System Information
Time of this report: 9/30/2007, 14:49:06
Machine name: MEISTER-MO
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2, v.2096 (2600.xpsp_sp2_rc1.040311-2315)
Language: German (Regional Setting: German)
System Manufacturer: To Be Filled By O.E.M.
System Model: To Be Filled By O.E.M.
BIOS: BIOS Date: 10/27/04 19:15:37 Ver: 08.00.09
Processor: AMD Athlon(tm) 64 Processor 3500+, MMX, 3DNow, ~2.2GHz
Memory: 2048MB RAM
Page File: 485MB used, 3457MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0 (4.09.0000.0900)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2096 32bit Unicode
DxDiag Notes
DirectX Files Tab: The file dxdiagn.dll is incorrectly installed in the Windows folder and should be deleted.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 6800 GS/XT
Manufacturer: NVIDIA
Chip type: NVxx
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_00F6&SUBSYS_217E1682&REV_A2
Display Memory: 256.0 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Plug und Play-Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.6371 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 9/17/2007 01:07:00, 5783040 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: Nicht zutreffend
Mini VDD: nv4_mini.sys
Mini VDD Date: 9/17/2007 01:07:00, 6853088 bytes
Device Identifier: {D7B71E3E-43B6-11CF-D16D-750103C2CB35}
Vendor ID: 0x10DE
Device ID: 0x00F6
SubSys ID: 0x217E1682
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2096)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2096)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2096)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2096)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2096)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2096)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2096)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2096)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 TCP/IP Service Provider: 10 + 100 MB - IPv4 -
DirectPlay Voice Codecs
Name: NVIDIA GeForce 6800 GS/XT
Device ID: PCI\VEN_10DE&DEV_00F6&SUBSYS_217E1682&REV_A2\4&3600494A&0&0008
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 6853088 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 5783040 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 155716 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 364544 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 6746112 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 8491008 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.11117 (English), 9/17/2007 01:07:00, 286720 bytes
Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 229376 bytes
Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 6344704 bytes
Driver: C:\WINDOWS\system32\nvdispsr.dll, 6.14.0011.6371 (German), 9/17/2007 01:07:00, 5509120 bytes
Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 3334144 bytes
Driver: C:\WINDOWS\system32\nvgamesr.dll, 6.14.0011.6371 (German), 9/17/2007 01:07:00, 3166208 bytes
Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 188416 bytes
Driver: C:\WINDOWS\system32\nvmccssr.dll, 6.14.0011.6371 (German), 9/17/2007 01:07:00, 458752 bytes
Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 1150976 bytes
Driver: C:\WINDOWS\system32\nvmoblsr.dll, 6.14.0011.6371 (German), 9/17/2007 01:07:00, 2854912 bytes
Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 3551232 bytes
Driver: C:\WINDOWS\system32\nvvitvsr.dll, 6.14.0011.6371 (German), 9/17/2007 01:07:00, 3629056 bytes
Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0011.6371 (English), 9/17/2007 01:07:00, 2371584 bytes
Driver: C:\WINDOWS\system32\nvwssr.dll, 6.14.0011.6371 (German), 9/17/2007 01:07:00, 2441216 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 9/17/2007 01:07:00, 177897 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 9/17/2007 01:07:00, 55444 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0035 (English), 9/17/2007 01:07:00, 36864 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0035 (English), 9/17/2007 01:07:00, 36864 bytes
