Festplatten noch okay?
Jacky007
Okt. 2006
HI,
habe hier zwei Festplatten auf einem Server (Raid1) mit folgenden Werten:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0005 139 139 054 Pre-fail Offline - 73
3 Spin_Up_Time 0x0007 185 185 024 Pre-fail Always - 340 (Average 281)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 26
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 124 124 020 Pre-fail Offline - 33
9 Power_On_Hours 0x0012 093 093 000 Old_age Always - 50361
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 25
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 71
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 71
194 Temperature_Celsius 0x0002 193 193 000 Old_age Always - 31 (Min/Max 22/37)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
=== START OF READ SMART DATA SECTION ===
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Interrupted (host reset) 30% 40712 -
# 2 Extended offline Completed without error 00% 24662 -
# 3 Extended offline Completed without error 00% 24644 -
# 4 Extended offline Completed without error 00% 22079 -
# 5 Extended offline Completed without error 00% 22061 -
# 6 Extended offline Completed without error 00% 20452 -
# 7 Extended offline Completed without error 00% 20374 -
# 8 Extended offline Completed without error 00% 11105 -
# 9 Extended offline Completed without error 00% 11075 -
#10 Extended offline Completed without error 00% 6 -
2te Festplatte:
1 Raw_Read_Error_Rate 0x000b 099 099 016 Pre-fail Always - 2
2 Throughput_Performance 0x0005 139 139 054 Pre-fail Offline - 72
3 Spin_Up_Time 0x0007 193 193 024 Pre-fail Always - 283 (Average 310)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 28
9 Power_On_Hours 0x0012 093 093 000 Old_age Always - 50357
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 27
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 69
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 69
194 Temperature_Celsius 0x0002 193 193 000 Old_age Always - 31 (Min/Max 23/38)
# 1 Extended offline Interrupted (host reset) 10% 40708 -
kann man da was erkennen, ob die Festplatten noch okay sind?
Danke im Voraus.
Sehen noch gut aus, am besten einmal komplett mit daten befüllen ( mit den Tool h2testw) und dann noch einmal die Werte posten
wichtig ist das die Werte von
auf 0 bleiben
€dit: ach die laufen noch im Raid, ok dann den Restplatz mal füllen dann :)
Also da die Platten im Raid laufen würde ich mir da keine Gedanken machen...
Ich persönlich würde sie nutzen.
die Festplatten sind zu 99% voll, daher kann ich sie nicht mehr wirklich voller machen :D - wollte nur sicher gehen, dass die Platten noch okay sind, da mir letzte Zeit aufgefallen ist, dass der Server nicht so schnell wie sonst ist.. aber liegt wohl woanders..
danke
2te Festplatte:
Wenn ich das richtig verstehe gab es ei der zweiten Platte bereits Lesefehler. Das sollte erst ab einer bestimmten gelesenen Datenmenge passieren. Jeder Hersteller hat dazu eine Angabe für die Wahrscheinlichkeit eines Lesefehlers. Würde ich beobachten. Solange die Lesemenge mit der Wahrscheinlichkeit für einen Lesefehler korreliert ist alles gut, ist es höher schlecht. Dann muss die Platte raus.
Reaktionen: Jacky007
Schwebende Sektoren wird man bei Platten die im RAID 1 laufen, nicht finden wenn die RAID Lösung etwas taugt. Die Werte sind also soweit in Ordnung, vor allem im Anbetracht des Alters, die haben ja die 5 Jahren von den Herstellern üblicherweise geplante Nutzungsdauer schon hinter sich. Daher wäre es nicht falsch mal an einen Ersatz nachzudenken und nimm auf jeden Fall HDDs mit Zulassung für den Dauerbetrieb.
Alternate 4
