Far Cry Far Cry 2 Patch v1.01
- Ersteller QXARE
- Status
S
Straßdörfler
wollte ich grad auch schreiben ^^
naja das spiel lief bei mir eigentlich perfekt auch ohne patch....
Hier der Changelog:
Multiplayer
* Server's IP address now displays in lobby, beside the match’s name (for direct IP join to work).
* Dedicated Server can now be launched in command line.
* Improved match start conditions. Ranked games can now also start if the player max is attained and everybody but the host is ready.
* Fixed a bug causing random crashes when joining a game.
* Ranked matches in progress will no longer display in the match list.
* Fixed players with same name by using identifiers instead of names.
* Fixed crash when creating a LAN game without a network cable.
* The diamond pool is now always validated after class upgrades, reset or rank up to avoid getting more diamonds than you are supposed to for your rank.
* When creating a dedicated server with PunkBuster enabled, then close it to create another but this time with PunkBuster disabled, PunkBuster will still be considered ON, on this new server.
* Fixed a problem where a player could get stuck (and couldn’t get killed) after pressing the interaction key while wounded and getting rescued by a teammate at the same time.
* Fixed players getting disconnected if they have too many user maps and try to enter the map rotation menu in a Player or Ranked match.
* Vehicles will now always respawn even if they are never used.
* Fixed users not being able to see a match if the host switched match mode after a rank.
* Fixed a glitch that could make a player invisible to another.
* Fixed incorrect check for negative values when adjusting diamond count.
* Fixed a problem where a player would render through objects if healing a wounded playing while being wounded at the same time.
* Fixed reload not being interrupted on the host when a client picks a weapon while reloading.
* Fixed Field Manuals not unlocking after game mode change.
Singleplayer
* Fixed health not changing with the difficulty level.
* Keyboard controls remapping in single mode now carry into multiplayer mode.
* A buddy will no longer get stuck when healing him while player is receiving damage.
* Stats of favourite weapon are now properly reset between loaded save games.
* The mortar will no longer move the player through wall.
* Mission objectives markers are now show properly after loading a save game.
General
* Fixed glider key remapping.
* Game will now minimize in order to show the website when clicking on ubi.com.
* Dolby 5.1 is now supported for most sound cards.
* Fixed a random crash that could happen when pressing ESC to cancel a Benchmark run.
* Added CPU Intensive benchmark test run.
* Fixed Jackal Tapes and Partner Tapes pages.
Map editor
* Fixed crash in editor when deleting many objects in very rapid succession.
* Fixed crash in editor during parsing of the map headers.
Hier der Changelog:
Multiplayer
Singleplayer
General
Map editor
Ultrawoach
- Jan. 2007
Wie sieht es mit der Maussteuerung unter DX10 aus? Hat das schon jemand geteset?
Also wenn die das nicht in den Griff bekommen, wird das Game wieder verkauft.
Und die respawn zeiten der "Gegner" wurden die auch angepasst?
In den Release notes steht leider nichts davon...
Ultrawoach
- Jan. 2007
An der Grafik? Was soll denn da gemacht werden?
Das einzige was zu tun wäre, ein paar Tiere mehr in Arfika
Ich weis echt nicht was manche Leute an der Grafik zu bemängeln haben?
Viel wichtiger ist doch das gameplay, und das ist ja bekanntlich unter aller Sau!
Was ist schon ein ein Shooter der schön aussieht, aber sich übelst schlecht spielen lässt?
Ich bin echt Maßlos enttäuscht von Ubisoft! Hab das Gefühl das die sich überhaupt nicht für die Community interessiert! Am Singleplayer wurde leider kaum etwas verändert. Und für diesen habe ich mir das Game gekauft
SubZero1987
Banned
- März 2007
Ist das geil endlich kann ich es spielen.
Rav3n666
- Okt. 2005
Also wieder ein Patch, den die Welt nicht braucht. Das wichtigste wär für mich gewesen, dass die Maussteuerung gefixt wird und dass das Spiel nicht immer nach 1 bis 2 Stunden abkackt. Und das hier war ja besonders wichtig: * Game will now minimize in order to show the website when clicking on ubi.com.
Super UBI.
Super UBI.
Ultrawoach
- Jan. 2007
@Hurrycane:
Deinen Wunsch kann ich leider auch nicht ganz nachvollziehen! Ich hab eine 8800gts und spiel mit 4aa.
Und 8aa wird dir doch reichen, wenn nicht, dann rutsch doch mit deinem Stuhl mal ein paar cm zurück.
Dann ist die Treppenbildung auch nicht mehr so schlimm ^^
@Rav3n666:
Ich hab jetzt auch die Schnauze voll! so kann ich nicht spielen. Die sollen sich mal ein Vorbild an richtige Shootern nehmen ála COD4 oder CSS. Und der Widescreenfix geht dank Patch auch nicht mehr.
Und selbst schafft es UBI nicht das zu richten... Armes UBISOFT!
@Rav3n666:
Gerolstein
- Juli 2008
Toll, hatte mich schon gefreut auf den patch und gehofft, dass die das endlich mit dem desktop crash gebacken bekommen, nach 5 min war ich wieder aufm desktop, toll..... echt super support von ubisoft...... wenn das so weiter geht wird sich doch eh fast niemand Far Cry 3 kaufen...
Ultrawoach
- Jan. 2007
FAR CRY 3 nein Danke!!
Ich lass mich nicht noch einmal verarschen.
FARCRY2 ist am absturz nicht schuld....
bei mir ist es auch oft abgestürzt...dann hab ich vcore mal was höher gestellt..bzw fsb niedriger und schon ist es kein mal mehr abgekackt...! das ist auch der grund beim absturz bei crysis wars!
(Multiple Satzendzeichen entfernt)
Ultrawoach
- Jan. 2007
Ja dann sollte man seinen Rechner mal mit Prime etc testen! Wenn du schon übertaktest dann richtig
- März 2008
Ich bin mal gespannt, ob jetzt wenigstens die Tastenbelegung richtig funktioniert. Ich habe ein und aussteigen auf F gelegt. Wenn ich aber am MG stehe dann muss ich E drücken um auszusteigen.
Dann habe ich mich noch auf Fixes für den Widescreenmodus und die Steuerung gefreut. Daraus ist ja leider nix geworden.
Ich habe alle paar Sekunden auch mal einen kleinen Ruckler. Mal schauen, ob das auch weggeht.
SubZero1987
Banned
- März 2007
Also mir hat der Patch SEHR geholfen.
Ich konnte es vorher garnicht spielen. jetzt kann ich es spielen
Auf 1024x768 und alles auf Mittel.
GEHT DOCH
GEHT DOCH
W0lfenstein
- Apr. 2007
Der Patch is meiner Meinung nach voll fürn Ar.....
Endlich erscheint der Patch , und dann sowas...Das is wie ein Schlag ins Gesicht
Belanglosigkeiten wurden gefixt und auf die wesentlich wichtigeren Dinge wurde nicht bzw kaum eingegangen.... Es gibt dinge die es echt nötiger hätten gepatch zu werden....
Ich für meinen Teil werde den Patch nicht nutzen, da der Widescreen Fix mit dem Patch nicht funtzt, und die natürlich auch nicht daran gearbeitet haben....
Nunja, zeigt wiedermal wie sehr die sich die Probleme der Leute zu Herzen nehmen.....
Btw, es gibt sicher welche die gleich wieder angerannt kommen und sagen ich würde maßlos übertreiben ...Aber das ist nunmal MEINE Meinung.
- Status