ddraw.dll: 5.03.2600.2096 German Final Retail 3/12/2004 01:09:50 265216 bytes
ddrawex.dll: 5.03.2600.2096 English Final Retail 3/12/2004 01:09:50 26112 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 10496 bytes
d3d8.dll: 5.03.2600.2096 German Final Retail 3/12/2004 01:09:50 1175552 bytes
d3d8thk.dll: 5.03.2600.2096 English Final Retail 3/12/2004 01:09:50 8192 bytes
d3d9.dll: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 1634304 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2096 English Final Retail 3/12/2004 01:09:50 825856 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 German Final Retail 8/18/2001 12:00:00 33040 bytes
dplayx.dll: 5.03.2600.2096 English Final Retail 3/12/2004 01:09:50 227840 bytes
dpmodemx.dll: 5.03.2600.2096 German Final Retail 3/12/2004 01:09:50 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/18/2001 12:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2096 German Final Retail 3/12/2004 01:09:50 57344 bytes
dplaysvr.exe: 5.03.2600.2096 English Final Retail 3/12/2004 01:10:18 30208 bytes
dpnsvr.exe: 5.03.2600.2096 German Final Retail 3/12/2004 01:10:18 18432 bytes
dpnet.dll: 5.03.2600.2096 English Final Retail 3/12/2004 01:09:50 375296 bytes
dpnlobby.dll: 5.03.2600.2096 English Final Retail 3/12/2004 01:08:10 3584 bytes
dpnaddr.dll: 5.03.2600.2096 English Final Retail 3/12/2004 01:08:10 3584 bytes
dpvoice.dll: 5.03.2600.2096 German Final Retail 3/12/2004 01:09:50 214016 bytes
dpvsetup.exe: 5.03.2600.2096 English Final Retail 3/12/2004 01:10:18 83456 bytes
dpvvox.dll: 5.03.2600.2096 German Final Retail 3/12/2004 01:09:50 116736 bytes
dpvacm.dll: 5.03.2600.2096 German Final Retail 3/12/2004 01:09:50 21504 bytes
dpnhpast.dll: 5.03.2600.2096 English Final Retail 3/12/2004 01:09:50 34816 bytes
dpnhupnp.dll: 5.03.2600.2096 English Final Retail 3/12/2004 01:09:50 60928 bytes
dpserial.dll: 5.00.2134.0001 German Final Retail 8/18/2001 12:00:00 54032 bytes
dinput.dll: 5.03.2600.2096 German Final Retail 3/12/2004 01:09:50 163328 bytes
dinput8.dll: 5.03.2600.2096 German Final Retail 3/12/2004 01:09:50 186368 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 German Final Retail 8/23/2001 05:00:00 467968 bytes
joy.cpl: 5.03.2600.2096 German Final Retail 3/12/2004 01:10:42 69632 bytes
gcdef.dll: 5.01.2600.0000 German Final Retail 8/23/2001 05:00:00 223232 bytes
pid.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:41:00 31744 bytes
dsound.dll: 5.03.2600.2096 German Final Retail 3/12/2004 01:09:52 360960 bytes
dsound3d.dll: 5.03.2600.2096 English Final Retail 3/12/2004 01:09:52 1294336 bytes
dswave.dll: 5.03.2600.2096 English Final Retail 3/12/2004 01:09:52 18944 bytes
dsdmo.dll: 5.03.2600.2096 English Final Retail 3/12/2004 01:09:52 181760 bytes
dsdmoprp.dll: 5.03.2600.2096 German Final Retail 3/12/2004 01:09:52 74240 bytes
dmusic.dll: 5.03.2600.2096 German Final Retail 3/12/2004 01:09:50 104448 bytes
dmband.dll: 5.03.2600.2096 English Final Retail 3/12/2004 01:09:50 28672 bytes
dmcompos.dll: 5.03.2600.2096 English Final Retail 3/12/2004 01:09:50 61440 bytes
dmime.dll: 5.03.2600.2096 English Final Retail 3/12/2004 01:09:50 181248 bytes
dmloader.dll: 5.03.2600.2096 English Final Retail 3/12/2004 01:09:50 35840 bytes
dmstyle.dll: 5.03.2600.2096 English Final Retail 3/12/2004 01:09:50 105984 bytes
dmsynth.dll: 5.03.2600.2096 English Final Retail 3/12/2004 01:09:50 103424 bytes
dmscript.dll: 5.03.2600.2096 English Final Retail 3/12/2004 01:09:50 82432 bytes
dx7vb.dll: 5.03.2600.2096 German Final Retail 3/12/2004 01:09:52 619008 bytes
dx8vb.dll: 5.03.2600.2096 German Final Retail 3/12/2004 01:09:52 1227264 bytes
dxdiagn.dll: 5.03.2600.2096 German Final Retail 3/12/2004 01:09:52 1875968 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/18/2001 12:00:00 924432 bytes
mfc42.dll: 6.02.4035.0000 English Final Retail 3/12/2004 01:09:56 1024000 bytes
wsock32.dll: 5.01.2600.2096 German Final Retail 3/12/2004 01:10:10 24576 bytes
amstream.dll: 6.05.2600.2096 English Final Retail 3/12/2004 01:09:48 70656 bytes
devenum.dll: 6.05.2600.2096 German Final Retail 3/12/2004 01:09:50 59904 bytes
