Hab eine neue Graka CPU und neuen Speicher eingebaut.
Und irgendwas davon macht Probleme. Nur was? Vllt. kann ja jemand damit was anfangen.
Code:
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: fffffa89024c0958, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff80001e6ff58, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff80002030080
fffffa89024c0958
CURRENT_IRQL: 2
FAULTING_IP:
nt!MiRemoveAnyPage+178
fffff800`01e6ff58 4c094828 or qword ptr [rax+28h],r9
CUSTOMER_CRASH_COUNT: 3
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0xA
PROCESS_NAME: BFBC2Updater.ex
TRAP_FRAME: fffffa60089fa1f0 -- (.trap 0xfffffa60089fa1f0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=fffffa89024c0930 rbx=0000000000000000 rcx=0000000000000093
rdx=fffffa8003900000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80001e6ff58 rsp=fffffa60089fa380 rbp=0000000000000000
r8=0000058000000000 r9=000fffffffffffff r10=0000000000000000
r11=0000000000000031 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz na po cy
nt!MiRemoveAnyPage+0x178:
fffff800`01e6ff58 4c094828 or qword ptr [rax+28h],r9 ds:fffffa89`024c0958=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80001e6322e to fffff80001e63490
STACK_TEXT:
fffffa60`089fa0a8 fffff800`01e6322e : 00000000`0000000a fffffa89`024c0958 00000000`00000002 00000000`00000001 : nt!KeBugCheckEx
fffffa60`089fa0b0 fffff800`01e6210b : 00000000`00000001 fffffa60`00c06ab2 fffffa80`00000001 fffffa80`024bfd30 : nt!KiBugCheckDispatch+0x6e
fffffa60`089fa1f0 fffff800`01e6ff58 : fffff800`01fce240 fffff800`01e8bbc5 fffffa80`04ccf6c0 fffffa60`00b4630f : nt!KiPageFault+0x20b
fffffa60`089fa380 fffff800`01e923d6 : 00000000`00000000 ffffffff`ffffffff 00000000`00000000 00000000`000003e8 : nt!MiRemoveAnyPage+0x178
fffffa60`089fa3e0 fffff800`01e90e53 : fffff980`1748c000 00000000`03ebfd8c 00000000`00000000 00000000`00000080 : nt!MmCopyToCachedPage+0x396
fffffa60`089fa550 fffff800`01e44f02 : fffffa80`046f8010 00000000`03ebfd8c fffffa60`089fa6e8 00000000`00000000 : nt!CcMapAndCopy+0x3a3
fffffa60`089fa670 fffffa60`010affe7 : 00000000`0000014b 00000000`0014c080 fffffa80`040e8800 00000000`03ebfd8c : nt!CcFastCopyWrite+0x162
fffffa60`089fa750 fffffa60`00a10232 : fffffa80`040e8800 fffffa80`07e92d60 fffffa80`000003e8 00000000`00000000 : Ntfs!NtfsCopyWriteA+0x217
fffffa60`089fa950 fffffa60`00a136e4 : fffffa60`089faa40 00000000`00000000 fffffa80`040e8800 00000000`00000004 : fltmgr!FltpPerformFastIoCall+0xf2
fffffa60`089fa9b0 fffffa60`00a2ea49 : 00000000`00000000 fffff800`01e84bae 00000000`00000000 fffffa60`089faa50 : fltmgr!FltpPassThroughFastIo+0xb4
fffffa60`089faa10 fffff800`020cdbfa : fffffa80`040e8874 fffff800`01e659af fffffa80`03fb8e30 fffffa80`040e8874 : fltmgr!FltpFastIoWrite+0x1a9
fffffa60`089faab0 fffff800`01e62f33 : fffffa80`03fb8e01 00000000`00000000 00000000`00000000 00000000`00000000 : nt!NtWriteFile+0x599
fffffa60`089fabb0 00000000`75483917 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`02dbf0b8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x75483917
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: nt!MiRemoveAnyPage+178
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP: 4dfb5a33
IMAGE_NAME: memory_corruption
FAILURE_BUCKET_ID: X64_0xA_nt!MiRemoveAnyPage+178
Followup: MachineOwner
Code:
NTFS_FILE_SYSTEM (24)
If you see NtfsExceptionFilter on the stack then the 2nd and 3rd
parameters are the exception record and context record. Do a .cxr
on the 3rd parameter and then kb to obtain a more informative stack
trace.
