827000 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl nz ac po cy
nt!KeSetEvent+0x1e3:
fffff800`02ad1d75 488b00 mov rax,qword ptr [rax] ds:00000001`00060080=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80002acd1e9 to fffff80002acdc40
STACK_TEXT:
fffff880`02932608 fffff800`02acd1e9 : 00000000`0000000a 00000001`00060080 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`02932610 fffff800`02acbe60 : 00000014`00000000 fffff680`0001c000 fffff6fb`82200148 fffff800`02c55bf0 : nt!KiBugCheckDispatch+0x69
fffff880`02932750 fffff800`02ad1d75 : fffff800`02c55bf0 00000000`00000000 00000000`00000000 fffff800`02c43e80 : nt!KiPageFault+0x260
fffff880`029328e0 fffff800`02bce8a2 : fffffa80`00000000 fffff800`00000000 00000000`00000a00 fffffa80`04c45b60 : nt!KeSetEvent+0x1e3
fffff880`02932950 fffff800`02bcecc1 : 00000000`00000410 00000000`00450001 00000000`00000000 00000000`00000000 : nt!MiQueuePageAccessLog+0xb2
fffff880`02932980 fffff800`02b424d5 : fffffa80`02410b30 00000003`00000000 00000000`0045f001 fffffa80`031719a0 : nt!MiEmptyPageAccessLog+0x271
fffff880`029329f0 fffff800`02de5221 : fffffa80`02ed3550 00000000`00000001 fffffa80`031719a0 fffffa80`031719a0 : nt! ?? ::FNODOBFM::`string'+0x3b9a6
fffff880`02932b10 fffff800`02de5623 : fffff880`00000000 00000000`03c60000 fffffa80`00000001 fffff880`02932c01 : nt!MiUnmapViewOfSection+0x1b1
fffff880`02932bd0 fffff800`02acced3 : fffffa80`026a0060 00000000`0000056c fffffa80`02410b30 fffffa80`0261b520 : nt!NtUnmapViewOfSection+0x5f
fffff880`02932c20 00000000`777515ba : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0009dd48 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x777515ba
STACK_COMMAND: kb
FOLLOWUP_IP:
nt!KeSetEvent+1e3
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: nt!KeSetEvent+1e3
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 4e02aaa3
FAILURE_BUCKET_ID: X64_0xA_nt!KeSetEvent+1e3