dxmasf.dll: 6.04.0009.1125 German Final Retail 3/12/2004 01:09:52 499741 bytes
mciqtz32.dll: 6.05.2600.2096 German Final Retail 3/12/2004 01:09:56 35328 bytes
mpg2splt.ax: 6.05.2600.2096 English Final Retail 3/12/2004 01:10:44 148480 bytes
msdmo.dll: 6.05.2600.2096 English Final Retail 3/12/2004 01:09:58 14336 bytes
encapi.dll: 5.03.2600.2096 English Final Retail 3/12/2004 01:09:52 20480 bytes
qasf.dll: 6.05.0001.0900 German Final Retail 12/12/2002 00:14:32 173056 bytes
qcap.dll: 6.05.2600.2096 German Final Retail 3/12/2004 01:10:02 192512 bytes
qdv.dll: 6.05.2600.2096 German Final Retail 3/12/2004 01:10:02 278528 bytes
qdvd.dll: 6.05.2600.2096 German Final Retail 3/12/2004 01:10:02 386048 bytes
qedit.dll: 6.05.2600.2096 German Final Retail 3/12/2004 01:10:02 563200 bytes
qedwipes.dll: 6.05.2600.2096 English Final Retail 3/11/2004 23:06:12 733696 bytes
quartz.dll: 6.05.2600.2096 German Final Retail 3/12/2004 01:10:02 1268224 bytes
strmdll.dll: 4.01.0000.3928 German Final Retail 3/12/2004 01:10:06 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/18/2001 12:00:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/18/2001 12:00:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/18/2001 12:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/18/2001 12:00:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/18/2001 12:00:00 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/18/2001 12:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/18/2001 12:00:00 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/18/2001 12:00:00 154624 bytes
mswebdvd.dll: 6.05.2600.2096 German Final Retail 3/12/2004 01:10:00 205312 bytes
ks.sys: 5.03.2600.2096 German Final Retail 3/12/2004 01:13:24 140288 bytes
ksproxy.ax: 5.03.2600.2096 German Final Retail 3/12/2004 02:10:44 130048 bytes
ksuser.dll: 5.03.2600.2096 German Final Retail 3/12/2004 02:09:56 4096 bytes
stream.sys: 5.03.2600.2096 German Final Retail 3/12/2004 00:53:18 48512 bytes
mspclock.sys: 5.03.2600.2096 German Final Retail 3/12/2004 00:44:38 5376 bytes
mspqm.sys: 5.01.2600.2096 German Final Retail 3/12/2004 00:44:40 4992 bytes
mskssrv.sys: 5.03.2600.2096 German Final Retail 3/12/2004 00:44:40 7552 bytes
swenum.sys: 5.03.2600.2096 German Final Retail 3/12/2004 01:21:16 4352 bytes
mstee.sys: 5.03.0000.0900 German Final Retail 12/12/2002 00:14:32 5504 bytes
bdaplgin.ax: 5.03.0000.0900 German Final Retail 7/9/2004 04:26:38 16896 bytes
bdasup.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 11392 bytes
msdvbnp.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:38 52224 bytes
psisdecd.dll: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:40 354816 bytes
psisrndr.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:40 30208 bytes
ipsink.ax: 5.03.0000.0900 German Final Retail 7/9/2004 04:26:38 14848 bytes
mpeg2data.ax: 6.05.2600.2096 English Final Retail 3/12/2004 01:10:44 118272 bytes
ndisip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 10112 bytes
mpe.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 15104 bytes
streamip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 14976 bytes
msvidctl.dll: 6.05.2600.2096 German Final Retail 3/12/2004 01:10:00 1455104 bytes
slip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 10880 bytes
nabtsfec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 83968 bytes
ccdecode.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 16384 bytes
vbisurf.ax: 5.03.2600.2096 English Final Retail 3/12/2004 01:10:44 30720 bytes
msyuv.dll: 5.03.2600.2096 English Final Retail 3/12/2004 01:21:16 17408 bytes
kstvtune.ax: 5.03.0001.0904 German Final Retail 7/19/2004 16:19:30 285696 bytes
ksxbar.ax: 5.03.0001.0902 English Final Retail 7/9/2004 04:26:38 39424 bytes
kswdmcap.ax: 5.03.0000.0900 German Final Retail 7/9/2004 04:26:40 226304 bytes
wstcodec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 18688 bytes
wstdecod.dll: 5.03.2600.2096 German Final Retail 3/12/2004 01:10:10 51200 bytes
msdv.sys: 5.01.2600.0000 English Final Retail 7/9/2004 04:26:38 52096 bytes