Arguments:
Arg1: 00000000001904aa
Arg2: fffffa60082951a8
Arg3: fffffa6008294b80
Arg4: fffff80001e907b0
Debugging Details:
EXCEPTION_RECORD: fffffa60082951a8 -- (.exr 0xfffffa60082951a8)
ExceptionAddress: fffff80001e907b0 (nt!MmMapViewInSystemCache+0x0000000000000060)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
CONTEXT: fffffa6008294b80 -- (.cxr 0xfffffa6008294b80)
rax=0000000000000040 rbx=0000000000000000 rcx=0000000000000000
rdx=0000000000000000 rsi=0000000000000000 rdi=cac5936ccac5936c
rip=fffff80001e907b0 rsp=fffffa60082953e0 rbp=fffffa800398a2c8
r8=fffffa6008295540 r9=fffffa6008295548 r10=fffffa80039aa650
r11=0000000000000000 r12=fffff8800b98baf0 r13=fffffa8005469c10
iopl=0 nv up ei pl zr na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010246
nt!MmMapViewInSystemCache+0x60:
fffff800`01e907b0 48837f6000 cmp qword ptr [rdi+60h],0 ds:002b:cac5936c`cac593cc=????????????????
CUSTOMER_CRASH_COUNT: 2
PROCESS_NAME: WG111v3.exe
CURRENT_IRQL: 0
ERROR_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in 0x%08lx verweist auf Speicher 0x%08lx. Der Vorgang %s konnte nicht im Speicher durchgef hrt werden.
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in 0x%08lx verweist auf Speicher 0x%08lx. Der Vorgang %s konnte nicht im Speicher durchgef hrt werden.
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: ffffffffffffffff
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff8000203c080
ffffffffffffffff
FOLLOWUP_IP:
Ntfs!NtfsCachedRead+13d
fffffa60`010119dd 84c0 test al,al
FAULTING_IP:
nt!MmMapViewInSystemCache+60
BUGCHECK_STR: 0x24
LAST_CONTROL_TRANSFER: from fffff80001e92964 to fffff80001e907b0
STACK_TEXT:
fffffa60`082953e0 fffff800`01e92964 : fffffa80`06e25fb0 00000000`00000000 fffffa60`082955c0 fffffa80`0398a2c8 : nt!MmMapViewInSystemCache+0x60
fffffa60`08295500 fffff800`01e7dea8 : 00000000`00000000 fffff800`01f4989b 00000000`00000000 00000000`00000000 : nt!CcGetVacbMiss+0x1a4
fffffa60`08295590 fffff800`020bfd3d : 00000000`00000000 00000000`00000002 00000000`00000000 fffffa80`058a2550 : nt!CcGetVirtualAddress+0x348
fffffa60`08295610 fffffa60`010119dd : fffffa80`042f0670 fffffa60`082957a0 fffffa80`00003f1f fffffa60`08295901 : nt!CcCopyRead+0x14d
fffffa60`08295730 fffffa60`01022d01 : fffff880`0b948c80 fffffa60`08295930 00000000`00000204 00000000`00003f1f : Ntfs!NtfsCachedRead+0x13d
fffffa60`08295780 fffffa60`01024728 : fffffa80`058a2550 fffffa80`06e25c10 fffffa60`08295901 fffffa80`00000004 : Ntfs!NtfsCommonRead+0x531
fffffa60`08295900 fffffa60`00a0ce91 : fffffa80`06e25fb0 fffffa80`06e25c10 fffffa80`042f06c0 fffffa80`04316010 : Ntfs!NtfsFsdRead+0x1b8
fffffa60`082959b0 fffffa60`00a0b0dd : fffffa80`065f5de0 fffffa80`042f06c0 fffffa80`065f5d00 00000000`00000000 : fltmgr!FltpLegacyProcessingAfterPreCallbacksCompleted+0x211
fffffa60`08295a20 fffff800`0209bd34 : fffffa80`042f0670 fffffa80`042f0670 00000000`0000000b 00000000`03b23f01 : fltmgr!FltpDispatch+0xcd
fffffa60`08295a80 fffff800`01e6ef33 : ffffffff`ffffffff 00000000`00000000 00000000`00000000 00000000`00000000 : nt!NtReadFile+0x702
fffffa60`08295bb0 00000000`75533917 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0007ee18 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x75533917
SYMBOL_STACK_INDEX: 4
SYMBOL_NAME: Ntfs!NtfsCachedRead+13d
MODULE_NAME: Ntfs
IMAGE_NAME: Ntfs.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 49e022ca
STACK_COMMAND: .cxr 0xfffffa6008294b80 ; kb
