Jackery IFA Fireplace
Frage zu Catalyst 4.9 -> 4.10
C
Consideration
ich habe zur Zeit noch den Catalyst 4.9 Treiber insklusive CCC installiert.
Wenn ich den neuen Treiber (4.10) installieren möchte, muss ich den Catalyst 4.10 mit CCC downloaden, ohne kann ich den Treiber ohne den CCC installieren, da ich den CCC ja bereits bei der 4.9 Version installiert hatte ?
Ich meine, gibt es beim CCC einen Unterschied (CCC in4.9 <--> CCC in 4.10) ??
DANKE im Voraus
Ja, es gibt nen Unterschied:
Auszug aus den Release Notes vom 4.10er
New Features for the CATALYST™ CONTROL CENTER
This section provides information on new features and enhancements introduced in the latest version of the CATALYST™ CONTROL CENTER. This includes the following:
CATALYST™ CONTROL CENTER Display Option
The CATALYST™ CONTROL CENTER 4.10 introduces a new Display Option page. The Display Option page provides for modification of options such as; 3D Refresh Rate Override, Display Detection Option, and Display Management Options.
Updated SDK for the CATALYST™ CONTROL CENTER
A new Sofware Developer Kit is now available for the ATI CATALYST™ CONTROL CENTER.
Resolved Issues for the CATALYST™ CONTROL CENTER
The following section provides a summary of the issues that have been resolved in the latest version of CATALYST™ CONTROL CENTER. These include:
-Having the display properties page active and attempting to close the CATALYST™ CONTROL CENTER no longer results in a .net exception error message appearing
-Loading the CATALYST™ CONTROL CENTER at a resolution lower than 800x600 when the system is connected to an HDTV no longer results in the resolution not changing to 800x600 and the button area of the CATALYST™ CONTROL CENTER not being visible
-Entering the Overlay option page in the CATALYST™ CONTROL CENTER and moving a media sample between the first and secondary display devices no longer results in the sliders intermittently becoming enabled and disabled
-Entering the Hotkey manager in the CATALYST™ CONTROL CENTER no longer results in the ability to edit two of the menus
-Using the Add/Remove program option to remove the ATI MULTIMEDIA CENTER™ no longer results in an empty ATI MULTIMEDIA CENTER™ menu being displayed when hovering the mouse pointer over the CATALYST™ CONTROL CENTER system tray
-A yellow background is no longer displayed for the DFP icon when using the CATALYST™ CONTROL CENTER Wizard
Du kannst aber das 4.9er CCC behalten, wenn du damit zufrieden warst.