FAILURE_BUCKET_ID: X64_0x24_Ntfs!NtfsCachedRead+13d
Code:
FAULTING_IP:
watchdog!WdLogEvent5+0
fffff980`0141d130 48895c2410 mov qword ptr [rsp+10h],rbx
EXCEPTION_RECORD: fffff9801ad52f38 -- (.exr 0xfffff9801ad52f38)
ExceptionAddress: fffff9800141d130 (watchdog!WdLogEvent5)
NumberParameters: 2
Parameter[0]: 0000000000000001
Parameter[1]: 0000000000000029
Attempt to write to address 0000000000000029
CONTEXT: fffff9801ad52910 -- (.cxr 0xfffff9801ad52910)
rax=0000000000000000 rbx=0000000000000000 rcx=0000000000000005
rdx=0000000000000000 rsi=fffff9801ad53550 rdi=fffffa8006221000
rip=fffff9800141d130 rsp=fffff9801ad53178 rbp=fffffa8006693f50
r8=fffffa8006693f50 r9=0000000000000001 r10=fffff98005bf2000
r11=fffff9801ad530c0 r12=fffff98007250000 r13=fffff9801ad53550
r14=0000000000000000 r15=0000000000000001
iopl=0 nv up ei ng nz na pe nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010282
watchdog!WdLogEvent5:
fffff980`0141d130 48895c2410 mov qword ptr [rsp+10h],rbx ss:0018:fffff980`1ad53188=fffffa80045d29b0
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: csrss.exe
CURRENT_IRQL: 0
EXCEPTION_PARAMETER1: 0000000000000001
EXCEPTION_PARAMETER2: 0000000000000029
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff80001dfa0b0
0000000000000029
FOLLOWUP_IP:
dxgkrnl!DXGADAPTER::DdiPresent+79
fffff980`0567a759 81fb080000c0 cmp ebx,0C0000008h
BUGCHECK_STR: 0x7E
DEFAULT_BUCKET_ID: NULL_CLASS_PTR_DEREFERENCE
LAST_CONTROL_TRANSFER: from fffff9800567a759 to fffff9800141d130
STACK_TEXT:
fffff980`1ad53178 fffff980`0567a759 : 00000000`00000000 fffffa80`045d29b0 fffff980`00000000 00000000`00000000 : watchdog!WdLogEvent5
fffff980`1ad53180 fffff980`056a405f : fffffa80`00001e10 fffffa80`045d29b0 fffff880`0b0a8990 fffff980`00000003 : dxgkrnl!DXGADAPTER::DdiPresent+0x79
fffff980`1ad531d0 fffff980`056a3b39 : 00000000`00005181 00000000`00000003 fffff880`c000ff00 00000000`c000fe80 : dxgkrnl!DXGCONTEXT::SubmitPresent+0x457
fffff980`1ad534e0 fffff980`0568712b : fffff880`0b0a8990 fffff980`1ad53960 fffff880`00000000 fffff980`05686ea7 : dxgkrnl!DXGCONTEXT::PresentFromCdd+0xc69
fffff980`1ad536e0 fffff960`006034b0 : fffff900`c007e960 ffffffff`ae04188e ffffffff`ae04188e fffffa80`08e64c10 : dxgkrnl!DxgkCddPresent+0x1eb
fffff980`1ad53780 fffff900`c007e960 : ffffffff`ae04188e ffffffff`ae04188e fffffa80`08e64c10 fffff900`c1da51f0 : cdd+0x34b0
fffff980`1ad53788 ffffffff`ae04188e : ffffffff`ae04188e fffffa80`08e64c10 fffff900`c1da51f0 fffff900`c1da51f0 : 0xfffff900`c007e960
fffff980`1ad53790 ffffffff`ae04188e : fffffa80`08e64c10 fffff900`c1da51f0 fffff900`c1da51f0 00000000`00000000 : 0xffffffff`ae04188e
fffff980`1ad53798 fffffa80`08e64c10 : fffff900`c1da51f0 fffff900`c1da51f0 00000000`00000000 fffff800`020e8e5c : 0xffffffff`ae04188e
fffff980`1ad537a0 fffff900`c1da51f0 : fffff900`c1da51f0 00000000`00000000 fffff800`020e8e5c 00000001`c000ffc0 : 0xfffffa80`08e64c10
fffff980`1ad537a8 fffff900`c1da51f0 : 00000000`00000000 fffff800`020e8e5c 00000001`c000ffc0 fffff980`1ad537d4 : 0xfffff900`c1da51f0
fffff980`1ad537b0 00000000`00000000 : fffff800`020e8e5c 00000001`c000ffc0 fffff980`1ad537d4 c000ff00`c000ffc0 : 0xfffff900`c1da51f0
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: dxgkrnl!DXGADAPTER::DdiPresent+79
MODULE_NAME: dxgkrnl
IMAGE_NAME: dxgkrnl.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4689a549
STACK_COMMAND: .cxr 0xfffff9801ad52910 ; kb
FAILURE_BUCKET_ID: X64_0x7E_dxgkrnl!DXGADAPTER::DdiPresent+79
